Question about Black & Decker CC800 Shredder
Will not shred
Wont accept paper
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
After shredding a piece of paper the machine wont shut off it keeps running
Please check to make sure the paper sensor is not blocked in some way.
This usually happens if there is any sticky tape on the paper or envelope shredded.
Apr 01, 2011 | Staples Office Equipment & Supplies
It does not want to shred at all
good you posted in fax machines. you do not want them to shred. if a shredder wont shred the entrance switch is glogged with paper dust or needs to be replaced. it is the sensor that sees the paper when you put it in
Jan 07, 2011 | Office Equipment & Supplies
Good morning-my P50CM shredder motor seems to be working fine (same noise as usual) in both forward and reverse, however it wont accept paperfor shredding .I have removed as much cut paper between the...
You shredder needs a new shredding head. I'm sorry to say. You will be better off getting a new shredder. I am a senior level shredder technician in CO. I have seen this problem many times and it is an expensive repair. Hope this helps. If you have further questions please respond.
Aug 25, 2010 | Fellowes P50CM Shredder
Will not shred, but makes clicking noise, will run in reverse
Possible that the actuator which feeds paper in has gotten affected. With the unit UNPLUGGED try looking to see if some paper has gotten wedged in there. If you can disassemble it you might be able to see the problem. Good Luck.
Aug 04, 2009 | Fellowes 3011001 Shredder
Royal VF12mx shredder
Pour some shredder oil in the throat where you normally insert the paper...put some shredder oil directly onto 1 sheet of paper and try shredding 1 sheet. If it wont even shred 1 sheet I would ask is the shredder running???
Mar 05, 2009 | Royal VF1012mx Shredder
Machine will not accept papers
The problem is the acrylic gear that runs directly off the motor. The threads on it are small, so it easily gets stripped. The engine can grab it better in reverse, since that side of the gears isn't rounded off. That gear needs to be replaced. I'm looking for a replacement short of exchanging it for a new one at target.
This post looks promising:
Link
Jan 16, 2009 | Aurora Electronics AS1018CD Shredder
Black & Decker CC800 Shredder Logo
44 people viewed this question
Top Black & Decker Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Black & Decker Office Equipment and Supply Expert? Answer questions, earn points and help others
