Question about SonicWALL TZ 100 [son-01ssc8734] (son01ssc8734) Firewall
Error message on kapersky anti virus about data encryption
Some of the application components may not have been installed link and when you click on it firewall is listed
Having problems getting on social network sites since installing BT Infinity
This can happen due to many reason
  • First of all close all your browser,check your Date and Time of your Device for mismatch, if it is incorrect, change it . and reopen any social networking sites on new browser tab.
If still same problem, It could be because of Anti Virus. I am assuming your anti virus is Kaspesky.
  • Close all internet browsers. Open your antivirus control panel. In my case, it was Kaspersky antivirus.
  • Click on "Settings". Go to "Advanced Settings" tab and click on "Network".
  • Under the "Encrypted connections scan", uncheck the "Scan encrypted settings".
  • Click Apply and OK.
  • Now, relaunch your browser and open the desired website.
  • Right click on the Shortcut file of Google Chrome( assuming your browser is Google Chrome) at your desktop.
  • Choose Properties. A new window will appear on your screen.
  • You would see a field named "Target". Just Tweak that i.e modify it. Add the below code in front as show in the below image.-ignore-certificate-errors-.
Hope one of the above step will work for you.
Apr 11, 2015 | Facebook Social Network
Tip
How to speed up computers.
**1The main reason which slowdowns system is VIRUS ATTACK.
Powerful tool to avoid this is installing Anti Virus.
Anyhow installing a anti virus is not sufficient.You need update the anti virus continuously(once for a week)
Updating means:-Hackers will generate the viruses and they will upload those viruses to internet data base every day.Which enters our computer when connected internet.The companies which provides the anti virus software will scans those viruses and they update those virus name our anti virus data base so that if any programs by those virus names which are in anti virus data base.Anti virus will block those programs.
So It's necessary to update the anti virus program continuously.
If you have genuine Windows operating system you can use "Microsoft Security Essentials" for FREE.
**2The reason which slowdowns PC is creation of unwanted sectors in hard disc.
For this Defragmentation is the best method to clear unwanted sectorsTo defragment the hard disc Select the partition>Right click>Properties>Tools>Defragment disk>Defragment>ok
Watch this...
**3)Another aspect which slow downs the system is creation of error sectors
you can use Check Now option to clear error sectorTo activate Check Now*Select the partition>Right click>Properties>Tools>check nowIt check for error during next reboot
**You can use "CHKDSK" command in DOS(instant check)
**3)You can use Disk Cleanup to delete temporary files,offline pages,log files, queued and error reports(These files are not important and files consumes much memory which can't cleared by us so we need to use Disk Cleanup.
To use this thisSelect the partition>Right click>Properties>select Disk
Cleanup (Disk Cleanup can be used for C: drive only effectively(Because temporary files,offline pages,log files, queued and error reports are saved in C: only)
**Options and Menu's are with respect to Windows7 & Windows related operating systems.
Thank you have a nice day
on Jan 30, 2011 | Computers & Internet
Geeksquad com
Although it is the 2009 version of Kapersky, it was upgraded to the latest version upon installation. The subscription which came with your computer is good for one year and you will be receiving renewal notices as the end of the subscription nears. Thus, if the one year license was activated in Jan 2013, it would have expired eight months ago. Unless you have activated another security or anti-virus program, your computer is unprotected and you are in danger of not only having your personal data compromised, but you are also in danger of having your computer taken over by viruses and malware.
Aug 30, 2014 | Kaspersky Labs Anti-Virus 2009 for PC
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
My yahoo messenger cannot post my written my message at the chat person
Is a virus efect. Now update your anti-spyware (Malwarebytes'Anti-Malware are recommended) and run a full system scan. You can download "Malwarebytes'Anti-Malware" on this link: https://www.regnow.com/softsell/visitor.cgi?affiliate=10793&action=site&vendor=12128&ref=http%3A%2F%2Ffileforum.betanews.com%2Fsendfile%2F1186760019%2F1%2F1299945984.e7567972719c69ce6f8f74749d9c4964702a3606%2Fmbam-setup.exe Simply after you download Malwarebytes'Anti-Malware from the link of the above, doubleclick the downloaded file to install the application on your computer. Once theapplication is installed, double click on the Malwarebytes' Anti-Malwareicon to start the program. When the application is open, select Scan andthe application will guide you through the remaining steps.If I could be of furtherassistance, let me know.
Mar 13, 2011 | Yahoo Messenger
Good day. i want to download a free Kasperskt anti-virus. along the way, i need to remove eset node on - access scanner. upon uninstalling it, windows said it is only applicable on recent installation....
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Click to highlight ESET
Click to Remove/Uninstall
Click OK
Restart your computer.
Access: http://www.microsoft.com/security_essentials to download _free_ anti-virus software.
Install it, and it will auto-update, and do a virus-scan.
Dec 07, 2010 | Computers & Internet
I want to install Kaspersky Anti virus
iKaspersky Anti-Virus 2010 It is recommended to close all applications before the installation.
Before you begin to install Kaspersky Anti-Virus 2010 on your computer, make sure that you have removed (uninstalled) your previous antivirus software.
If you are installing using the Kaspersky Anti-Virus 2010 CD, please skip to Step 2. If you have purchased your software online, follow Step 1 to download it.
Click the download link provided in your order email to begin the download process. You will be asked to Run, Save or Cancel the download. Click Save.
  • The web browser will ask you where to save the file. Select where you want to locate the file and click the Save button.
  • The download process will begin, and depending on the speed of your Internet connection can take up to an hour.
  • When the download completes, click Run.
  • You may receive a warning that the publisher could not be verified. Click Run.
Step 2 - Install Process:
  • You will briefly see the install process copy the installation files to your computer. Wait for the process to finish.
  • The install process will check if there is a newer version online and download it if needed.
  • Wait a few seconds. The Setup Wizard will open.
  • In the welcome window of the Setup Wizard you can choose one of the following types of installation:
    • Express installation - full program installation with recommended by Kaspersky Lab experts settings (Custom installation in the left lower corner is not checked).
    • Custom installation - installation with the possibility to choose which program features to install (Custom installation in the left lower corner is checked). You will be able also to activate the application by special wizard. It is recommended for advanced users.
  • In order to start the Express installation click the Next button.
  • Read the license agreement. If you agree with all the terms, then click the I agree button. The installation continues. In order to stop the installation click Cancel.
  • The Setup Wizard offers to participate in Kaspersky Security Network. If you participate in the program, then Kaspersky Lab will receive information about new threats, detected on your computer, system information and send unique identification which is specified for your computer by Kaspersky Anti-Virus. Your personal data is not collected. Read the Data Collection Statement about using Kaspersky Security Network. If you agree with all the terms, check I accept the terms of participation in Kaspersky Security Network. Click the Install button. The installation continues.
  • The install process copies files and adds registry values. Wait until the process completes.
You may see the following notification from the Windows Security Center that there are problems with your computer:
This is normal and will automatically resolve itself after the process completes. The Windows Security Center messages will go away when Kaspersky Anti-Virus will be updated and have the latest databases.
Step 3 - Configuration Wizard:
Having copied the files the Setup Wizard offers to activate Kaspersky Anti-Virus 2010. You will be offered the following options of activation:
  • Activate commercial license - a 20-digit activation code should be entered (e.g. XXXXX-XXXXX-XXXXX-XXXXX). Your computer should be connected to the Internet to activate the product. The Setup Wizard will download and install a key file automatically.
  • Activate trial license. The Setup Wizard will download and install a key file which is 30 days valid. Your computer should be connected to the Internet to activate the product. Trial version is fully-functioning, however when a trial period expires the anti-virus databases will not be updated.
info1.gifIf the option Activate trial license is missed, it means the trial version a) was already installed or b) is installed now.
  • Activate later. If you choose this option, the Kaspersky Anti-Virus activation stage will be skipped. The application will be installed on your computer, all its options will be available to you, except for the update.
In order to activate a commercial version of Kaspersky Anti-Virus 2010, perform the following actions:
  • select Activate commercial license.
  • In the field Enter the activation code enter the activation code you obtained when purchasing the license. An activation code should be entered from the keyboard in Latin ONLY without any hyphens. The program calculates the number of entered symbols and automatically adds a hyphen where necessary.
If you are not asked to activate, the wizard has detected your existing valid license.
  • The Setup Wizard will connect with the Kaspersky Lab server and will download a license key file. Please, wait while the wizard activates your Kaspersky Anti-Virus 2010.
  • After the license is activated, you will see the License type and Expiration date. Click Next.
  • The installation and activation processes are now complete. Click Finish to open Kaspersky Anti-Virus 2010.
You may also refer to the product manual for Kaspersky Anti-Virus 2010, by clicking on the following link :-
http://docs.kaspersky-labs.com/english/kav2010_en.pdf
Sep 26, 2010 | Computers & Internet
Have a virus on my toshiba laptop, can i resolve this by restoring the factory settings?
Hi Andrewfairwa.
Yes, you may remove all the security threats in the Computer by restoring it to the Factory settings.
But, restoring the Computer to the Factory settings will also delete the Data in the Hard Drive.
Hence, you may try performing a Complete System Scan to check for any Virus or security threats.
You may perform the Complete System Scan by using the Anti-virus Application installed in the Computer.
If you have not installed any Anti-virus Application installed in the Computer, you may perform a online System Scan.
Let me provide the detailed steps to perform the online System Scan.
You may perform the free Online Scan by visiting the below link:
http://www.bitdefender.com/scanner/online/free.html
Please open the above link and click on "Start Scanner".
This will start the free Online System Scan.
Once the Scan is complete, check if the Virus or any security threats are removed from the Computer.
If there are still any threats, then you may backup all the important Data and restore the Computer to the Factory settings.
Hope this helps.
Please feel free to ask further questions.
Aug 18, 2010 | Toshiba Tecra A7-S712 Notebook
Window xp will not start
Hi
Problem is because of virus please install any good anti virus i.e. Eset nod 32, kaspersky or bitdefender....etc. after you install anti virus update it an scan your system problem will be solved.
Thanks
Jun 17, 2008 | HP Compaq nc6000 Notebook
SonicWALL TZ 100 [son-01ssc8734] (son01ssc8734) Firewall Logo
Top SonicWALL Computers & Internet Experts
Raymond Ramirez
Raymond Ramirez
Frank Zabroski
Frank Zabroski
Steve P
Steve P
Are you a SonicWALL Computer and Internet Expert? Answer questions, earn points and help others
