Question about Thermaltake Liquid Cooling System Bigwater UV Sensitive Coolant - liquid cooling system fluid (S7430417)
Northstar engine coolant flow diagram
1996 Seville Cadillac overheating. we just put a thermostat in. we checked the purge line. it was cloged. we blew threw it uncloged it. then in like two min it went back to overheating. I need your help please. thank you.
    New Friend:
  • 127 Answers
Replace That Peice Of Junk no Offence With A New Kia Sedona ! Kia Is The Best Trust Me !
Posted on Feb 18, 2014
My 1995 cadillac seville sts is over heating i flushed system put in new radiator new cap new thermostat new hoses new pump new fluid there is no leaks i dont understand
The most common overheating problem with the Northstar engine is a blocked purge line(small hose).The purge line is designed to purge air out of the cooling system.
There is a small diameter hose coming from near the top of the coolant tank (not the cap) ,this is the purge line.
With the engine idling,pull the purge line from the tank,if there is no coolant flow from this small hose,it is blocked and this will cause overheating.
If the hose is clear, check for blockage at the nipple on the tank.Or trace the hose back until you find the blockage.
The hose goes in to the engine to a crossover and comes out the other side close to the thermostat housing,the blockage may be there.
Jun 14, 2010 | 1998 Cadillac DeVille
Overheating problem on 9 deville, can be fixed or
You have not given any details but consider the following:-
With the engine idling,pull the purge line from the tank,if there is no coolant flow from this small hose,it is blocked and this will cause overheating.If the hose is clear, check for blockage at the nipple on the tank.Or trace the hose back until you find the blockage.The hose goes in to the engine to a crossover and comes out the other side to near the thermostat housing,the blockage may be there.
Apr 12, 2010 | 1996 Cadillac Seville CA Value
HOW DO YOU CAHNGE THE THERMOSTAT ON 2002 CADILLAC DEVILLE
The most common overheating problem with the Northstar engine is a blocked purge line. It's job is to purge air out of the cooling system.
There is a small diameter hose coming from near the top of the coolant tank,this is the purge line.
Jan 28, 2010 | 2002 Cadillac Deville
MY 1999 SEVILLE STS IS BLOWING COLD AIR EVEN WITH COOLANT FULL. HOW DO I KNOW IF IT IS THE THERMOSTANT OR HEATER CORE. THE CAR RUNS HOT.
Jan 23, 2010 | 1998 Cadillac Seville
Engine is running hot on 1995 Cadillac Seville. Is it the thermostat or the water pump?
With the engine idling,pull the purge line from the tank,if there is no coolant flow from this small hose,it is blocked and this will cause overheating.If the hose is clear, check for blockage at the nipple on the tank.Or trace the hose back until you find the blockage.The hose goes in to the engine to a crossover and comes out the other side which leads to the thermostat housing,the blockage may be there.
Dec 18, 2009 | 1995 Cadillac Seville
My 1996 cadillac sts is overheating.. ook how do i get air out of it
There is no need to purge the air out of the cooling system as it is self purging on the northstar engine.
With the engine idling,pull the purge line from the tank,if there is no coolant flow from this small hose,it is blocked and this will cause overheating.If the hose is clear, check for blockage at the nipple on the tank or trace the hose further back until you locate the blockage.
Oct 21, 2009 | 1996 Cadillac Seville CA Value
II have a 98 deville changed thermostat 3 months ago,started overheating yesterday after i checked my coolant level
Oct 06, 2009 | 1998 Cadillac Seville
1996 Cadillac Deville- running hot
is the water pump, belt and tensioner OK? its not where you think it is. its on the drivers side of the front cylinder head.
Oct 03, 2009 | 1996 Cadillac DeVille
I need a cadillac seville sts 1998 4.3L & 32
Check for coolant flow at the Purge line,this is a common problem on the Northstar.
Oct 01, 2009 | 1998 Cadillac Seville
96 cadillac deville overheating
Aug 13, 2009 | 1996 Cadillac DeVille
Thermaltake Liquid Cooling System Bigwater UV Sensitive Coolant - liquid cooling system fluid (S7430417) Logo
461 people viewed this question
Top Thermaltake Computers & Internet Experts
Martin Clarke
Martin Clarke
Lawrence Oravetz
Are you a Thermaltake Computer and Internet Expert? Answer questions, earn points and help others
