Whirlpool ghw9150pwo code f h
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all
the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the
inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to
Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain
Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
Don't get too deep into the washer itself and void your warranty!
SOURCE: Whirlpool Duet Mdl GHW9150PWO Washer stops
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
SOURCE: whirlpool ghw9150pwo f11 error code
f11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor
Control Unit (MCU) cannot be sent correctly.
* Check Wire Harness connectors to the MCU, the motor, and Central
Control Unit (CCU)
* Check the Drive system for any worn or failed components
* Check MCU
* Check CCU
* Check Motor
SOURCE: code f-6
"F6" is a Motor Speed error problem. It is commonly attributed to either a broken or slipped drive belt, defective Drive Motor, bad Motor Control Unit (MCU), or the interconnecting wiring. The following link explains:
http://www.fixya.com/support/r3608706-f06_error_code
First, remove the back panel of the unit and make sure the drive belt is not broken, or has not slipped off the drum pulley.
Then, remove the top panel of the washer and check all the connector plugs between the Drive Motor, MCU and Central Control Unit (CCU). Check for loose connections and then unplug each connector and plug them back in (one at a time) to ensure they are snug and making good contact. The top panel comes off by removing the three screws that hold it in place in the rear of the washer. With the screws removed, the panel will slide back, then off.
NOTE: You only need to check the connectors that affect the drive motor and MCU circuitry.
The MCU has a tachometer mounted on it. If it is determined to be the cause of the problem, it is considered part of the MCU and cannot be replaced separately. The MCU is not serviceable and will require replacement.
Next, check the motor windings to ensure they are reading the proper resistance. Followed by continuity checks of all the interconnecting wiring between the drive motor, MCU and CCU. You should not need a service manual because each one of these washers comes with a technical data sheet.
For more in depth troubleshooting tips refer to your tech sheet located inside the washer behind the lower toe panel. You will need to locate and remove the screws under the bottom front edge of the toe panel. Once removed, the panel will drop down, then come off. If the tech sheet isn't located directly behind the panel, it will be affixed to one of the interior cabinet walls. The tech sheet includes all error codes, test points, diagnostic procedures and helpful illustrations to assist in troubleshooting and repair of your washer.
If you have questions, or require additional assistance, please let me know. I hope you find this information helpful.
