Question about Dell Latitude E5400 Notebook
WifI not switched on. - Dell Latitude E5400 Notebook
My wifi keeps disconnecting and have to restart phone to reconnect, but only lasts for maybe an hour
Samsung Galaxy S 4G Smartphone: WiFi disconnects (have to restart phone to reconnect, does not scan for WiFi connections):
Hello. It could be that your "Auto Network Switch" setting is on..
What Auto Network Switch does: when the WiFi gets too low the phone automatically switches to cellular, and when cellular connection gets too low, the phone will switch to WiFi
All Samsung Galaxy's are not alike for it's menu settings.. but you can try:
for S4 and up:
Settings>hold down on WiFi settings for a second then let go > un-check box at top for "Smart Network Switch"
for other Samsung Smartphones see the attached video below:
If your device is having issues trying to scan for your router.. try turning off your router for 2 minutes, then turn it back on.. make sure you wait a few minutes for your router to properly boot back up before you try scanning for your WiFi network again
Jan 31, 2016 | Samsung Galaxy S 4G Cell Phone
My Nextbook 10.1 wont show the wifi ON/OFF switch, so I cant connect to the wifi
Do you mean a physical/hard, on-the-tablet WiFi ON/OFF switch, similar to the POWER ON/OFF switch ? I don't think any tablet or smartphone has that. You turn on/off WiFi with a "soft" switch from Settings-->Network (or WiFi). Hope this helps.
Jan 04, 2015 | Tablets & eReaders
Where is the wifi switch on a Gateway laptop?
It depends on your wifi configurations.... but I need more information from you about your wifi
Mar 01, 2014 | Gateway Computers & Internet
Wifi switch damaged and i need to turn wireless on
You would either need to replace the portion of the case where the wifi switch is located (can't buy just the switch) check on ebay for cheap replacements.
You could if you want remove the wifi switch and hot wire the contacts together (permanent wifi on)
Nov 07, 2011 | Toshiba Satellite Pro L300 Notebook
How to turn on WIFI?
Look at the sides of your laptop. Look for a sliding switch with a wifi wave icon. Manually slide it to turn the wifi radio ON or OFF.
If you don't have that mechanical switch, look at your laptop's Function Keys (F1 to F12). Look for a function key with a wifi wave icon printed in a different color. Example, if F10 has that wifi wave icon, hold down the FN Key and press F10 to turn your wifi ON and OFF.
Jun 11, 2010 | Acer TravelMate 2480-2779 Notebook
How do i keep wifi switched on permanently
Hi:
Well you have to click on start in the bottom left hand corner of your PC. Than on the right there is a button that says "Connect to". Click on it. Then press View Wireless Connections. When your done just press on your optimum wifi/comcast wifi.
- For any questions email me at... xoiceybabe21@aol.com
Thanks,
Nikki
Nov 04, 2009 | Computers & Internet
How do I turn the radio on the wireless card
When your computer is switched on, the WiFi radio is almost always transmitting or receiving signals. In certain situations, as in an airplane, signals from the radio may cause interference. Use the following methods if you need to disable the radio and use your notebook without emitting radio signals.
Use the Optional Computer Radio On or Off Switch
If your computer has an external switch installed, use it to switch the WiFi radio on or off. See the computer manufacturer for more information about this switch. If you have Intel® PROSet/Wireless installed, the current state of the radio displays in the Intel PROSet/Wireless main window and on the Taskbar.
Use Intel PROSet/Wireless to Switch the WiFi Radio On or Off
From Intel PROSet/Wireless, the WiFi radio can be switched on or off. The status icon on Intel PROSet/Wireless displays the current state of the radio.
To start Intel® PROSet/Wireless, use one of the following methods:
  • Click Start > Programs > Intel PROSet Wireless > WiFi Connection Utility.
  • Right-click the Taskbar icon prosettaskbaricon1.jpg located in the lower right corner of your Windows* Desktop to open the Taskbar menu. Click Configure WiFi.
  • Double-click the Taskbar icon to open Intel PROSet/Wireless.
Switch the WiFi Radio On or Off from the Taskbar Icon
To switch the WiFi radio on or off, click the Taskbar icon image1_ipswtaskbaricon.jpg and select WiFi On or WiFi Off.
How to use the Device Manager to Disable the WiFi Radio
The WiFi radio can be disabled (made non-functional) from the Windows* Device Manager.
Note: If you disabled the WiFi radio from Windows*, then you must use Windows to turn the radio on. You cannot use a hardware switch or Intel PROSet/Wireless to enable the radio again.
Windows* XP
  1. From your desktop, right-click My Computer.
  2. Click Properties.
  3. Click Hardware.
  4. Click Device Manager.
  5. Double-click Network adapters and expand the selection by clicking the Plus symbol.
  6. Right-click the installed WiFi adapter.
  7. Choose Disable from the menu.
  8. Click OK.
Windows Vista*
  1. Use Control Panel > Mobile PC > Adjust commonly used mobility settings (if you use Classic View, select Control Panel > Power Options.
  2. Click Turn Wireless Off .
Hope this helps !
Jul 03, 2009 | Acer Aspire 3000 Notebook
ASUS wifi switch
Make sure that wifi is enabled in wireless switch utility. You can find that in the system tray next to the clock.
May 28, 2009 | Computers & Internet
Wireless adapter radio
Windows* XP
  3. Click Hardware.
  8. Click OK.
Windows Vista*
Nov 05, 2008 | Acer Aspire 3000 Notebook
Dell Latitude E5400 Notebook Logo
20 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
