Question about Inter-Tel Axxess Corded Phone
Having trouble setting up my voice mail greeting onmy eircom 7000 digital cordless phone
How to set up voice mail
Here are all the steps you will need. Good luck:
  1. From the Home screen, tap Phone .
  2. Tap Voicemail .
    You could be directed to the automated Voice Mail system at this time. If so, follow the voice prompts to set up your Voice Mail and greeting instead of completing the steps below.
  3. Tap Set Up Now.
  4. Enter a password then tap Done.
    The password must be between 4-6 digits in length.
  5. Re-enter the password then tap Done.
  6. Tap Custom to record a greeting.
    To use a Verizon default greeting, tap (check) Default.
  7. Tap Record to begin.
  8. When finished, tap Stop.
  9. Tap Save.
Apr 25, 2016 | Cell Phones
Set up voice mail
What model phone do you have and which carrier? For example, with a Verizon iphone 5 these are the steps:
    The Home screen is accessed by pressing the home button (located at the bottom of the device).
  2. Tap Voicemail
  3. Tap Set Up Now.
    If the 'Set Up Now' pop-up does not appear, your voice mail has already been set up. Simply tap Greeting in the upper-left of the voice mail screen and begin at step 6.
  9. Tap Save.
Apr 11, 2016 | Cell Phones
Voicemail setup
Enter the model of your VTech DECT 6.0 system into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Jan 27, 2014 | Vtech DECT 6.0 Digital Cordless Phone
Change voice mail greeting
Pick the model of your Uniden 5.8GHz system from the list beginning at http://www.uniden.com/owners-manuals/cordless-phones/scat/cordlessphones_mnl to download a copy of the manual.
Feb 16, 2013 | Uniden 5.8GHz Expandable Cordless Phone...
How do I set up the voice mail on the 5.8 vtech phone?
Set up the answering machine that came with your Vtech 5.8phone. To activate your voice mail, press the "Answer on/off" buttonat the base of the main cordless phone. Press "Setup" and then usethe arrows to set the number of rings before the answering machine picks up Press the "Announce" key on your Vtech 5.8 mainphone base to listen to the greeting that people hear when they call you. Press"Record" to record a new greeting and then press "Announce"to listen to the greeting.Press "Play" on your Vtech 5.8 main phonebase to listen to your voice messages. Press "Delete" to erasemessages.
Mar 11, 2011 | Vtech 5.8GHz Analog Cordless Phone
I want to put a greeting on my phone for voice mail purposes
Since you declined to specify the model of your Uniden cordless system I can only suggest you select it from the list beginning here to download a copy of the manual.
Nov 01, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Want to turn off voicemail Don't know codes
To turn off voice mail please dial ##002#, this would do the trick.
Regards
Oct 13, 2009 | RCA 25450 4-Line Extended Range Multi...
I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
May 18, 2009 | Nortel Business Series Terminal T7208 -...
Inter-Tel Axxess Corded Phone Logo
12 people viewed this question
Top Inter-Tel Lands Phones Experts
george  peters
george peters
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
