Question about Canon i9900 InkJet Photo Printer
I am getting support code 1403 Print head problem. It suggests I remove the print head and reinstall it. I have no idea how to remove a printhead or just what the printhead is.
SOURCE: How do I remove printhead?
same as when you change ink tanks...
1.follow the same procedure you use to change ink tanks/cartridges to remove the current ink tanks
2.remove all ink tanks/cartridges
3.the printhead is what the ink tanks/cartridges sit in, the furthest half of the part the ink tanks/cartridges sit on is the removable part/printhead, it is loose so you can simply reach in and carefully pull it out.
Easy as 123 ...
eSid
Posted on Jun 13, 2009
JongCur
  • 88 Answers
SOURCE: new printhead will only print 3eBK, no color
If you're concerned with a clogged printhead try to clean it with acetone solution. Also, check the cable connections to your printerheads they might be loosened..
Posted on Apr 09, 2008
checkitright
  • 1362 Answers
SOURCE: Code U052
It's most likely an after market cartridge. Try a diiferent one or get the OEM.
Posted on Jul 15, 2008
SOURCE: Printhead error "no error code number" turn power off.
you need to enter a service mode before the error message pops up. hold down paper source button + online.
that should override the message before it pops up.
go to replace print head selection. or do a clean. it may still be working. let me know if this doesn't work....but at least you can still get past the message now! marty
Posted on Dec 27, 2010
itguy2000
  • 97 Answers
SOURCE: getting "Error Number : 1403
Not sure what you are asking. You posted the solution?
Posted on Jan 24, 2011
Why is Alarm code 5 flashes not going away?
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
1401/E05
Description: The print head is not installed or has not been properly installed.
1403
Description: A print head temperature sensor error has occurred.
1405
Description: Faulty data of the print head.
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/
Aug 26, 2014 | Canon PIXMA iP3500 Printer
I just purchased a brother mfc-6490cw and it will not print in black. all other colors look good on the test print. I have installed a new black cartridge and cleaned the print head several times. any...
The following may work: remove all the ink supplies. Remove the printhead and soak it for about 5 minutes in 0.5" of very hot water. Gently blot the printhead on a soft damp paper towel to remove the excess water, then replace in the printer and then reinstall the ink supplies.
Mar 08, 2011 | Brother MFC 6490CW InkJet Printer
Getting "Error Number : 1403
Jan 24, 2011 | Canon Office Equipment & Supplies
My Kodak 5500 all in one won't print in black ink
This is a common problem. Please follow the below mentioned steps:
  • Reseat the ink and the printhead on the printer.
  • On doing this, the printer will ask you to print a calibration sheet for which, it would display the instructions on the printer screen.
  • After printing the calibration sheet, press Menu button and got to the option Clean Printhead and hit ok.
  • Choose deep clean and hit ok.
If the issue persists, you need to get another printhead.
Kodak will not charge you for the printhead.
Oct 10, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Code U052
Dear dgthorpe,
This indicates that printhead of your printer faulty. Commonly this problem come with short circuitry problem in printhead so it may harm logic board and carriage unit too. I suggest you to try checking with another printhead first.
Regards,
Oct 10, 2008 | Canon MP970 Photo All-In-One InkJet...
5 flashes amber pixma ip3000 5 AMBER FLASHES PIXMA IP 3000
Try this link http://www.fixyourownprinter.com/forums/inkjet/27412
Stanr
Oct 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
I have just re-started my Canon PIXMA MP610 after it has been in storage for 2 months. It is around 1yr old. It seemed to work OK. When i went to print the 1st page, the paper jammed because of some...
I would suggest removing the printhead, make sure there are no more dead roach's under the printhead, also make sure all lights on the ink tanks are lite up, the first error code you mentioned has to do with the ink tanks, the second one has to do with the printhead. I would suggest un-installing the printhead, then reinstalling it doing the alignment, and that should clear the error code.
Sep 28, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon pixma mp780
Try uninstalling/reinstalling the drivers.
Is the error light flashing?
From the printer utility can you print a nozzle check sheet or align the printhead?
Does it seem to be printing (feeding sheet and moving printhead) or nothing happening at all?
Try removing all the tanks, take out the head. If blocked try cleaning manualy by running warm water over the ink ports/printhead jets - dry off and reinstall.
May 10, 2008 | Canon PIXMA MP780 All-In-One InkJet...
I860 won't print properly
Buying a new printhead is a mighty good suggestion, it seems you have pretty well used up the maximum service life of your printhead, if i'm not mistaken. Try to reinstall your printer along with its software. Go to settings>control panel > remove hardware> then,reboot. After, rebooting, re-install your printer software and drivers.
Dec 29, 2007 | Canon i860 InkJet Photo Printer
Canon i9900 InkJet Photo Printer Logo
4,614 people viewed this question
old marine
old marine
