Question about Smeg WDI12 Front Load Washer / Dryer
Smeg washer dryer wdi12 how to get between the drums
4 Suggested Answers
SOURCE: drying operation on WD16BA on smeg dryer
I think all you have to do (that's how I do it anyway), is turn the program knob so that the line is at the beginning of the drying stage (the little 'sun'), having first of course chosen the desired amount of drying time with the knob on the far left...
Hope this helps, good luck...
Posted on Oct 03, 2008
SOURCE: broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Posted on Apr 17, 2010
heatman101
  • 43501 Answers
SOURCE: Smeg WDI12 Not Turning + can't get into it!
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 29, 2010
Smeg washer dryer not draining
Sounds tricky you may want to try this site, there's loads of help, advice and videos to help diagnose faults.
Give them a try. Hope you get this sorted. How to diagnose draining problems
Jan 31, 2014 | Smeg WDI12 Front Load Washer / Dryer
How do I change the outside door latch on a smeg integrated washer/dryer
Go to www.repairclinic.com and enter WDI12. With luck, you will be presented with a list of common repair parts and may be able to view a generic Smeg video showing disassembly
Jun 20, 2017 | Smeg WDI12 Front Load Washer / Dryer
Smeg washing machine stuck on pause
If the machine won't start then it will most likely be the door latch that is at fault.
Mar 12, 2012 | Smeg WDI12 Front Load Washer / Dryer
Dryer doesn't warm up It's a smeg washer/dryer and doesn't dry the clothes
either the red/ orange wire to the high side limit switch is burnt off !1 of the limit switch itself is fried
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Smeg WD1 12C, error code 10
I have a smeg wd1 12c washer dryer showing error code e01 any idea how to fix it?
Gilly
Nov 06, 2008 | Smeg WDI12 Front Load Washer / Dryer
heatman101
Apr 26, 2008 | Smeg WDI12 Front Load Washer / Dryer
Loud noise coming from machine
i would say its the bearings in the drum rather then the motor,that would be expensive over $200?
Dec 19, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg Washing machine
This happened to us before and we had to actually reset the unit. I had to call the tech support and they walked me through the process.
Mar 25, 2007 | Smeg WDI12 Front Load Washer / Dryer
Error code e14
E14 Dryer temperature probe in short circuit or interrupted
Jan 29, 2007 | Smeg WDI12 Front Load Washer / Dryer
Smeg WDI12 Front Load Washer / Dryer Logo
16 people viewed this question
Top Smeg Washing Machines Experts
matt
matt
ray gallant
Owen Barnes
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
