Question about Sewing Machines
Singer sewing 411g
I have a Singer 411g which has served me very well for over 45 years. I recently let someone else use it and it promptly developed a problem. I was not there so don't know what, if anything, she did wrong but it started to "run away with itself", operating at high speed of its own accord without any contact with the foot pedal. Switching off at the socket was the only way to stop it. I have since tentatively tried to use it; it works fine for a couple of minutes or so before starting the same problem and need to switch off at socket. Any ideas? Is it a short or something in the foot pedal and what can I do?
  • 822 Answers
It is most likely the foot pedal has failed. The pedal motor circuit is very simple and it is not possible for any other component to cause the machine to go into a race condition other than a defective pedal.
Check the spring return of the pedal. If it is not operating freely it might be repairable. If it is not the spring then the pedal is not likely repairable..
Parts are still available.
Hope this helps?
Posted on Apr 15, 2017
2 Suggested Answers
  • 980 Answers
SOURCE: singer 522 starts sewing at speed without the
Undo the foot control and take out the small square suppressor and throw it away, you don't need it anymore.
Posted on Dec 18, 2009
What year and how much is my singer sewing machhine aj767584 worth
This web site may be helpful.
Singer Sewing Machine Company Serial Numbers
As far as value, that is very subjective. Singer has made machines for well over 100 years and made probably million or more. So, that said, unless it is a rare, well-sought-after machine in exceptionally good visual and operating condition with accessories included, probably not a lot. Most people use these either as decoration or for actual sewing use, not so much for collectibility. You can always check web auctions like eBay to see if anything similar is listed or has sold recently.
Jan 16, 2017 | Singer Sewing Machines
Singer 306K original Manual states needle is 206 x 13 dont seem to be able to find any, what can i use that doesnt drop stitches?
Help with Singer 306K - Sewing Discussion at Stitcher's Guild ... > ... > Sewing Machines
Nov 22, 2013 - 33 posts - ‎8 authors
Unless,the original bobbin case has been modified,or someone bought a newer ... In Ed's blog here are pictures of a 206x13 needle vs a regular 15x1 needle and ... Here is a free Singer 306K automatic sewing machine pdf manual,with ..... I was upset and so I didn't get any more details over the phone. Author Topic: Is there such a machine as
Jul 6, 2012
Singer 319 find
May 13, 2009
More results from
Missing: states
Singer 320K2, Singer 306K Bobbin Case Conversion for ...
Sep 13, 2014 - I recently had the good fortune to pick up a Singer 320K2 sewing machine. ... as well as Singer's zig zag model 206 utilise a needle design (206X13) which ... The 206×13 needles are becoming rare, with only two sizes and only one ....Neither can I state, beyond any doubt, that this modification won't cause ...
Jan 11, 2016 | Singer Sewing Machines
How do you replace the horizontal spool pin on a singer sewing machine 3810?
seems like the screw in, if my memory serves me right . but it has been many years since I looked at one.retired over 20 yrs .
Dec 12, 2015 | Singer 3810
Where can I get a zigzag foot for a 411g singer sewing machine
You should be able to take your straight stitch foot to a local sewing shop and ask for a zig-zag foot that will work on your machine. Other alternatives would be searching online, ie:
Sewing Machine Feet this site will help you determine what shank will fit your machine
Nov 28, 2015 | Singer Sewing Machines
How do I remove the light cover to replace the bulb on a model 411G Singer sewing machine
Pull down the cover to the bulb. Lightly push the bulb while turning to remove the bulb.
Feb 02, 2015 | Singer Sewing Machines
Replace the screw. This model has a twist & click bulb. Push in, twist, and pull out. Be careful. If the bulb is quite old, it can be brittle and break.
How to the timing on a sewing machine
all sewing machines are the same a very simple. to adjust timing so the bobbin catches the thread, just slightly loosen screw on the main needle shaft(the one that has the needle and goes up and down), move the flywheel so that bobbin point is behind needle at lowest point, tighten screw. test it out. you cannot break the sewing machine, tho you can break a few needles as you master the timing technique. dont be afraid to try. it really is easy. one summer many, many years ago, while i was in college i worked for singer in a singer store. things havent changed since then. (almost 45 years ago). good luck
Jul 28, 2014 | Singer Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
