Question about AudioBahn Car Audio & Video
Brand new 2 channel audiobahn amp one channel doesnt work why
  • 7 Answers
SOURCE: audiobahn 12' subs and audiobahn amp
First thing is first. What subs do you have? Audiobahn makes several kinds of 12" subs. What model sub do you have?
Without knowing this, it would be hard to recomend an amp without knowing how much power your sub can handle. Audiobahn makes from very power amps that can put out up to 5000W RMS, but if your sub can not handle that power, then you will blow your sub.
Posted on Dec 21, 2007
SOURCE: Audiobahn A4601T, only 1 audio channel works
Absolutely. Thanks for your help. I will open it up some time this week and take a look. If I can't figure it out I will reply and give you my email so I can send you some pics.
Posted on Oct 27, 2008
etirbynnor
  • 655 Answers
SOURCE: amp makes noise. I am purchaseing a new amp
Hello termite440,
A mono amp will generally provide more power for subs. And for those Audiobahn's, you'll want something that will provide a minimum of 500-600 watts RMS to each, a least a 1000 watt amp. At the low end, something like the Alpine MRP-M1000 or the Orion HCCA-D2400 will provide 1000-1200 watts. I'd recommend the Alpine. For more power, and another $100, look at the Alpine M2000, or for another $250, the Rockford-Fosgate T1500-1bd.
Hope this helps.
Posted on Apr 28, 2009
  • 61 Answers
SOURCE: I'am missing a rear channel, checked fuses,
have you got on one rca input to this amp or two. of two you may need to use a set of splitters.
Posted on May 15, 2009
  • 155 Answers
SOURCE: recomended sub woofer wireing diagram have 2
check out audiobahn.com go to tech support and go to wiring diagrams type in how many speakers DVC or SVC and it will show you how...
Posted on May 11, 2010
Audiobahn a1502dp amp only one channel is working. I need both to bridge it and get its full 1ohm potential. Where can I get this fixed? Preferably near kc
Audiobahn A1502DP True Digital Series 2-Channel Amplifier
www.sonicelectronix.com > ... > Car Amplifiers > Class-D Amplifiers
Rating: 4.5 - ‎4 reviews
Audiobahn A1502DP • True Digital Series 2-Channel Amplifier 1 ohm stereo stable 2 ohms bridged • True Digital Circuitry • Dual Cooling Fans • HP/LP ...
new amp, only one channel working?? help! [Archive ...
www.caraudioforum.com > ... > Car Audio: Installation Help
Apr 24, 2006 - 16 posts - ‎5 authors
the next step would be to try reversing the rca cables on the amp. ... unplug one wire, the one sub that is working, gets quieter, although it is still working. as ... It'saudiobahn, of course this could happen straight from the factory.Missing: a1502dp
[PDF]True Digital Full-Range Series - Audiobahn
audiobahn.com/.../Amplifiers/A752DP-A1502DP-A2502DP-A1004DP-...
A752DP/A1502DP/A2502DP ... Audiobahn was established in 1997 with one long-term goal in mind, ... Great products and proper installation are only a small piece of the puzzle when it ... from the smallest terminal, to power wires up to 0 gauge, and 4channel RCA cables. .... exceed the total value of fuses in the amp. 1 1 .
one channel not working [Solved] - Speakers - Audio
Jan 15, 2016 | AudioBahn Car Audio & Video
Brand new Audiobahn amp burning smell
i'd need more info but from what you've stated, sorry to break it to you but it sounds likely you've incorrectly wired you speakers and blown your amp. this will prove no doubt an expensive mistake and learning exercise.
May 23, 2017 | AudioBahn Car Audio & Video
How do i get the most watts possible from this amp, with out overheating the amp.
you can run your amp at 1 ohm you would need to to have the right ohm subwoofer wired in parralle to get 1 ohm at amp ...... the put a 12 volt fan in the area to keep the amp cool so it doesnt over heat if you plane to
Audiobahn A2X400HQ 2 Ch Amp
1600w x 1 @ 1ohm - 800w x 1 @ 2ohm
600w x 2 @ 1ohm - 400w x 2 @ 2ohm
2-Channel High Current Amplifier -- Ideal for use with all Audiobahn Rack Mount Products
http://www.tintingbyfredjohnson.com
Dec 27, 2010 | AudioBahn A2X400HQ Car Audio Amplifier
I have a 12 inch audiobahn 550 rms 4 ohm coil ported box and a dual box with 12 inch subs they say 550 max wattas a piece thats it waht amp do i need to get atleast 80% of my power in bass
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
Sep 25, 2010 | Car Audio & Video
Heeey. I have the Audiobahn A2300HCT and it has a very strange problem. When i start the amp its in the normal blue mode but i have no sound. The one power output (LEFT) indicator shows +3DB (full) the...
My brother just bought an A2300HCX and almost the same thing happen. 1 of the gauges (left side) was no movement. We tryed hooking the amp to the right side, and it works. The Left side turns out was shot, had to get it fixed. So sorry to tell you but sounds like one of the channels has internal damage. I know this isn't the good new you were wanting to hear, but hope it was helpful
Apr 08, 2010 | AudioBahn A2300HCT Car Audio Amplifier
I am looking to buy a 1200 watt jensen 2 channel amp. what model is this? is there a jensen 1200, i have not seem it.
I would recommend you purchase a brand name 600watt RMS amp instead of a Jensen 1200 watt peak amp. Trust me you will notice the difference. Try a kicker, hifonics, MTX, audiobahn Autotech... Its not the watts its the quality of the watts..
Sep 12, 2009 | Car Audio & Video
550x2 subs....SPL z2x-820 Amp
The 230 watt amp is a little small for your subs. They'll work, but if you are looking for max SPL, you won't get it. To push those Audiobahn's to their potential pavement shaking max, I would recommend an amp in the range of 500-600 rms (2-channel bridged) or 1000 watts rms monoblock.
Hope this helps.
Mar 28, 2009 | SPL Dynamics Z2X-820 Car Audio Amplifier
Is it the same channel in both amps that produces output?
Have you tried all combinations of setting for the switches and pots on both amps?
Oct 25, 2008 | AudioBahn A4601T Car Audio Amplifier
Wiring subs
audiobahn.com can help you with the free diagrams under tect support
May 03, 2008 | AudioBahn A4075HCQ Car Audio Amplifier
Car Audio & Video Logo
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
