Question about Franke PF3000 Deck Mounted Pot Filler Faucet with Two Valves: Polished ....
Sign the crab pot filler deck mount faucet leaking at swivel, how to take apart to change washer
I have to get swivel apart at the joint and am having a difficult time should i just force it apart or is there a trick to it
2 Suggested Answers
  • 171 Answers
SOURCE: Installing a Pot Filler
Hi 13Kat,
I'm Harvey the Master Plumber.
You must connect to a flanged fitting behind the wall. The wall is sandwiched between the flange behind and the escutchen in front that holds the pot filler in place. These are usually installed on stainless steel sinks that have stainless steel back walls and do not come supplied with the flanged fitting, available at any plumbing supply.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 15, 2008
Delta T2738 Deck Mount on Jacuzzi Tub. Hot Water side leaking.
With the detailed part number you have, I would just walk into stores like Home Depot or any plumbing store and they will give you the exact parts you need. They are not expensive and a lot of them are standard parts and come in kits.
Good luck.
Apr 08, 2013 | Delta T2738 Lahara Deck-Mount Two-Handle...
Tip
Diagram-Type Faucets
DIAPHRAGM-TYPE FAUCETS
  • The diaphragm faucet is washerless but is similar to washer-type faucets. A rubber diaphragm between the stem and seat creates a straight-down, frictionless close. As with washer-type faucets, diaphragm faucets have two handles.
  • Remove the stem by following the steps outlined for washer-type faucets. Instead of a washer on the end of the stem, you'll find a swiveling disc. If the rubber diaphragm doesn't come out with the stem, it is still inside the faucet.
  • If the diaphragm didn't come out with the stem, use pliers to peel it from inside the faucet and pull it out. Install a new diaphragm around the swiveling disc, then replace the stem in the faucet.
  • If the faucet is leaking around the stem, replace the stem's O-ring before reinstalling the stem.
on Jan 16, 2010 | Plumbing
Tip
How to repair a washer-type faucet
REPAIRING A LEAKY WASHER-TYPE FAUCET
  • Washer-type faucets work with a rubber or composition washer that closes onto a metal washer seat (Fig. 1). The washer can become hardened, worn or the seat wears, causing the faucet to leak. You can close the faucet tighter to stop the leaking temporarily, but this increases the internal damage to the faucet.
  • To repair the leak, first turn off the water. If there's a shutoff valve beneath the fixture, turn off the water at that point. Otherwise, turn it off at the main house shutoff valve in the basement, utility room, or crawlspace. Turn off the hot water supply at the water heater.
  • Take the faucet apart by removing the handle (this may not be necessary on some older faucets). Loosen the Phillips-head screw, which usually is beneath a decorative cap in the center of the handle. The cap either unscrews or snaps off when you pry it with a knife blade. If you must use pliers on decorative faucet parts, pad them with electrical tape or cloth to protect the finish. And take special care with the plastic parts found on many modern faucets. Next, lift or pry the handle off its broached stem. Unscrew the packing nut beneath the handle, exposing the rest of the stem. Remove the stem by rotating it in the "on" direction. It will thread out. Reinstall the handle if you have difficulty turning it (Fig. 1). Clean chips from the faucet cavity, but do not use harsh abrasives or a file.
  • Examine the stem. If the threads are badly corroded or worn, take it to your retailer and get a new stem to match. Clean the stem if it's dirty.
  • Now look at the washer, which is located on the lower end of the stem and held in place by a brass screw. If the washer is squeezed flat or has a groove worn in it, replace it–this should stop any dripping. Take the washer with you to your dealer to ensure an exact match in size and style. If the brass screw is damaged, too, replace it with a new brass screw.
  • The washer seat is located inside the faucet body. You probably can't determine if the washer seat is causing the leak just by looking at it. Any faucet that needs frequent washer replacement obviously has a damaged seat. The seat should either be refaced with a seat-dressing tool. A seat-dressing tool is not costly. Every home with washer-type faucets needs one. Use the tool according to the manufacturer's directions, placing it in the faucet along with the packing nut. Then rotate (Fig. 2) until the seat is smooth, and blow out the chips.
  • Some washer seats can be unthreaded and replaced. Check the faucet body with a flashlight to see if it has a square or hexagonal hole through its center or is slotted for a screwdriver; if so, it is replaceable. However, if the seat simply has a round hole through its center and no slots, it is not replaceable. In this case, dress it with a seat-dressing tool. To replace it, you'll need a faucet seat wrench, which comes with a combination of square and hex heads to fit most faucet seats. Turn the washer seat counterclockwise to loosen, clockwise to tighten (Fig. 3). Add a little silicone rubber sealant (RTV) or pipe joint compound around the threads of the seat before you install it to make it easier to remove during future repairs.
  • It's important to install the correct type of faucet washer (Fig. 1, bottom). A swiveling washer (C) is preferable to either (A) or (B). To install washer style (C), file the shoulder off the end of the stem, drill out the threads of the screw hole. Instead of rubbing against the seat as it closes, a swiveling washer closes with a straight-down, frictionless action – this allows it to outlast fixed washers.
  • Following this seat and washer service, your faucet should be like new. Put the parts back together in the reverse order of taking them apart. Spread a bit of petroleum jelly or silicone grease on the threads of the stem to lubricate the faucet's action.
  • If the faucet leaks around the stem rather than from the spigot, install new packing. You may want to install one of the newer nylon-covered or graphite-impregnated packings–their lubrication allows the faucet handle to turn more freely. Wrap one turn of this packing around the stem just beneath the packing nut (Fig. 1). Use three complete wraps if you're applying string-type packing. Some stems use O-rings, rather than packing. For these stems, replace the O-ring with a matching one to stop a leak. Hand tighten the packing nut, then tighten it another half-turn.
Price pfister kitchen faucet spot leaking at joint
They are wrong. There is no O-Ring at the swivel joint and it is NOT serviceable.
May 20, 2012 | Price Pfister Plumbing
Just installed and is leaking from faucet body at joints.
If you used sealer (teflon tape) it shouldn't be leaking where the water hoses connect, unless it is still loose. If the faucet leaks water from ANYWHERE else (handles, swivel neck, spout) you have a bad faucet.
I would suggest if this is the case to replace the unit. Otherwise, remove your hoses and put pipe tape on the threads where the hoses connect, then reconnect the hoses, and tighten them down-don't strip the threads or break the connection. If it is a new faucet, it shouldn't leak anywhere when properly installed.
Hope this helps.
Dec 10, 2009 | Rohl A1676LPAPC Single Hole C-Spout...
Hi, I have a Franke FF600 with a serious low flow problem. Thanks
The undersink flow restrictor, attached at the end of the flexible "hose", was clogged. Verified this problem with Franke USA. In support of their product they are sending out a replacement flow restrictor for FREE!
Aug 25, 2009 | Franke PF3000Series Deck Mounted Pot...
What advantage(s) does a two-valved potfiller faucet have over a one-valve (if any)??
no real advantage, just your prefferance really. but i find with the two valve it's harder to acidentaly turn it on, as you have two stops.
Aug 12, 2009 | Franke PF3000Series Deck Mounted Pot...
Grohe pot filler
Here is the link to the install manual for your pot filler... http://www.frankeksd.com/grfx/pdf_files/installs/PF3000.pdf
It mentions 'cold water only' in several places, but also mentions maximum hot water temp of 175, which is hotter than most hot water heaters (140-150), so I don't think (without being an authorized factory rep) that your hot water temp will hurt it... keep on keepin on... always wanted one of these for myself...
Oct 26, 2008 | Franke PF3000 Deck Mounted Pot Filler...
Hi 13Kat,
Thank you,
Oct 06, 2008 | Franke PF3000 Deck Mounted Pot Filler...
Franke PF3000 Deck Mounted Pot Filler Faucet with Two Valves: Polished .... Logo
37 people viewed this question
Top Franke Plumbing Experts
Donni Steen
ray gallant
William Wurtinger
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
