Question about Luggage & Travel
Combination lock how to reset turned top wrong way
How to change the 3 digit code of my samsonite ?
Luggage manufacturer Samsonite offers a variety of business, personal, travel products and accessories. Many Samsonite pieces such as attaches and other bags include a three-digit, built-in combination lock. When purchased, the locks are set on a factory default combination that you can change as often as you wish.
STEP 1
Turn the number dials to the previously set combination, or to "0-0-0", the factory default combination for Samsonite luggage.
STEP 2
Locate the reset button, usually placed to the side of the combination dials.
STEP 3
Press the reset button and hold it while rotating the number dials to the desired combination. Set this to a sequence easy for you to remember but hard for others to figure out.
STEP 4
Release the reset button after you set the numbers to the new combination.
STEP 5
Test the combination by turning the dials to the new code to open the lock. If the combination does not open the lock, repeat Steps 1 through 4 and test the lock again. If you still can't open the lock, contact Samsonite Customer Service at 800-765-2247.
Aug 28, 2016 | Luggage & Travel
I have a korjo boarding pass BPL2 and have forgotten combination and can't relock - am i able to reset
If it is open, it is a lot easier to find the combination than if it were closed! Unfortunately, I can't find an image of this lock to advise you. If it is a standard combination lock with a loop shackle, you put gentle pressure on the loop as you turn the top dial of numbers. When the loop drops in, write down the number, then without moving that dial start turning the second dial until the shackle drops in, write down that number. Do the same with cylinders 3 and 4.
Mar 16, 2016 | Locks & Locksmithing
How do I can unlock dial lock
The master dial lock is the world's best selling combination padlock.The lock uses three digit combination of 40 numbers.allowing for 15,00 possible variations
.Follow these step to unlock dial lock. 25284217-gdc3ufgmlwaqnv2deqjxyac2-5-0.jpg With the Combination Step 1 Turn the lock until the numbers read right-side-up. Roll the left-most dial until the first number of your combination lines up with the scored hash mark just to the left of the dial.
With the Combination Step 2 Roll the middle dial until the appropriate number lines up with the number to its left. Do the same for the right-most number. Your three-digit combination should now show, left to right, lined up with the scored hash marks.
With the Combination Step 3 Pull the body of the lock away from the U-shaped metal ring without turning any of the dials. The lock will click open to expose a hook. The hook spins 360 degrees so that it can be placed onto, and taken off, luggage.
Forgotten Combination Step 1 Pull the body of the lock and the U-shaped ring away from each other to put pressure on the mechanism inside the lock. Pull the body of the lock away from its attachment, or, if the lock is not attached, apply pressure on the U-shaped ring away from the body of the lock with your fingers. Keep holding a firm, steady pressure.
Forgotten Combination Step 2 Roll the dial closest to the U-shaped ring slowly, while keeping steady pressure on the mechanism. The dial will get difficult to roll over three consecutive numbers, and one of those numbers will click. You should feel and hear this small click, and that is the first number to your combination.
Forgotten Combination Step 3 Repeat Step 2 with the middle dial, and then the farthest dial. Leave the dial set when you find the click, moving onto the next dial. The combination will reveal itself, letting you pull the U-ring away from the body of the lock.
Resetting Your Combination Step 1 Hold the body of the lock so that the numbers face away from you. Set the combination and release the U-shaped ring.
Resetting Your Combination Step 2 Turn the hook of the U-shaped ring counterclockwise 90 degrees until the notch on the stem of the hook and the hole on the body of the lock line up. Push the stem of the hook down into the body of the lock as far as it will go.
Resetting Your Combination Step 3 Turn the hook another 90 degrees counterclockwise while it is depressed into the body of the lock.
Resetting Your Combination Step 4 Roll the dials until you have your new combination.
Resetting Your Combination Step 5 Turn the hook 90 degrees clockwise and raise the stem out of the body of the lock. Turn it another 90 degrees clockwise and push it back into the locked position. The lock now uses your new combination.
Sponsored Links
Luggage Trolleys Supplier
Supplies Made to Order from World's Largest Supplier Base. Top Deals!
www.alibaba.com $0.01 Web Hosting
Scalable, Secure Web Hosting. Try Our Award-Winning Service Now!
www.hostgator.com/1Penny Rooftop Air Conditioner
low noise, high static pressure. Made in China, Inquire Now!
www.airconditionings.cn Download Facebook Apps
Get The Most Popular Apps For The Largest Social Network. Join Now!
www.facebook.com by Taboola
Sponsored Links
Move Over, Turkey: 9 Side Dishes that Will Steal the ShowKraft Recipes See Another Side of Dubai in HattaDepartment of Dubai Tourism & Commerce Marketing by AFAR
Email Best Practices: Sending Emails That Won't Be IgnoredRackspace
TIP
  • Email yourself the password to your lock, and title the email "Luggage Lock." If you forget the password in the future, simply search your email for the term "Luggage Lock."
WARNING
  • Do not open a lock that does not belong to you. It is against the law.
REFERENCES
RESOURCES
ABOUT THE AUTHOR Christopher Michael began writing in 2004 for his college newspaper. He received a Bachelor of Arts in English and psychology, as well as a certificate in criminal justice from the University of Massachusetts, Amherst.
PHOTO CREDITS
  • Creatas/Creatas/Getty images
Suggest an Article Correction
How to Open a Combination Lock on a Samsonite Suitcase
  • How to Reset the Combination on an American Tourister
  • Airline Rules on Locked Luggage
  • How to Reset a TSA Lock
  • Reagan Airport & Luggage Storage
  • How to Prevent Lost Luggage
  • Cost of Shipping Luggage Ahead to Destination
  • How to Repair Wheels on Luggage
  • The Odds of Losing Luggage
  • How to Make Inexpensive Luggage Tags
  • Solutions to Lost Luggage in Air Travel
  • How to Measure Luggage
  • How to Expedite Lost Luggage Claims
  • What Are the Dimensions of Hand Luggage for Air France?
  • What Rights Do I Have If My Luggage Is Lost?
  • How to Store Luggage While Traveling in Italy
  • pixel.gifHappy Camper: Test Your Outdoors Knowledge
  • pixel.gifCruisin' Along the PCH: Test Your Knowledge
  • pixel.gifWhich U.S. Landmark Would You Be?
  • pixel.gifCan You Pass for a Proper Brit?
  • Nov 15, 2014 | Lands Phones
    Tsa002 change combination
    Most combination luggage locks can be reset when they are open. The combination wheels can't be turned unless the lock is being reset. So either the wheels show the correct combination, or you will be able to turn them to a new combination. The lock that is "locked outside the hole" was either not relocked after inspection or it's in reset mode.
    Jul 04, 2014 | Locks & Locksmithing
    How do you unlock a TSA COMBINATION LOCK WITH fogotten. number?
    The only way to reset a TSA Combination lock is to turn the numbers until you get it. The good news is that you only have 1000 possible combinations. Start at 0 0 0, then 0 0 1, 0 0 2, etc...
    There are posted videos on YouTube that talk about how to reset locks with unknown combinations but they are specific to the brand of the lock; assuming they aren't fake videos anyhow.
    Nov 19, 2013 | Home Security
    How do I reset a 4 dial Samsonite combination lock
    Hello sstacy1,
    You can follow the steps below to fix your problem on how to reset your 4 dial Samsonite combination lock:
    1. Set the dials to 0-0-0. Find the lever or button next to the dials.
    2. 2If your lock has a lever, lower it and turn the dials to the desired numbers. Return the lever to its starting position.
    3. 3For locks with a button, push the button towards the dials and turn them to the desired numbers. Release the button.
    4. 4The lock is now set to the new combination.
    Read more: How to Reset Samsonite Luggage Combination Locks ' eHow.comhttp://www.ehow.com/how_4761466_reset-samsonite-luggage-combination-locks.html#ixzz157Q4Ap
    Hopefully it helps.
    Thank you for using fixya
    Sep 08, 2011 | Health & Beauty
    I lost the instructions and don't know how to unlock using "original code" and how to create a new code
    try all zeros Kryptonite locks come preset to zeros once unlocked there is a small lever inside were it locks together pull it down and set your new combo then push it back up
    Oct 17, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
    I dont know how to open the lock its brand new????? They failed to give me instructions when they attached to the bike
    My new lock didn't come with any instuctions. I followed the link above and located the "bike locks" heading. I found that the question:
    - I have a Kryptonite resettable combination lock and can't find the instructions for resetting it. How can I change the combination?
    contained a pdf titled :
    - Resettable Combination Cable
    (red reset buttons inside)
    which is not the cryptoflex 1218 but is compatible anyway.
    dont hurt your fingers trying to depress the nodules as the diagram says though. to my chagrin i discovered that they will turn easily if you just push them around into place.
    here are the instructions:
    To set your own combination
    Your new lock is preset to open at 0-0-0-5 at the factory.
    1. Open the lock by aligning the opening combination
    number to the Guide Points and pull out the Lock
    Post. (Figure 1)
    2. Push down the two Reset Buttons simultaneously
    with thumb and forefinger, and turn counterclockwise
    until it comes to a stop. (Figure 2)
    3.You are now ready to turn the dials to set your
    secret combination, such as a phone number, birthday,
    etc.
    4. After setting your secret combination, turn the
    two Reset Buttons again by Thumb and Forefinger
    clockwise until it comes to a stop and back to its
    original position.
    5. Verify your new combination before using your
    lock. Insert the Lock Post all the way into the Locking
    Port but do not turn the dials. Pull out the Lock Post.
    Your lock is ready to use.
    6.The reset operation is now complete. Repeat
    steps 1-5 anytime you wish to change your secret
    combination.
    Oct 11, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
    We threw out the info that came with our new trek combination lock. now we have no idea how to open it or to reset it.
    Try this....
    Post. (Figure 1)
    etc.
    original position.
    combination.
    Sep 16, 2009 | Kryptonite Kryptoflex 1218 Combo Cable...
    Luggage & Travel Logo
    14 people viewed this question
    Top Luggage & Travel Experts
    Dave braun
    Dave braun
    Tom Chichester
    Bobby Lewis
    Bobby Lewis
    Are you a Luggage and Travel Expert? Answer questions, earn points and help others
