Question about Sony CMT-HP7 CD Shelf System
CDs won't load. Mechanical error message. - Sony CMT-HP7 CD Shelf System
MCD36 6 disc changer won't eject or play CDs. Erro messages are Surface or CD loading!
Please remove the top cover and manually rotate the motor to release the loading. It can be due to a warped cd or a motor pulley which had slipped.
Also check if the linking cord to the loading motor is having a continuity.
If not there is fault in the processor controller or the loading IC.
Aug 09, 2011 | Car Audio & Video
Loads cds. I can hear the loading mechanism operating, I get the 'read' message, but 10 seconds later comes the error message
either the cd you are trying to use is in the wrong format for that cd player or something is wrong with the eye in the cd player
Jun 10, 2010 | Sony CDX-565MXRF 10-Disc CD Changer
Cd player keeps going out when i try to play/load/reject get 'error' message
Take out #7 and #31 fuses. Start the vehicle, the radio/cd will not come on. Shut the vehicle off and replace the fuses. Start the vehicle again and you shoud hear the cd player cycling through the cds. Be patient and let it go through the process. Then play/eject/load cds. It worked for me.
Mar 03, 2010 | 2003 Ford Expedition
6-disc Cd changer Mechanical Error
I talked to a dealer, all they could tell me is they have to send it to honda to fix it... a good 250$ for software fix...plus dealer will charge 50$ for each time they take the player out and in...
Jul 27, 2009 | 2005 Honda Accord
My sony vaio vgn-n110g w/ pioneer dvr stopped burnning
Sounds like you may need a new drive. If I remember correctly those run about $100 and if you feel confident and read the directions (and research it correctly on the internet) you should be able to install it yourself.
Jul 01, 2009 | Sony VAIO VGN-NR160ET Notebook
Bose 6 cd changer factory installed will not function.
Some people with this issue have had some sucess disconnecting the negative battery cable for 10 minutes to reset the stereo. After re-connecting the battery, the stereo should reset and the error message should clear at which point the CD player should also function. Apart from this, a service call at a dealer or a car stereo repair specialist are the only alternatives. Best of luck.
Greg
Jun 14, 2009 | 2002 GMC Envoy
Monsoon Radio CD CHANGER ERROR
CHANGEUR CD ERROR . g6 2006
Jan 14, 2009 | 2003 Hyundai Santa Fe
Neither dvds or cds are loading,
How to or can't boot from a CD or DVD. If the computer is loading to an error message when attempting to boot to ... Not all CDs and DVDs are bootable; in order to boot from a CD .
Read and follow instructions, Good Luck please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Compaq Evo n610c Notebook
Sony CMT-HP7 CD Shelf System Logo
56 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
