Question about Cooktops
Circuit Braker Jump Off Easily on GE JP350 Cooktop
Could you help me troubleshoot why the circuit braker jumps off so easy on GE JP350 Cooktop, even only with two units on?
  • 1 more comment
  • tom2026 Oct 31, 2007
    It is 30A. I just bought one with 40A rating.
    Thanks! That was my concern too.
  • chris matthews Jul 28, 2008
    iv just installed an aeg 6410kfn hob, iv run 6mm cable from a cooker socket(45a) to the consumer unit and a 40a rcd in there, from socket to hob also in 6mm cable, however when wiring to hob there is two live inlets, i bridged them in same cable and the rcd blows every time, it doesnt blow when only connected to live 1, back of hob shows 3 diagrams ie 400v, 230v and 230-240v, second and third wiring diagram the same with a bridge between live 1 and live 2, do i need a bigger rcd, havent got any instructions etc, thanks in advance for your help
  • 363 Answers
The ciruit breaker might not be of sufficient rating. Tell us what is the number written on the breaker?
Posted on Oct 27, 2007
  • Martin B
    Martin B Oct 31, 2007
    Providing you are at 240V line voltage then 40Amps is correct for this 7.7kW cooktop. 30Amp is not enough.
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
I have a GE 30 in. Profile JP350 Cooktop. The large, front and right control seems stripped and will no longer control the cooktop. Also, the part that it sits on at the cooktop is not protruding up as...
Hi sounds like you have a busted switch assembly, this is very much fixable the part is around $50, but you would need to remove the top of the stove which requires pulling the unit from the counter, this is slightly more involved, but definitely doable i would also change the knob. A more accurate name would be infinite switch.
Mar 28, 2011 | GE 30 in. Profile JP350 Electric Cooktop
Infinite switch has failed twice in the last 6 months on my JP350 elec. stove?
This is usually the infinite switch has failed. They are easy to check and inexpensive. There is a video at that will walk you thru testing this. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations for your specific model. Not all models are available. All parts come with installation instructions.
May 14, 2010 | GE 30 in. Profile JP350 Electric Cooktop
GE jgp328 front ignitors won't turn off. How do I remedy this?
Did you just clean it? If the swiches under the burner knobs get wet, they cause the electrodes to click. Unplug the unit or turn off the braker for a day. it should dry up and work normal.
May 04, 2009 | GE 30 in. JGP328 Gas Cooktop
Broken selector switch
TURN OFF CIRCUIT BREAKER. Lift out cooktop, remove all machine screws holding the glass frame. Remove plastic knobs and lift glass top straight up. Make sure rubber gromits are not ripped or torn. Unscrew the small screws on the selector switch and then lift up and tilt over the small aluminum chasis holding the switches to expose the wiring connections. Pull off the wires and pull out the defective switch. Replacre switch, connect wires, re-seat switch chasis, and secure switch with screws. Carefully drop in the glasstop lining up the switch shafts and the rubber grommets. Secure the top with machine screws and drop back in the cutout.
Apr 18, 2009 | GE 30 in. Profile JP350 Electric Cooktop
Poping sound, sparks shooting out and 220 circuit breaker out
Did you move the breaker fully off before turning it back on? make sure the offending burner is off.
It sounds as though the element shorted out.
Mar 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Circuit Braker Jumps Off
You probably have a burnt out element. They almost always short out when they burn out. If it is a coil unit it may be visible. A smooth top unit can't be diagnosed without removing the top glass. Most of the time you can do this yourself. Sometimes when a burner goes it will ruin the switch also.
Mar 29, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
GE JP350 wiring problems
a to black one
b to red one
d to orange
e to grey
a-e to red two
a-d to black two
a-c to orange two
a-b to grey two
a-a to white
Jan 19, 2008 | GE 30 in. Profile JP350 Electric Cooktop
Cooktops Logo
438 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
