Question about Toshiba Office Equipment & Supplies
0x00000002 error toshiba e-studio 225
Hi there I have just set up a Toshiba E-studio 225, but on host machine (USB connection) it throws out installation errors, software doesn't run automatically, and gives 0x00000002 error. Tried adding manually, same thing. Swapped USB cables, no joy. Swapped ports, no joy. Running windows 7 professional, all updates are current. Done malware, spyware + virus scans, clean. Get a message when booting into desktop that manmsg32.dll is missing, but cannot seem to download it. Checked registry against my win 7 laptop and seems identical - but laptop installs first time. Device keeps on registering as unspecified. Please help!
SOURCE: e-studio 163 coppier - I cannot connect it to pc
hi frnd do one thing
go to printers and faxes
select toshiba e-163,
right click
select properties
select port
select com 3
try to give print
OR
select com 4
and give print i may be ok.
pls up date me
regards
san
Posted on Oct 04, 2008
SOURCE: problem scanning with samsung scx 4521f
My connection is via a parallel to parallel cable, and I am also having a similar problem. I'm reading that usb to usb cable is the only way it will properly function. good luck with it!
Posted on Oct 20, 2008
SOURCE: Error message "Can not find camera.Please connect Omnivision SuperCam!" on my Vista laptop. Scanner works fine on my friend's XP desktop. Have tried all steps outlined in manual (several tim
Tengo el VISTA, Al tratar de escanear diapositivas con un reflecta x2-scan, cuyo sofwar he instalado, me da exactamente el mensaje que reseñan "Can not find camera. Please connect Omnivision SuperCam".
¿Como puedo activar dicho dispositivo?
Posted on Aug 25, 2009
  • 49 Answers
SOURCE: Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Posted on Dec 14, 2009
SOURCE: Xerox 6180 MFP N error 016-782 Windows 7 x64
did you get a solution to this problem. i have the exact same situation.
Posted on Feb 28, 2010
Toshiba Model e studio 2303 A.Trouble showing Error Toner.Need a solution.
Technology Time: Toshiba Error codes
www.mytechtime.com/2011/04/toshiba-errors.html
Toshiba E-Studio machines do not display service code automatically. ... All codes, except fuser errors are reset by turning the machine off and back on again. ... holding down "0" and 8" keys, enter 251 to set PM limit, and 252 to see the number of copies that have been run since the last PM. ...Toner transport motor problem.
Mar 21, 2017 | Toshiba Office Equipment & Supplies
How to remove c41 error toshiba estudio 225
C41Fuser theWhat does c41 mean C41 is fuser error...u can clear it using 08-400, reset any value to "0" ...If occur again, u need to check the fuser unit, especially themistor.
Jan 02, 2017 | Toshiba E-Studio 225 Multifunction Copier
I have atoshiba e-studio 167 machine wich shows error code C41
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
May 23, 2016 | Toshiba E-studio 167 B & W Copier....
What happened if toner not recognized in toshiba e studio 225
This model no code to bypass...Make sure you are using genuine toner with toner chip on it...Then, clean the toner chip(with 6 springs) and harness inside the machine...If still persist, u might need to change the toner chip on the machine...
Aug 11, 2015 | Toshiba E-Studio 225 Multifunction Copier
What is the reset code of toshiba estudio 181
i have toshiba e studio 181 it gives an error of paper size its not accepting any paper size expect A3 size plzz help how to set paper size
Sep 12, 2012 | Toshiba e-STUDIO181
F10 error code for a toshiba e-studio 28
Your HDD is having issues. You can try formatting the HDD (make sure you backup templates and address book if you use them.) To format HDD hold 0 and 8 while turning on the copier, when the machine comes ready key in 690 and hit start. It will then display "2 2", hit start again. Wait for it to say please reboot the machine, turn it off and back on. Hopefully this will work but if not, your HDD will need replacing.
Dec 03, 2009 | Toshiba e-STUDIO 282 Black and White...
I am having problem in taking printout from TOSHIBA E STUDIO 166
You are trying to print to paper size that is not installed in the machine. Check what paper is installed in the machine then set your software application default paper size to the same value and then print away!
Sep 10, 2009 | Toshiba e-Studio163 Copier
Toshiba e-studio 207 "local device communication error
On the host pc that connected to the MFP, check the paper size setting under the driver properties.
Apr 22, 2009 | Toshiba e-Studio 232 Black and White...
E-studio 2500c "network host is busy"
you can try to print directly to the machine (not going through the novel system) using either apple talk or ip printing
Mar 27, 2008 | Toshiba e-Studio 205 Copier
44 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
Branko Djurdjevic
Branko Djurdjevic
CheckitRight
CheckitRight
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
