Question about Sony Video Game Consoles & Games
Online multiplayer for god of war
Redeem code
Xestrix
  • 51 Answers
SOURCE: god of war II
Try this youtube walkthrough :)
Posted on Feb 17, 2009
  • 10 Answers
SOURCE: god of war 2 red orb chaet code
u can get the cheat of god of war 2 here http://faqs.ign.com/articles/772/772645p1.html
Posted on Feb 27, 2009
Jmizpah777
  • 290 Answers
SOURCE: God of War 1 and 2(Unable to read disc)!
Check your cd if it can play in different ps2 consoles. if it can, then theres nothing wrong with the cd.
probably your game console has problems on disk reading.
FIX Those Ps2 disk errors.
You're going to be surprised when you find out how easy this is. Read the instructions all the way through before you attempt the repair just so you'll be familiar with the entire process. First take off the outer cover of you PS2. If you haven't done this before, you will have to remove all the screw covers from the bottom of the unit, both plastic and rubber, these will be the only screws you will have to remove in order to take off the outer cover.
To remove the outer cover, lift up from the rear of the unit and pull towards the front in order to clear the controller jacks and the eject/close buttons. As you remove the outer cover you will notice a small metallic ribbon cable inside the machine leading to the eject/close and reset buttons on the front of the unit, this cable is usually taped to the top of the disc tray. This cable is not a sensitive as it appears; just remove the tape holding the ribbon cable. Once the outer cover is off you need to remove the cover to the disc tray, this will require a rather small phillips screwdriver (I've seen a few that use a standard slotted screw). Now that the tray cover is off, the first thing to do is to clean the laser eye. All you will need is a Q-Tip dipped in alcohol. Just swab the eye a few times and allow it to dry on its own, making sure that no lint was left behind from the Q-Tip.
After the cover is off of the disk tray and the laser has been cleaned you will need to plug the unit back in, (The unit needs to be hooked up to a TV as well to test it while you have it open. You should have a DVD, a game disk with a silver or gold back and one with a purple back in order to fine tune the system to play all three.) It will be necessary to have the unit powered up to perform the repair. Press the eject button so that the tray slides forward exposing the undercarriage. At the back of the unit you should see a small white, geared wheel about the size of a quarter. This little bastard is the cause of all your problems.
This wheel changes the angle in which the disk is held. You will notice that there is a small metal tab that holds the wheel in place. Take a felt-tip marker and mark the point on the wheel that meets the tab. That way you will always know the original position that the wheel was in. Now that the orig. position has been marked, feel free to spin the wheel for a few full rotations in order to see how it changes the angle. It will only alter the angle a few degrees before it goes back to zero, after it reaches the maximum angle it will go back to flat after each full rotation. Once you've toyed with it to see how it works, put the wheel back to the original position that you have marked. Then advance the wheel about 1/8 of a turn and place the disk tray cover back on top of the disk tray. (You will not need to screw the tray cover back down in order to test the machine; you will only need to hold down the cover with your fingers while trying to load/test a disk) Now place a DVD in the tray and press the eject/close button in order to close the tray and load the DVD (hold down the cover as explained above). Wait to see if the DVD loads, you may have to use the browser in order to load each disk you test. If the DVD loads, eject it and load a silver backed disk, if that loads try a purple backed disk. If all three loaded successfully, congratulations you're finished. If not, remove the tray cover, eject the disk and advance the wheel another 1/8 turn and repeat the process. It just a matter of finding an angle that will facilitate the operation of all three types of disks. Once you've found the proper angle and the system is operating to its full potential, close it up and let'er rip. I also do not recommend placing the PS2 on its side once you have fixed it. Although Sony says they recommend it in the owner manual, I have since seen internal Sony documents retracting the statement and attributing many malfunctions to storing and operating the unit on its side. Keep it flat at all times.
well. i hope this works.
pm me if problems continue.
Posted on Aug 08, 2009
  • 51 Answers
SOURCE: dive not working in god of war psp
just make sure you are using the right combinatio of buttons, check game controllers
Posted on Aug 20, 2009
Dajuliehubby
  • 203 Answers
SOURCE: play staion 2 reads all games but wont read god of war 1 and 2
Best bet is to try a laser lens cleaner and seeing if that helps. I know it sounds silly that it might be dust on the lens when only THOSE games don't work, but stranger things have happened.
Posted on Jul 30, 2010
Storm8 World War is stuck on small screen help
Massively Multiplayer ONLINE War Game! Join over 2.8 million players!It's the year 2020. A nuclear war has broken out. Most countries in the world have fought and many have been vanquished. 5 countries have emerged as the major superpowers in the devastating war. Which one will you be?
Start as a general defending your base from the enemy and fight to become the dominant military presence in the world as you march your way to victory in World War.
Jul 28, 2012 | Storm8 World Warâ„¢
I need god of war ghost of sparta pc cd key
i need God Of War Ghost Of Sparta PC cd key can any one help ne please
Apr 04, 2012 | Video Game Consoles & Games
My kids world at war for his xbox 360 will no longer let him play multiplayer or zombies even though he is connected to xbox live. It has him back at level one and the choices under which one to play on...
I have heard of this happening before. You are reset to level 1 with negative XP and this stops you from playing online. Your only option is to contact Activision and possibly Microsoft.
Click here for Activision support
I have read that the companies like to blame each other for the problem. So, when you call Activision, make sure they help you or speak to a supervisor if necessary.
Regards,
G33k
May 09, 2011 | Activision Call of Duty: World At War for...
Hey i was playing nazi zombie and i ended upp with a group one off the guuy in my group did somehing i dont know what i did but i think its hack and i was in level7 but when i had quit that group i was in...
Unfortunately, in Call of Duty: World at War, some people decide to be jerks and do this to others just so that they cannot play multiplayer, kind of like pointless computer malware that just hurts your system, with not even any gain to the person that made it.
The only way to play multiplayer again is either to make a new account, or have someone hack you back to level 1 with positive XP. You can search online and talk to some people, and they may be willing to help you, or you could also try doing it yourself.
Apr 20, 2011 | Activision Call of Duty: World At War for...
What is the pass code of compiler of god of war 2 pc?
Hello, Kindly download the software here to get the code: http://www.elvinmiradi.com/topik/download+rar+compiler+passcode+for+god+of+war+2+pc+software+msi.html
Jan 19, 2011 | Sony God of War 2
Can't play multi-player in call of duty
For COD5 on the wii, there is no split screen or local (in your room) multiplayer. Only online multiplayer and co op in the single player campaign.
Jan 11, 2009 | Nintendo Call of Duty: World at War for ...
Video Game Consoles & Games Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
