Question about Citizen CLP-521 Thermal Label Printer
How to find my ip address for the CLP-521 - Citizen CLP-521 Thermal Label Printer
My CLP-315 keeps turning itself off and on occasions when it does stay on (with red and/or amber lights in place) the Smart Panel tells me it is not connected to my computer, even though it is, or that it...
Is it a clp 315w. If so, it could be dropping off the wireless network. I had a similar problem caused by duplicate IP addresses. Removed the printer and re-added it to my laptops which resolved the problem. (Control Panel add/remove devices), Roy Bayliss
Nov 23, 2011 | Samsung CLP 315 Laser Printer
Hello, I got on my printer a Samsung CLP-315 always a red light <--> also when it print's it stops in the middle... Isn't there a reset buttom? Thank you
  1. Hello Charlotte, to reset your printer you have to do the following action
  1. The printer and the computer must be on
Hold down the "Stop" button (shaped like a triangle) for at least five seconds. A Network Configuration page should print out, showing the IP address of the printer. Even if it doesn't, the IP address with display on the printer monitor. Write it down.Open Internet Explorer and enter the IP address after "http://." As an Example, "http://192.168.1.107." And press "Enter." You will be taken to Samsung's SyncThru Web Service. you do not actually need to be connected to the Internet for this to work. on that page Click "Reset" and Click "Clear."
Aug 01, 2011 | Samsung CLP 315 Laser Printer
How to manually input ip address on Samsung clp315 printer
This solution just points you to someone trying to sell you something
Aug 27, 2009 | Samsung CLP-315W Laser Color Printer
Printing problem
Problem has been solved, thankyou,
Printer was unistalled and then re-installed.
Jul 22, 2009 | Citizen CLP-521 Thermal Label Printer
I have lost network printer status and cannot get it back.
Restart printer Network switch/router and computer.
Ping the Ip address of printer if its not responding then try IP set program from samsung. If the same status then the problem suspected is the main board.
Jul 05, 2009 | Samsung CLP 315 Laser Printer
Unable to connect wirelessly to my Samsung CLP 315W
configure the setting manually by putting the printers IP address....install the driver first
verify your printers support site and download the updated/new drivers and patches need to install.
link for Drivers and manual:
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=colorlaserprinters&model_nm=CLP-315W&language=&cate_type=all&dType=D&mType=SW&vType=&prd_ia_cd=06010200&disp_nm=CLP-315W&model_cd=CLP-315W/XAA&menu=download
Mar 20, 2009 | Samsung CLP 315 Laser Printer
How to determine which toner run out the ink.
If installed through the network connection go to the machines ip address in ie or firefox and it will tell you. or print a config page using the menu buttons on the machine
Jan 06, 2009 | Samsung CLP-500 Laser Printer
Samsung CLP 300 - Drivers keep disabling
The printer is probably not getting the same IP address every time. Set a static IP address outside of the range being used for DHCP addressing. If the entire range is set for DHCP, you will need to adjust that range so the printer's IP is no longer in it.
Nov 09, 2008 | Samsung CLP-300N Laser Printer
Samsung CLP-510 not printing
hi ,
i went through the website www.linksys.com and i found that Samsung CLP-510 is not compatible with wrt160n.
Oct 23, 2008 | Computers & Internet
Question: Samsung CLP-600N, Vista
Possibly two problems here.
1) Printer on before PC to get a print - an IP address problem ??
Is the IP adress of the printer a STATIC address (usually works better and more reliably), or is obtaining its address from a DHCP server (typically a router, wireless router etc)
Doing an Information print (MENU, ENTER, ENTER) should tell you how the printer is set.
2) Unable to get multple copies.
Possibly a driver problem - get the first sorted out then see if it still does it.
Jan 08, 2008 | Samsung CLP-600N Laser Printer
Citizen CLP-521 Thermal Label Printer Logo
121 people viewed this question
Top Citizen Office Equipment & Supplies Experts
Tejodhar Atreya...
Tejodhar Atreya...
Roy May
Are you a Citizen Office Equipment and Supply Expert? Answer questions, earn points and help others
