Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Lacie 160 external FW HD not copying
I am trying to copy files off of my 160Gb external FW hard drive to either my desktop (Powermac G4 OSX 10.4.1) or to another Lacie HD.  But it won't let me drag any files from it, anything I drag just bounces back. Ownership & Permissions in the "Get Info" on the drive says I can read and write.  Any other solutions?
Thanks,
Dave
david@townsendphotography.com
  • 1 more comment
  • datsnice Oct 28, 2007
    The same thing happens whether I try to copy 6GB over or just one 8MB file.  The file just bounces back when I drag it over.  That's what leads me to believe it is a problem with permissions on the drive.  I'll try to repair permissions with Disk Utility and see if that does the trick...
    Any other suggestions appreciated!
    Dave
    I did check the admin abilities under "GET INFO" and the Ownership drop down menu is different than on my other drives.  I can't change the owner option, and it only says I have ability to read and write.  I also noticed the disk is formatted to MS-DOS (FAT32). Does that have anything to do with it?
    Should I try to repair permissions in Disk Utility?
    Can you tell me the other 2 possibilities in your next post please?  thanks!
    I'll just tried plugging the drive into my laptop G4, ans while the Ownsership settings are the same, I AM ABLE to copy from the drive.  So it must be issue with settings on my computer, not the drive.
    Novelist:
    Champion:
  • 382 Answers
How much are you attempting to copy at once?
Posted on Oct 28, 2007
  • 2 more comments
  • Keith Seekwhensir
    Keith Seekwhensir Oct 28, 2007
    Click on the drive once, go up top to the file menu and choose FILE/GET INFO.
    Go to the bottom of that pop up menu/dialog box and see if you have admin abilities to both read and write to the drive..
    And also verify that on all external drives, you are the owner ( your user name will appear next to owner )
    If that's all good and proper, try holding down the OPTION key when you select and drag.
    There are 2 other possiblities, so let me know.
  • Keith Seekwhensir
    Open Disk utility, repair permissions on the volume..the difference is, when you open disk utility, you will see all drives on the left pane. Each item will have the drive name ( on top ) and the volume name ( on bottom and indented ) repair permissions on both. It appears like you are editing video...if thats the case I would stray clear from the affordable but you get what you pay for LACIE PORSCHE..inferior bridge board, does not have an appropriate chipset, and is considered consumer at best.
    Check the SMART status of the drive. Now keep in mind MS-DOS formatted drive shave a file size limit of 4GB...so you cannot trANSFER files that large or larger off the drive while its formatted in that type.
    keep me posted..
  • Keith Seekwhensir
    in the photo you provided, it doesn't appear that you info window has the DETAILS option.
    You should go to
    Software update and go for the update, or google search " 10.4.9 combo update ".
    It will allow the OS and Admin to have more control over parameters.
    Keep me posted..
  • Keith Seekwhensir
    LOOK for ACCESS
Lacie d2 Quadra Ejects Itself
I've had issues with the lacie mini power supply before. I can cause some wierd issues. Unfortunately, it isn't the cheapest thing to replace but that's probably the best place to look first.
Oct 16, 2012 | LaCie 1TB D2 Quadra eSATA/USB 2.0/FireWire...
I got an iomega 300 gb hard drive.When i connect it to my computer i can't access it coz it asks me to format the drive,only then can i access it and formatting the drive removes all the data in it.what to...
Try to acces HD with paragon hard disk manager resque disk (you must boot from this cd). You have an option there to copy files. Backup all your files if you see them and format hard drive then copy all your data back. It works several times for me.
Mar 18, 2011 | Iomega 160GB Ego HD USB 2.0/FW Red 160 GB...
Transferring software and files from PowerPC G3 to PowerMac G4
to mount somthing in a mac is basicly cutting it on for use.
For example if you instal a flash drive or an hard drive via an out side connection, The mac will mount it so you can use it.
Aug 09, 2009 | Computers & Internet
I was copying a large amount of data - 65GB from the drive to a network drive and the USB cable was disconnected. After reconnecting some of the files sre on the network drive (~ 1/3) some are on the Lacie...
Your copy process was interrupted so you'll need to perform the entire operation again to ensure you have all of your data and to also make sure none of it is corrupted.
Jul 10, 2009 | LaCie 160GB Little Disk USB2/FW400 160 GB...
Using the 160GB passportHard drive
are there any errors that popped up while copying the music files? if not, then it probably works fine. the files are now stored on the harddrive.
if you want to safely unplug and carry the HD over to another computer, you can., the files should be accessible... that's all a harddive does.
Dec 29, 2008 | Western Digital Passport 160GB External...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
Firelite HD 160GB won't mount on PC
Try this site: http://sewelldirect.com/USBManualShareSwitch2To1.asp. Although you must purchase this "splitter", you can use the Hard drive on two different computers. CAREFUL! Make sure that only ONE computer is reading or writing to the same file at a time! If you have a crossover, the hard drive could crash!
Feb 01, 2008 | FireLite (USBFLB80) Hard Drive
Lacie 250GB changes date when copied
Unfortunately, when you copy a file, you are technically creating a new file hence it would assign the current day's date as the new date.
Jan 14, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
164 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
