Question about ASUS DSL-N10 Wireless-N ADSL Modem Router
How to set up PPPoE connection for DSL-N10 - ASUS DSL-N10 Wireless-N ADSL Modem Router
Wat is my pppoe name and password
Most internet provider just set it to "obtain an IP address automatically" or "Dynamic" for both Cable and DSL. If you are using DSL, you may also be using PPPoE as connection type. You need to get this from your internet provider. It should be included in your account or if not provided they should give you one. If you are setting up a router do not forget to turn it off then on again after saving the settings made.
Jan 27, 2012 | Dell Computers & Internet
Keeps asking for pppoe settings ?
Hi and welcome to FixYa!
The Point-to-Point Protocol over Ethernet (PPPoE) is a network protocol for encapsulating Point-to-Point Protocol (PPP) frames inside Ethernet frames. It is used mainly with DSL services where individual users connect to the DSL modem over Ethernet and in plain Metro Ethernet networks.
This is a problem with you modem. You need to call your internet provider and have them insert it into your router and ask for your PPPOE settings. You may get lucky and be able to have them access it from there.
KittyTech
Sep 11, 2011 | Computers & Internet
I've problem with my ADSL i can't access by wireless??? i don't know why???
Some DSL Internet Service Providers (ISPs) use Point to Point Protocol over Ethernet (PPPoE) Authentication to establish Internet connection with their end-users. This article will guide you in setting up the router's PPPoE feature.
NOTE: This article assumes that you already have the username and the password for your DSL Internet connection.
Step 1:
Access the router's web-based setup page. For instructions, click here
NOTE: If you're using a Mac, click here for instructions.
Step 2:
On the Setup tab, click the drop-down arrow for Internet Connection Type then, select PPPoE.
Step 3:
Enter the Username and the Password for your DSL Internet connection.
Step 4:
Select Keep Alive.
Step 5:
Click Save Settings.
Step 6:
Click the Status tab.
Step 7:
Verify that the Connection Type is PPPoE then, click Connect.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 21, 2010 | Linksys WRT54G2 Wireless Router
Belkin N Router does not recognise PPPoA connection type
First reset the router by pressing the reset button for 10 seconds while power is ON and then after that run again the setup , just to give you a clue which one to choose for the internet setup, if you use Cable internet select Dynamic and if you use DSL internet set it to PPPoE and provide your email and password from your DSL company...
Dec 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
I can not get on the net via my router. I can get out on my laptop directly connected to DSL modem. what am i doing wrong?
That means your router is not yet configured for internet access. If you are on DSL, your modem's IP and router's IP might be conflicting with each other. You need to change the router's IP address. If not, you can simply configure PPPoE settings on the router's admin page. If you can open the router's setup page, look for Internet Connection Type, choose PPPoE and provide the information that it asks you like username and password given by your DSL provider.
Jul 03, 2009 | Dynex DX-E401 Router
New dir 625 with DSL-cat5 connection and NO internet on status.
If it keeps on trying to connect to PPPoE, try not to use PPPoE setting. Use Automatic Configuration or DHCP connection type.
Jun 10, 2009 | D-Link DIR-625 (790069292637) Wireless...
Modem settings for Siemens SL2_141
First of all check whether dsl yellow light is on or not.
if it is not on then contact bsnl local branch.
otherwise
remove dsl line from modem.
Then
open internet explorer
type http://192.168.1.1
username= admin
password= admin
click WAN
edit pppoe 0_35_1
connection type=bridging
encapusulating =LLC/Snap-bridge
next
again next
save
save/reboot
close IExplorer
connect DSL line.
if its work plz reply me
findme_rohit@yahoo.co.in
Sep 14, 2008 | Computers & Internet
Netgear wireless wpn824
Sounds link you need to setup PPPoE on your router. Not knowing who your ISP is, Netgear has this website that lists a lot of ISPs support on setting PPPoE up. that is located here: Netgear
If you can't find the info there, basically what you need to do is on your router, typically the main page, you might see an area that lists: DHCP, Static, PPPoE (or something similar). What you need to do, is select the PPPoE option and put your ISP login information (that is on your DSL modem now) there should be a connect or login button once your finished. Once that is done, your router does the logging in, instead of the modem.
Feb 03, 2008 | NetGear RangeMax WPN824 Wireless Router...
Adsl modem not working
First you must have a steady led light on the on Power, Act and Lan, the Sync led will flash until the modem connects to the DSL line. If you are not running a router but only a modem, you will need to create a PPPOE network connection on the computer. If you are using a router with the DSL modem you will need to create the PPPOE connection only on the router. I had recently a problem with the DSL service to my home. My modem showed DSL connected but could not connect the PPPOE connection, the telephone company had to reset the circuit that I am on which fixed the problem. BPCS
Dec 06, 2007 | Acer Altos G500 Server
PPPoE
If your have software from your DSL provider such as "WinPoet" or "Enternet300" or you need to run a program (other than your browser) from your desktop to connect to the Internet, then you will need to configure your router for PPPoE.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
ASUS DSL-N10 Wireless-N ADSL Modem Router Logo
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
