Question about Canon imagePROGRAF W7200 InkJet Printer
Error e02506 no bk ink tank, but there is one in it
3 Suggested Answers
ariyoso
  • 145 Answers
SOURCE: ip4500 keeps giving error message
u can try to press and hold the reset button several minutes untill the printers react again
Posted on Jun 08, 2009
TerryTown
  • 292 Answers
SOURCE: Describe your pixma mg5220 error
Thank you for contacting FixYa with your inquiry.
Canon has excellent support for missing items and or parts broken in shipment. You can contact them at the following:
Support by Phone Support Home
spacer.gif Canon Customer Support Center Hours: Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays Phone: 1-800-OK-CANON (toll free)
1-800-652-2666 TDD: 1-866-251-3752 (toll free) Email: carecenter@cits.canon.com For additional support options: www.canontechsupport.com
Canon is a wonderful steward for taking ownership of their customer concerns with products. Contact them & they will ship out your missing BK ink Tank.
Kind regards,
TF
Posted on Jul 29, 2011
Canon W8400 E02804
Check x Tank (the ink color is indicated by x)
This is displayed when an incorrect ink tank is installed.
The final digit indicates the ink color.
So you have problem with Bk ink tank...
This is displayed when installation of an incorrect ink tank is detected.
This is displayed when a checksum error occurs in the ink tank EEPROM.
Ink tank, ink tank unit, engine controller, system controller
1. Replace the ink tank.
2. Replace the ink tank unit.
3. Cable connection check
Replace the cable between the ink tank unit and engine controller if the connection is not functioning normally.
4. Replace the engine controller.
5. Replace the system control
So as you can see there is a lot of possibillities, ... call service
Aug 08, 2011 | Canon imagePROGRAF W6400 InkJet Printer
My printer says UO52 after I loaded new CLI-BK cartridge? I did not touch the print head.
U052 is the error code for a bad printhead, not a bad ink tank, so that is a little odd. First try another ink tank, even your old one. Are you using refilled ink tanks? I see a lot of odd problems with refilled ink.
If a new tank doesn't work, you need a new printhead. It is user replaceable.
Sep 20, 2010 | Canon MP610 Photo All-In-One Printer
I have a message showing bk tank - code
Its detecting an incorrect ink tank.
The printer is not happy with one of your tanks. Make sure you have PB inks if it is a PG printer.
More probably the job you are printing requires the other black ink tank. Very important to make sure your status monitor is installed correctly, make sure when you send a job that it displays the ink tank levels and not question marks. You should be able to find out roughly how much ink is left through the driver (status monitor) and also what type of black is installed. If you cant, you have not got the 'Status Monitor' installed.
Mar 09, 2010 | Canon imagePROGRAF W6400 InkJet Printer
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Feb 22, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
5 bk was low. changed it now light does not even come on. alarm light blinking, can't do anything. other inks are good but flashing
are u sure have reset your ink tank.... please go to print properties ->click maintenance->click ink counter reset->check colour box an reset.
Sep 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Error U071 ;more than one ink tank for black
your chip may get something wrong if the sensor is dirty or some ink goes over it!try to pull out the Bk carige and put it back again if not help try same but get some tishue and clean up the chip contact serfice!
Aug 24, 2009 | Canon Pixma MP500 All-In-One InkJet...
Not recognising ink tank
This is problem with the Bad chip on the ink tank ,Check with new fresh one if it works ok Ask Cannon to replace the damaged ink tank.We had faced many OEM chip with fault
thank you
Feb 17, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Black ink clogged
Did you use generic ink? The generic ink has the wrong ink filled in which destroys the ph!
brother printers must be run with dye-ink and special additives. Those additives are always missing within the generic carts!
Do use a original brother ink cart, make sure ALL carts are full with ink, placed well and are secured! Run the following procedure afterwards:
press menu then start bk copy then fourtimes arrow up (tel-index). machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will refresh ink
within tubes and ph and do some special cleaning procedures. When finished press 7 then 6 then 3 then start bk copy. machine will run a powerpurge.
When finished press 9 then 9 to leave the maintenance mode.
Print a quality test print by pressing ink Management etc.
If there is no BK afterwards the ph is defenitly clogged and cant be fixed anymore!
Dec 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon imagePROGRAF W7200 InkJet Printer Logo
88 people viewed this question
old marine
old marine
