Question about Carrier Humidifiers
Carrier 49BG013200 Humidifier - Carrier Humidifiers
I need a replacement part for humidifier, model#HUMCCLBP2317-A, part is a "Scale control insert"
Here is a link for the part you are looking for:
http://www.searspartsdirect.com/partsdirect/part-model/Carrier-Parts/Humidifier-Parts/Model-HUMCCLBP2317A/3079/0913000/50027453/00001?blt=06&prst=&shdMod=
Oct 21, 2014 | Carrier Humidifiers
Humidifier Running Continuously with Fan Blower
As long as the humidifier start/stop is regulated by air flow there is no way to cycle it on/off with another device. If, however you disconnect that capability and, instead wire it to the heat on cool on switch it will only turn on when the stat calls for heating or cooling. You may need to install an intermediate relay off the stat wires to regulate the different(assuming that they are) voltage of the humidifier start/stop.What a fun project, thanks!
Jan 22, 2013 | Humidifiers
My carrier humidifier has a hose which drains into the laundry sink and a lot of water is coming out. Should this happen in winter? I thought water should only come out in the summer?
The humidifier should run in winter, however if the windows are fogged up it means the humidistat is set too high. Try lowerimg the setting on tue humidistat.
Jan 03, 2013 | Carrier SBP Humidifier
Low voltage to selenoid valve how do i correct this?
change and check another carrier LBP Humidifier
Jan 21, 2012 | Carrier LBP Humidifier
My humidifier is a Carrier and uses the square evaporator cartrages. There is a drain pipe coming out of the bottom that goes to a floor drain. I've noticed that there is a slow drip here all of the...
Hello, no the humidifier should be running only when the blower motor is running. Sounds like the solenoid valve is faulty if water keeps drainig from humidifier.
Sep 25, 2011 | Aprilaire 700 Humidifier
I have a carrier humidifier model BG49. When the furnace turns off due to reaching room temp. The water still continues to flow into the reservoir of the humidifier. Is this the correct operating...
Hello, The humidifier should turn on and off with the furnace's blower motor, If the humidifier keeps continously running than the solenoid valve is stuck open and should be replaced.
Jan 30, 2011 | Carrier LFP Humidifier
Excessive water usage with Carrier LBP humidifier.
hi the water runs down the pad the fan blows air across is , this controled by the stat which should control the water flow / on or off, this should be under warranty in the first year
Mar 01, 2010 | Carrier LBP Humidifier
I have a carrier furnace, humidifier valve popped fuse
hook up the new transformer to the white (common) from the blower motor, and the lead from the blower motor hooked up to the heat term on the board. (just cut the wires and wire nut all three together)
Nov 18, 2009 | Honeywell HE360A1027 Whole House...
Carrier SBP Humidifier is not working
I would suggest turning up the humidistat (usually located on the the return air duct to a higher setting and listening for a "click" noise on the supply valve. If you do hear a click but dont see / hear any water than the culprit is likely the valve itself.
Nov 22, 2008 | Carrier SBP Humidifier
Humidifiers Logo
Top Carrier Humidifiers Experts
paulcarew
Mack Baxter
Tom Chichester
Are you a Carrier Humidifier Expert? Answer questions, earn points and help others
