Question about Krups XP4030 Espresso Machine
My espresso machine will not drip water - Krups XP4030 Espresso Machine
2 Suggested Answers
  • 39 Answers
SOURCE: Krups XP2070 coffee machine -
This will most likely happen when the pressure valves become defective. Replacing the two valves (they come in pairs) should fix the problem.
Posted on Dec 29, 2009
Espresso part is working, hot water/steam draining into drip tray.
I had the same problem on my Delonghi ESAM3300; you need to replace the "Tap" #7313216621 you can buy at eReplacementParts.com and search on how to install on Youtube. Its easy. No more leaking. Good luck
Oct 07, 2015 | DeLonghi ESAM3300 Magnifica...
I purchased the espresso maker above. My problem is the strength of the espresso brewed. It comes out strong at first, but by the end of the dripping it turns watery. By the time the dripping stops the...
to have a good espresso depends from many factors, first of all is the coffe blend, the grind, then water quality, espresso maker pressure and temperature, and that is just the most important!...I think you can try with a REAL espresso blend with very thin grind, let the water flow without filter, then when the light switch on put the filter, you can also try to warm first for steam and after commute to make espresso and wait for right temperature. Finally you will obtain a discreete espresso, never as in the professional machines!...otherwise you have to invest such 2000 euros for a professional good coffe machine
Aug 22, 2010 | Ariete Cafe Retro Espresso Machine
The machine is making a grinding noise and barely anything is dripping from the machine. It would take an hour for it all to drip out at that rate. Help!!
Not sure what the grinding noise would be (its hard to hear it ;-]) it might be the water pump if that model has one. The slow drip rate can also be from build up inside the machine. If you run vinegar and water through the machine a few times and then plain water a few more to make sure you don't end up with a vinegar espresso ;-]
Oct 23, 2009 | DeLonghi EC140 Espresso Machine
Water dripping of Steam Wand during brew cycle
If water is dripping out of steamwand then the valve assembly is not working properly and needs to be replaced.
Aug 17, 2009 | Saeco Odea-Giro Espresso Machine
Water not dripping enough
maybe our coffee is to fine of a grind
Apr 24, 2009 | Saeco Classico Espresso Machine
Espresso water is dripping not streaming
Try replacing the brew solenoid on the grouphead. Its the black or blue electrical box assembly connected to the side of the group.
Apr 17, 2009 | Coffee Makers & Espresso Machines
Coffee not dripping out of the machine
let it run without coffe tablets, if no water comes out probably the conducts are obstructed, may be calcium in the pipes...do water come out somewere else?...
Jan 08, 2009 | Lavazza Espresso Point Capsule Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Water steams away and nothing drips into the caraffe
I had this problem too and finally found a fix for it.
I don't know if the cause of this issue is the same for everyone experiencing the problem, but the issue for me was hard water. The fix is to run vinegar mixed with water through the machine quite a few times, until it starts to run normally.
If you do have hard water issues, it's recommended that you run vinegar or citric acid through the machine about once a month, to keep deposits from building up.
Feb 15, 2008 | Krups Caffe Bistro 867 Espresso & Coffee...
Krups XP4030 Espresso Machine Logo
62 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
