Question about Sharp Office Equipment & Supplies
I have a MX4110 with a Maintainence code of -FK3. What does it mean?
2 Suggested Answers
bschilz
  • 2049 Answers
SOURCE: I have a MX6200N with a Maintainence code of -FK3.
FK3 means that the fuser web cleaning counter has reached the specified limit. Replace the web and reset the counter.
If you are getting the FK3 message, get ready to do a PM. Those messages will be popping up soon.
Posted on Mar 10, 2010
Sharp error code fk3
If you wish to get some details about error code and printer repair
Then check the below added link.
http://electro-medical.blogspot.com/
Jul 07, 2016 | Sharp Office Equipment & Supplies
What does maintanence required FK3 means?
You will need to replace the web fuser cleaner
Feb 06, 2015 | Office Equipment & Supplies
E202-0002 what is problem
Check this link and the answer that they finally found was their problem - hopefully it helps you - Boots66
http://forums.usa.canon.com/t5/Printer-Multifunction-Support/Canon-MF4412-laser-printer-error-quot-turn-the-main-power-on/td-p/40847
ok guys finaly i have found reason for this .
FK3-1153-000---- CONTACT IMAGE SENSOR ASS\'Y , I mean to say this lamp and strip was faulty ,We have replaced it and
printer is now functional...
Aug 13, 2014 | Canon ImageClass MF4412 Toner Black Repl -...
MAINTENANCE CODE FX3
Should be FK3 ,this is only fusing maintenance display no worry
Mar 18, 2014 | Sharp MX-2700N Color Copier
What is error code FK3 on Sharp MX3501N
FK3 is the code for the cleaning web in the Fusing Unit.
Jul 30, 2012 | Sharp MX-2300N Color Copier
Translation for B 125 maintenance code
This fooled me for a little while, as I'm not familiar with the car. Actually what you are seeing is a maintainence message that tells you first, that you need to perform a maintainence type A or B.
Then it tells you what maintainence sub items you also need to perform.
So, what you are being told is perform maintainence B and perform sub items 1, 2 and 5
MAINTAINENCE A CHECKLIST:
Replace engine oil
MAINTAINENCE B CHECKLIST:
Replace engine oil and filter
Inspect front & rear brakes
Inspect parking brake & adjustment
Inspect Tie rod ends, steering box & boots
Inspect suspension components
Inspect Driveshaft boots
Inspect brake hoses and lines including ABS
Inspect All fluid levels and conditions of fluid
Inspect Exhaust system
Inspect Fuel lines & connections
SUB ITEMS CHECK LIST
1:
Rotate Tyres
2:
Replace air cleaner element (Every 15,000 miles in dusty conditions)
Replace dust & pollen filter (Urban areas with high concentrations of soot, replace every 15,00 miles)
Inspect Drive belt
3:
Replace Transmission Fluid
4:
Replace Spark plugs
Replace Timing Belt
Inspect Water Pump (V6 Engines only) - If regular extreme conditions over 110 degrees f or under -20 degrees F, replace every 60,000 miles
Inspect Valve Clearance
5:
Replace engine coolant
Aug 15, 2011 | 2006 Honda Accord
How do i clearn a maintenance code fk3 from a sharp 5001n
this is a web cleaner replacement which is cleared with p/# * c * then 2 4 copy start 4 copy start. press web cleaner button and execute. Note if the web cleaning web has run out (probably has) it will need to be replaced. machine can run without this for a while but the fuser could start leaving dirty marks.
Oct 14, 2010 | Sharp Office Equipment & Supplies
I have a MX6200N with a Maintainence code of -FK3. What does it mean?
Mar 10, 2010 | Sharp Office Equipment & Supplies
Service code
its a scheduled maintainence code it means replace the engine oil and rotate tyres
May 25, 2008 | 2007 Honda Pilot
71 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
