Question about Singer 7462 Mechanical Sewing Machine
How to wind a bobin - Singer 7462 Mechanical Sewing Machine
Bobin not feeding properly.
I don't know what machine you're using but I thought that there should only be one thread coming from the bobbin. Have you removed it and checked the winding?
Jul 08, 2015 | Sewing Machines
How do i rethread the bobin
You have to get the machine to switch its gear to wind the bobbin instead of sewing( needle up and down). There are two ways most machines do this...on older or simpler machines you pop the wheel that makes the needle go up and down ( right side of the machine) either in or out! There may be a round knob in the center that pops in or out... Other machines make you move the rod that the bobbin sits on for winding move or swing to engage the gear. There should be a path for it to slide along if that is what your machine does. Good luck!
Jul 07, 2015 | Sewing Machines
I can't seem to wind a bobbin. I've done everything in the manual but it just seizes up- doesn't spin.
you placed the bobin upside down
one side is flat the other is keyed
so place the keyed side down
usual fault with winders
bobins are easy... read again the manual slowly
Jun 04, 2015 | Singer 57815 Mechanical Sewing Machine
Bobin thread is loose
As you are winding the thread onto the bobbin, grasp it between your fingers ever so lightly to give it a little drag so it spools up tighter.
Or just press the thread down against the top of the machine as it winds, anything to just help it spool up a little tighter.
Jul 20, 2014 | Elna Sewing Machines
Winding a bobin
That's how that machine works. You don't loosen the hand wheel or anything, Simply put the bobbin on the winder and go.
Mar 13, 2014 | Husqvarna Viking 1
Bobins
To "wind" a bobbin you can:
1 - Look in your book
2 - Google : how to thread a bobbin on a kenmore "12 stitch"
3 - Youtube https://www.youtube.com/watch?v=Fe11QQubfqw
4 - Ask a friend
To "make a bobin"
1 - Get some 0.5mm stainless steel
2 - Cut two 19mm circles out of the 0.5mm steel
3 - Drill a 6mm hole in the center of each circle
4 - Solder (silver solder work the best) the 2 circles together with a 6mm round by 9mm tall cylinder in between the two 19mm circular pieces.
The top thread is looping every 30 or 40 stitches on my Juki DDL 8700. I put in a fresh needle, cleaned thoroughly, fresh throat plate and re-threaded. Any ideas? Thank you!
hi there
please check bobin case spring maybe need t adjust or rplace.
please check if you are wind bobin by correct way not too much titght or not too much loose. thread insaid bobin must be littel soft.
the last reason maybe the tip of stoper for hook id damaged and need to rplace.
best regards
ashraf abozid
aabozid@hotmail.com
Dec 01, 2010 | Juki DDL-8700
Toyota sewing machinge 5500
If I understand the problem, the bobin winder has probably lost a rubber 'o' ring.
Unscrew the two top screws and remove the top cover. At the base of the bobin spindle is a metal disk that should have a rubber 'o' ring on it. This will perish over time and break off.
When the bobin winder is pushed sideways into the active position, this should contact the main turning handle thingy (that's a technical term) and be spun around. Check if the bobin 'o' ring is making contact or if it is even there at all. Any sewing machine repair shop (or good automotive store if you're desperate) will have a replacement.
Oct 09, 2008 | Sewing Machines
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
15 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
