Question about Hobart HGC501 Gas Oven
Hobart gas oven not heating - Hobart HGC501 Gas Oven
Where can I buy replacement parts like latch and handles,
Any appliance store that deals with Hobart can get you what you need. You should also be able to go to the Hobart site and find what you need.
Apr 13, 2014 | Hobart DGC501 Stainless Steel Gas Single...
Electric oven does not heat
Hi limit is open , it is located on the top right corner
Mar 27, 2014 | Hobart Ovens
Where can i go and dowload the wiring manual for the baxter gas oven
Hobart, the parent company of Baxter are very picky with releasing manuals, diagrams, etc. Your best bet is go to the link below and create a user name and see if they give you access to the manuals.
https://feg.hobartcorp.com/CookieAuth.dll?GetLogon?curl=Z2FresourcecenterZ2FPagesZ2FInstructOperManuals.aspx&reason=0&formdir=2
Nov 14, 2011 | Baxter BXA2G Stainless Steel Gas Single...
LOOKING FOR A WIRING DIAGRAM FOR A HOBART HR7
looking for a wiring diagram for hobart hr7 rotisserie oven
Nov 10, 2010 | Hobart HR7E Electric Single Oven
My hobart hgc-5 convection oven heats intermittenly. Heat goes on then off. I replaced the thermostat, ignition wire and ignition board. Still only heating intermittenly. What do I do?
I would replace the flame sense or clean it and make sure it is in the flame it will glow red you can see this if you remove the front and cover it is tough but can be done.also check to make sure it is not in a drafty location the air movement could blow the flame around and not hit the flame sense.it is just a metal rod with ceramic insulator.the flame is actually conductive.it will carry a small current.That is how the ign. module knows the flame is lit and dont just let gas pour in without being lit.
Oct 03, 2010 | Hobart HGC502 Stainless Steel Gas Double...
Hgc5-1 hobart gas convection oven board giving a 3 blink code after flame shuts off what is the code error seems like maybe a limit
Test wire nuts on wire #54 and #55 (on 550 degree high limit switch) for continuity, should show shorted if shows open, limit switch is bad. Test by jumping if oven works switch is bad.
Sep 01, 2010 | Ovens
Not heating
Before buying any parts, check for proper voltage to stove and receptacle. On the side of the oven is an opening that keeps the controls cooler. If it is blocked, the temp control might be malfunctioning. Something as simple as cleaning that up might cause it to work better.
May 17, 2010 | Hobart HEC20 Electric Single Oven
My covection oven does not heat up once food is put in
on the gas valve there is an adj. for the pilot size, maybe too small , would try increasing the pilot and see what happens.also the thermocouple might be on the way out ,you might want to replace that and try oper. go with thermocouple first, then try pilot size dont forget to vote tks. monomoy
Feb 20, 2009 | Hobart HGC202 Gas Single Oven
Hobart HEC40 208V to a 240V source
The only difference should be the elements. Consider installing a buck-boost transformer. It may be cheaper.
The Hobart part number for the 240 volt element assembly is --
# 342170-00002. Your local Hobart can get you a price.
Mar 08, 2008 | Hobart HEC501-208V Electric Single Oven
Hobart HGC501 Gas Oven Logo
23 people viewed this question
Top Hobart Ovens Experts
Dan Webster
Dan Webster
joneable
Level 1 Expert
Gil Shultz
Are you a Hobart Oven Expert? Answer questions, earn points and help others
