Question about RCA 25414RE3 Corded Phone
How to put RCA voice message machine on remotey
How to put voice mail on remotely
How do I stop the red message light from blinking after I have received my messages
~*~*~ SOLVED SOLVED SOLVED! ~*~*~ After talking to both ATT and RCA with no success...I figured it out. ~*~*~ Plug your phone line into the "DATA PORT" on the back of the unit. Slide the "DATA PORT" switch to whichever line is showing it has a message. Press the corresponding Line# button on the front of the phone. (you should hear the dial tone) Dial your voice mail number. Let it answer, (enter your passcode if needed), then hang up! - That's it! example: MSG Waiting:L2 - I plugged the phone line into the Data Port and moved the data port switch to "2". I pressed LINE 2 on the front of the phone, dialed my voice mail number, it answered, I put in my passcode. (It said that I did not have any new voice mails), then hung up! That's it! Message Indicator light off!!! Repeat for each line that shows a (false) message waiting. ~~~Don't forget to move your phone line back into it's correct port on the back of your phone.~~~
Jul 06, 2012 | RCA 25414RE3 Corded Phone
I have a RCA 2-line corded visys speakerphone model 25201 and I need to set up voice message but can not find any instruction.
And you won't. The model you listed is just a phone, it is not an answering machine. You either have voice mail as part of your phone service, or you have another RCA system phone that is acting as the voice mail machine.
Here's the manual http://www.rca4business.com/products/pc/pdf/instruction-book/25201RE1.pdf
Carl
Feb 28, 2011 | RCA 25201RE1 Corded Phone
Lost the manual and need to record a new voice mail message
to leave a voice mail message on the Samsung Prostar;
To enter voice mail, press the Voice Message Key, the pass code will be set in default to 0000. Your mailbox will not function properly until you have put your voice message on. To do this, press option 0, followed by 5 followed by 7. When you have got the message you require press the #. If you regularly change your voice-mail message, you must press 3, delete the original message and reset the message followed by the #.
I have loaded a video explaining VM, at www.abbeytelecom.com there are 64 videos which will help you with any other issues that may arise.
Jan 22, 2011 | Samsung Prostar DCS-24B-LCD Corded Phone
I need the code to get into voice mail remotey
To retrieve your voicemail messages remotely, wait for the automated attendant to answer the call then press ** your extension number then #.
Sep 22, 2010 | NorStar Startalk Flash 2 Phone
Redirect a caller to voice mail
1.goto phone menu.
2.goto setting.
3.goto callsetting.
4.goto divert call to voice mail
Jun 02, 2010 | RCA 25202RE3 Corded Phone
Indicator message light on handheld phones do not go off!!!
on the base set, press and hold the voice mail 1 button. You will get a message clear voice mail indication? hit the sel/save button to the left of the display.
poof! message gone
Apr 17, 2008 | RCA ViSYS 2-Line Speakerphone
Remote call forwarding/message retrieval; record voice mail message
i found my solution on the AT&T website.
thanks anyway.
Mar 31, 2008 | AT&T 950 Corded Phone
Voice Mail
There are two types of voice mail. One is from your local telephone provider and the othere is inside your phone system. Most telephone voice mail is signalled by a stuttered dial tone on the mail line. You would have to call the voicemail ( a local Phone number) and set up a password that will let you retrieve your messages. If this is what you have call your provider and they will tell you the number to call and give you your temporary password.
Jan 17, 2008 | RCA 25414RE3 Corded Phone
Voice mail
An alternative to this problem, i've got ...possibly its a COMCAST feature..
Call your own number which will activate the ansering option for COMCAST and then u can read ur messages. This will ge the NEW VOICE MAIL message off ur handset.
In that case i find the answering machine of the phone useless and shouldnt have put money for the same.
Dec 16, 2007 | GE 25952 Cordless Phone
Remote Access
When you call in from the outside wait for auto attendant to answer. As soon as the "Thank you for calling" starts, press [*], and your mailbox number. If that does not work you may need to put a [#], 165 before the [*], mail box. This is assuming that most voice mail and auto attendant settings are operational and you have a Panasonic KX-TVS voice mail.
If a live person (not to be confused with the living dead) answers, have them transfer you to voice mail and do the whole [#], 165, [*], your mail box thing.
Dec 05, 2007 | Panasonic KX-T7453 Corded Phone
Lands Phones Logo
15 people viewed this question
Top RCA Lands Phones Experts
Are you a RCA Lands Phone Expert? Answer questions, earn points and help others
