Question about Panasonic Televison & Video
How do i eject vhs tape from panasonic dmr-ex79
  • Panasonic Master
  • 1,511 Answers
You can not. Tape has wrapped around spindle.
Posted on Jan 22, 2015
  • 883 Answers
SOURCE: vhs tape gets chewed
Dear William,
the rubber belts and rubber capstan need cleaning/conditioning. you can attempt this with alcohol swabs and if you find rubber conditioner (in the past was easy to find in audio supply stores) apply some of this also. if this treatment does not solve, then may need new rubber belt kit. good luck.
Posted on Dec 27, 2007
  • 77 Answers
SOURCE: VHS Won't play
i had the same problem and it turned out my motor was getting realy weak from exessive use and it would cost me more to fix it then it would be for me to buy a new one
Posted on Feb 26, 2008
SOURCE: Cannot eject VHS tape from Sony SLV-X811
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
Posted on Mar 02, 2008
  • 139 Answers
SOURCE: VCR tape won't eject
The flap on the door stays open until the tape is ejected. There are two possible ways to remove the tape. First, with the power off, try to locate the drive pulley or gear on the side of the tape housing. It may be possible to turn it with your finger and cause the tape to eject. The eject mechanism will move VERY slowly when you use this technique.
The second way to do it should normally be done by an experienced technician, because it involves taking it even farther apart...and it may be difficult to reassemble. There are typically four screws that hold the tape mechanism in place...two near the top front and two near the back. It should be possible to remove those screws and pull the entire mechanism out of the VCR. Then you can more easily rotate the eject pulley (or gear) and remove the tape. If this sounds a little scary, I would definitely recommend placing the top back on and acting like nothing happened!
Posted on Mar 17, 2008
  • 52 Answers
SOURCE: Panasonic 7350 VCR Keep ejecting tapes just seconds after loading
This happens when he strings are worn out or broken. It will not hurt to replace the strings of the VCR after some while.
Posted on Feb 09, 2009
I have a Panasonic VCR (DMR-ES35V) and when you insert the tape, it does not thread the tape across the video head. The tape runs for a moment and then ejects.
There's either damage in the drive section, or more likely and in some cases "plus" the Mode Switch is set in the wrong position or is faulty. The mode switch tells the electronics what position the VCR mechanism is in. Such as play or fast-forward. If in the wrong place it will carry out other functions - such as eject - in your case.
Sep 27, 2013 | Panasonic PV-V4022 VHS VCR
Where can I get a user manual for a Panasonic DMR-EZ48V without hassle
Google this manual download from panasonic.com link.You need adobe pdf reader or sumatrapdf to open the manual.
Aug 16, 2010 | Panasonic DMR-EZ48VK DVD Recorder
Panasonic DMR E20 Produces a line of distortion along the bottom
Sounds like you see head switching from the tape. Most TV are over scanned enough to hide it.
Aug 30, 2009 | Panasonic DMR-E20 DVD Recorder
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Can the panasonic dmr-eh75v copy a vhs tape to DVD?
Yes, that's mostly what I use mine for. You actually copy your VHS to the Hard Drive, then copy from your hard drive to your blank DVD. I'm about 1/3 of my way through reformatting my VHS library (800+ tapes.)
Nov 25, 2008 | Panasonic Diga DMR-EH75V DVD...
How To Burn a DVD from VHS tape
Insert the VHS tape. Do not press play. Insert a DVD RAM or DVD-R into the DVD side and press and hold DVD DUBBING, it should start playing the VHS immediately while recording on the DVD side.
Jun 03, 2008 | Panasonic DMR-E75V DVD Player/VCR
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
VHS will not eject tape
So open up the casing and retrieve the tape. I have done it a few times and it is not hard. Not sure if fixing it is worth it. I just buy a new one for cheap.
Nov 16, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
