Question about Tappan Ovens
Timer keeps buzzing
Model 12-1063-30
I have just baught a second hand belling double oven cooker, we have switched it on and the timer is constantly buzzing! And the top oven and grill don't work! Any ideas on wot could b wrong?
The timer has been set and the cooking time is finished. That is why it is buzzing and the oven is in a turned off state. You need to acknowledge the cooking time finished, and set the oven back to Manual operation from Automatic. In the old days you pressed one of the buttons by the clock that was used to set. I used to have a Belling Double Oven in the UK, but I can't remember about the timer.
Google
make model manual
Google
Dec 19, 2016 | Belling Ovens
How do you clear Clock/Timer on a 1-year-old Viking Electric oven (Model # VESO1302SS)?
PDF]Viking Use & Care Manual
www.vikingrange.com/MEDIA.../m3500217_F20669.pdf
Viking RangeClocks and Timers ... the potential risk of fire, electric shock, personal injury or damage to the appliance as a result ... NEVER use aluminum foil to cover oven racks or oven bottom. ... Keep area around appliance clear and free from combustible materials, .... 1. Push and hold the "MIN/SEC TIMER" and "BAKE TIME" buttons.
Nov 26, 2015 | Viking Ovens
A SMALL BUZZING IS GOING ON AND CANT SHUT IT OFF ALSO OVEN HASENT BEEN USED IN YEARS TURNED ELECTRIC OFF BUZZING WENT OFF
Check to see if there is a switch for an open or not properly closed oven door. Could be stuck in the wrong position.
Nov 09, 2015 | Ovens
My electrolux EOU43002X oven bottom fan recently stopped. it also coincided with a buzzing from the timer panel. I replaced fan motor but timer wont work and the buzz still there when the timers tried
According to the convection fan which does not work, I suggest checking the main oven selector, wiring and convection fan.
According to the timer you should first set the time and then verify the correctness the timer relay. If relay is open than completely oven will not work.
Dado
Sep 08, 2015 | Electrolux Ovens
Why does Model CM301 timer buzz randomly?
it has a bad motor in the timer/clock or a noisy transformer.
May 18, 2014 | Thermador Ovens
My daughter turned the timer but when it got to zero and it buzzed....it never stopped buzzing. It is still buzzing 10 hrs now! What can I do?
unplug your oven. sounds like you need a new timer. the relay is not releasing . cause the timer wont let it
Jun 19, 2011 | Kenmore Ovens
AEG single oven - clock runs for 12 hrs , buzzes and goes back to 12 o'clock - if set timer and check time remaining, it buzzes and jumps to clock setting loosing time remaining. Buzzer sounds ''hoarse''.
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
Jul 17, 2010 | AEG B2100-4 Electric Single Oven
Zanussi oven timer buzzes at 20.00 then resets to 12.00
Gave up and bought a new timer module for £66 from espares. Timer board has microscopic components so even if you knew what was wrong it wouldn't be fixable.
Sep 22, 2009 | Zanussi ZBF360 Electric Single Oven
Zanussi Built-In Oven Clock keeps resetting?
The 1000uF/10V condensator in the timer unit has to be replaced.
Sep 29, 2008 | Zanussi ZBF360 Electric Single Oven
Ovens Logo
24 people viewed this question
Top Tappan Ovens Experts
Dan Webster
Dan Webster
ashburton
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Tappan Oven Expert? Answer questions, earn points and help others
