Question about Freezers
United commercial heavy duty freezer
The buzzer started buzzing last night. Is it low on coolant?
  • 833 Answers
SOURCE: Can my kenmore chest freezer be in the garage during hot summers and cold winters in Minnesota?
Jeremy,
You can put a fridge/freezer in the garage. Be sure that the area is level so you don't warp the case which will cause sealing problems with the gasket. Also, clean the condenser frequently as dust and dirt will reduce efficiency.
Posted on Dec 04, 2007
SOURCE: whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Posted on Jul 04, 2009
victorwod
  • 157 Answers
SOURCE: I have lost my turnkey for an Imperial Upright
you can visit the website of the company and make a request for the key or get the door forced it to get open and get a new locker key for it.
Posted on Feb 20, 2010
SOURCE: I have a Superior heavy duty commercial upright
I have a superior hd freezer it is working but the out side sides get very hot any idea
Posted on Jun 09, 2010
  • 1531 Answers
SOURCE: We have an upright Commercial Grade heavy duty
the suction noise is not something that will happen all the time.
check the current draw on the compressor and make sure it is in between 1.2 and 1.6 amps.also look at you evaporator coils and make sure there is no excessive frost build up.If there is ice build up then you need to defrost it check the heating element and defrost timer and make sure they are in proper working order.also check the evaporator fan and make sure it is working when the unit is in a cooling mode.
Posted on Sep 08, 2010
Our old Imperial heavy duty commercial model uf20x needs seal. Where to find it?
Commercial refrigerator parts supplier can make it same day. Check google for your nearest supplier.
Feb 01, 2014 | True 72 cu. ft. / 2039 liter Commercial...
Freezer Controls
Cold, Colder, B-r-r-r
Nov 23, 2013 | Freezers
I have a small magic chef freezer that opens from the top. I has about 3 or 4 cu. ft. of freezer space. Lately a buzzer has been going off every 15 or 20 minutes. It buzzes for about 5-10 seconds and then...
With the time as the compressor gets old the buzzing will increased, its not a bid deal, just set the thermostat to 1 during the winter, saves you energy and give the compressor more time to rest.
Sep 28, 2011 | Magic Chef Chest Freezer MCCF5WBX
I have lost my turnkey for an Imperial Upright heavy duty Commercial Freezer. It is locked and I have no way of getting inside... Where can I get one?
Feb 16, 2010 | Amana 19.7 cu. ft. / 558 liter Upright...
I have a Superior heavy duty commercial upright freezer that has stopped freezing. It gets cold but doesn't freeze. Is there a reset button on it? The compressor comes on but it's not getting cold enough...
Check if the condensing coil(the one by the compressor) is clog with dirt or grease ,if yes unplugged and clean it real good with a degreaser , also make sure the fan works , if all this is ok and you see the coil inside is partially frozed up ,could be that is low in refrigerant what means there's a leak that has to be fixed before recharge the unit.
Oct 06, 2009 | Freezers
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
59 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
