Question about Sony ICF-C1IP (Black) Docking Station
I pod dock pcb - Sony ICF-C1IP (Black) Docking Station
I pod dock not connecting properly
it sounds like you have a faulty connection piece on your docking station u mite want to take it back to the shop
Sep 02, 2012 | Audio Players & Recorders
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
Need replacement battery for I-pod docking station Model#5084
I have a battery from my if-2 by Sonic Impact. My ipod connectionwent bad. Battery and charger available.
Jul 23, 2010 | Sonic Impact Technologies IF22 Docking...
I just bought a I Pod dock ASD 11R and would like
Get a 3.5 plug with two RCA plugs and connect it to an aux imput via the headphone out of the dock.
Jan 24, 2010 | Denon AVR-3803 Receiver
I pods doesn't work after i remove it from radio dock.
I had that same problem too and i had to take my i-pod back because my machine messed it up so thats probably what your going to have to do to the repair shop said that there was nothin they could do and I was better off taking it back and my docking station messed it upso I had to get another i-pod and a docking station-I hope you get the problem fixed
Oct 09, 2009 | Starlite Nextplay Fashion iPod Docking...
Cant see a movie / photos using idk-o1 dock and 160 gb i pod
just go to the setting options and turn the tv out off and it should work fine,if not reset the settings to the default.
Dec 17, 2008 | Pioneer IDK-01 Universal iPod Dock
How to open the jbl radial micro speaker set?
Bit late! Just remove the four rubber feet underneath (self adhesive). Take out the four philips screws. It's a bit of a mess inside - you'll have to remove the connectors and some screws to get to the i-pod connector. You dont need to remove the button pcbs just the main board. The i-pod connector pcb is on the end of the grey ribbon cable connected to the main board (the button end of the unit).
Nov 22, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
PHILLIPS HTD 7001 IPOD DOCKING STATION
I also have the same problem but now I think it's the type of I-Pod you use. Do you use the I-Pod 80 Gb video or the newer 160 Gb I-Pod with the cover flow etc. ? The documention of the HTD7001 says it's only support some I-Pods. I would know sure if I would have a type of Video I Pod wich is supported by the documentation
May 31, 2008 | Bose 3 2 1 Series I DVD Home Entertainment...
I-pod shuffle copatibility with car stereo
No, The iPod Shuffle only transmits Audio, not data.
May 21, 2008 | Apple iPod shuffle Second Gen. Silver (1...
Accurian 2336 i-pod dock
try to go to this site though and download this.
www.apple.com/ipod/start
this is an Itune start installer. hope it will help you.
Jan 05, 2008 | Audio Players & Recorders
Sony ICF-C1IP (Black) Docking Station Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
