Question about Hardware & Accessories
Hi, I have a Grasslin Qe7+ timer for the boiler and suddenly I do not have hot water. After having a look several times I've found out that apparently works normal but the boiler never stars up. Happily I can get hot water when I press the boost button so the boiler is working properly. Any suggestions?. Thanks a lot.
SOURCE: Tefal Quick Cup not working
This is in my opinion a design problem. The wiring connects to the spiral heating element via spring loaded contacts which only have a tiny connection surface area. These gets arcing deposits on the surfaces and will periodically require scraping clean. To get access prise off the silver top assembly which is a snap fit, unclip the circuit board and pull the plastic water pipe off the top of the plastic cylindrical tank. Then remove the two star screws from the base and prise it free. The whole internal assembly can now be carefully removed intact from the kettle housing but the circuit board at the top will need to be turned vertically and guided down the main body on the way out.
Posted on Jun 29, 2008
SOURCE: Grasslin Digital wall mounted timer programme setting instructions please
pdf file link, instructions will say it is for a topica500 also known as a logica 500.
Hope this helps.RoyG
Posted on Mar 09, 2009
SOURCE: Vaillant boiler - heating OK, but no hot water.
Most likey problem is the diverter valve, not energising fully. This in turn will not move the little plastic lever arm that actuates the microswitch on the side, sending the signal to ignite.
You can buy a diaghram kit from most local plumb centres, you need to replace the diaghram and seals, don't forget the silicon grease to ensure the plunger doesnt stick. Kits less than a tenner.
You should have noticed before it stopped working completely the water had reduced in temperature before the weeks it failed.
To make sure it is a diverter valve fault, depress the microswitch if you can, when the hot water is flowing and hey presto the demand for hot water light should shine.
Posted on Apr 26, 2009
  • 148 Answers
SOURCE: Honeywell ST6400C - hot water not working
some digital thermostats do no not work with zone valves is this a new thermostat that you had installed
Posted on May 10, 2009
SOURCE: Worcester combi boiler losing pressure & water through o/flow
having the same problem and its a new bolier. thanks , adriano.
Posted on Jul 12, 2009
Hi i have a grasslin bath timer with a dial clock,how exactly do I use it?
Dial clock ... experiment by rotating dial clockwise several times to see what turns on-off.
Step by step for analog timers on following link
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
Feb 28, 2015 | Hardware & Accessories
Grasslin qe7 water heater wont turn on
Read product manual and it shows no troubleshoot resources:
Turn circuit breaker fully off and fully back on.
http://waterheatertimer.org/pdf/QE7-INSTRUCTION.pdf
Gene
h
Jan 21, 2014 | Water Heaters
Instructions for a grasslin qe7+ water heater timer
hi . I just have a small question. I have grasslin qe7 in my house. I shithed this off before I went for my holiday and now it's not working ;( what can I do now?
Apr 12, 2013 | V, Inc. 12v Dc Timergeneratortransfer...
I have lost the instructions for my boiler and I have seen that the timer is a Grassling timer, i don't know when it is on or off, it might not even work as the radiators seem to stay hot whatevr I do.
Without knowing which Grasslin timer you have, I cannot offer specific instructions:
Find Grasslin timers and manuals at following link:
http://www.intermatic.com/products/grasslin.aspx
I am familiar with Grasslin timers, and you can add a comment with specific question and I will respond.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 02, 2011 | Intermatic Hardware & Accessories
How to set the time and which is on out or in
pins IN = timer ON
pins OUT = timer OFF
Slide-switch must be pushed to right for timer to work
If dial is not rotating, wiring is incorrect (see below for wiring)
__________________________________________
Grasslin and Paragon both offer multiple-gang timers.
Grasslin manual says:
" For example, to turn lights ON at 5:00pm and OFF at
11:00pm, leave inward the 18 trippers between 5 and
11 on the "pm" side of the dial.
Link to Grasslin manual
Wiring timer:
Timer black goes to Hot wire
Timer red (or blue) goes to Load
Timer white goes to Neutral (if no neutral, then connect to bare ground)
If timer dial does not rotate, black and red wires are reversed
Oct 08, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Wired incorrectly need wiring diagram
I have baxi combi boiler genesis 80 and grasslin timer need to no what wires go were there are 4 wires coming out the timer red and brown together white and blue the timer is internal one can you help
Mar 18, 2010 | Intermatic Grasslin KM2ST-2D Timer, 2 Gang...
Hardware & Accessories Logo
202 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
