Question about Dell UltraSharp 1905FP 19" LCD Monitor
Dell 1905FP powers up but screen goes black after a few minutes
Monitor powers up long enough for computer to boot, then the screen goes black. Sometimes the screen flickers slightly before this happens. When I lose the video I will see faint colored vertical lines that dissolve into black. The power light remains lit. If I turn off the monitor and power up again I will have video for a few minutes more. Any thoughts on what the problem is? Thanks.
    Problem Solver:
  • 16 Answers
The monitors inverter seems to be failing. If you look up close, can you see a very faint image of the desktop?
You should think about getting a new monitor it might be cheaper than repairing.
Posted on Nov 12, 2017
Benimur
  • 6966 Answers
SOURCE: Dell SP2208WFP Flat Panel Monitor flickers out and goes black.
Hi again,
Any luck with the Dell people?
A favor if I may, at your convenience, would appreciate if you can rate our Live Session as you see it fit.
Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 06, 2008
SOURCE: LCD monitor turns off after 2 seconds from boot
Thanks for the suggestion, I have finally found out that the back light for the monitor is culprit. Also dell people and confirmed it . They aggred for a replacement. Thanks for the suggestion again.
Posted on Nov 25, 2008
  • 11 Answers
SOURCE: Screen goes blank
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cause of power going off: There is a bad 1000uF, 16V cap on the power supply board.
Solution: Replace cap. Radio Shack sells a 1000uF, 35V cap for $2. This will work.
Why did the cap go bad? The cap is too close to a heat sink and over heated.
What does this cap do? This cap sends a signal to an IC which keeps the monitor 'on' after the power switch is pushed. When the cap is weak, AC ripple voltage is applied to the IC and it sends a signal to shut the monitor off.
Opening the Monitor: These monitors are difficult to open.
The two plastic pieces snap together and must be pried apart with a flat screw driver.
After removing the stand, you need to insert a flat screw driver at the bottom of the screen where two slots are located. Then work the screw driver around until the two plastic pieces are separated.
Remove the cover plate and unscrew the push button circuit board.
Unplug the monitor cords from the driver board and remove the screen.
Unscrew the mounting screws from the power supply board and remove.
You will need to pinch the plastic support in the middle of the board to remove.
Cap Replacement:
Cap is located near a copper heat sink and the value will be on the side of the cap. It will be bulged up on the top. You will see burn marks on the board surrounding the cap. Unsolder the cap.
Install the new cap and solder. Make sure you connect + of the cap to + marked on the board.
Be careful not to solder across joints.
Keep leads long so you can bend the cap as far away from the heat sink as possible.
Reassemble monitor and turn on.
This should solve the problem.
Posted on Jan 01, 2009
tommya300
  • 724 Answers
SOURCE: blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Posted on Jul 27, 2009
  • 1684 Answers
SOURCE: Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 30, 2009
Dell 530S powers up and goes blank
how long have you given it to boot after it goes black? you may just have to wait a few minutes as windows may be configuring something on boot.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 03, 2012 | Dell Inspiron 530s Desktop Computer...
My 1905FP Dell monitor powers up and the screen is normal for about 3 - 5 seconds and then goes black. Turn it off and then on and the screen goes thru the same routine as many times as you want to turn...
si al encenderlo dura unos cuantos segundos encendido y luego se apaga
revisa los condensadores en la fuente del alto voltage casi siempre se inchan y no dan el voltage correcto tambien podria ser una de las lamparas se quema el cable negativo de la lampara que es el mas delgado donde solda con ella.
Aug 16, 2011 | Dell UltraSharp 1905FP LCD Monitor
One of my computers lost power this morning due to blown fuse. When I turned everything back on the monitor screen has power and no screen.. it is all black
If the power light is on, but the screen never appears to light up, either the backlight or the power inverter have failed.
May 05, 2011 | Dell UltraSharp 1905FP 19" LCD Monitor
Cant change it from power saving mode
Screen flashes on for few seconds and turn black? Does the same on another PC?. It may ahve bad caps as hsown in my albums.
http://s807.photobucket.com/albums/yy352/budm/Dell%201905FP%20Rev%20A03/
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Oct 23, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
I have a Dell Ultrasharp 1907FPV, it's a few years old. Whenever I start my computer, the moniter stays dark and the green power button does these quick flickers. Eash flicker cycle takes less then a...
You don't have a short-circuit. That would have blown the protections or even the monitor. Refer to the manual, that flashing light may be a code that tells you the problem. I don't think the repair would be expensive...
Nov 29, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
I have a dell moniter 1905fp and it is flash the main screen. any suggestions
Had the same problem on my Dell E178FP and I made a video on how I fixed it.
Jun 20, 2009 | Dell UltraSharp 1905FP LCD Monitor
Monitor goes black............
try checking the cables first.
May 28, 2009 | Dell E176FP 17" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
How do i open the cover to a Dell 1905FP Monitor
The front bezel snaps off. Power supply access requires dissassembly of screen from electronics cage.
Dec 13, 2008 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell UltraSharp 1905FP 19" LCD Monitor Logo
Alun Cox
