32 inch konka tv stuck on standby - Televison & Video
JOHNSONELECT
  • 113 Answers
SOURCE: Ilo 32 inch LCD tv will not turn on
replace bad cap in the power supply the top will be put up
Posted on Aug 28, 2009
JOHNSONELECT
  • 113 Answers
SOURCE: Ilo 32 inch LCD wont turn on
power supply bad inside of tv
  • 376 Answers
SOURCE: I have a Konka 26 inch lcd tv LC26E560 What is
It might help someone to help solve your problem is you state what you're trying to do. Most tv's just plug into a standard ac wall jack. Are you taking it to Europe or bringing it to America? Most color lcd tv's pull about 150 watts (or less)
Posted on Sep 09, 2010
  • 1156 Answers
SOURCE: NEON C3298DVB LCD TV 32
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this help out in solving the problem.....
Posted on May 06, 2011
SuperTech-11
  • 1591 Answers
SOURCE: My 32" lcd tv is
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Posted on Jun 04, 2011
I have konka led tv model kde24ph306l.. And its stuck in standby mode.. I cant turn it on by remote and button at the side of tv... Pls someone help me..
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 09, 2017 | Konka Televison & Video
Have a 32 inch RCA TV that is stuck on standby,what can l do??
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Apr 28, 2016 | RCA F32650 32" TV
I have a konka tv 34 inch any office address or phone no of konka dealers or distibuters
Have you tried http://www.konkaamerica.com/ the have "Contact Us" page you try calling them and asking for technical support.
Nov 15, 2010 | Konka FL2794U 27" TV
Jun 24, 2010 | Konka KDL32AT23U 32 in. LCD Television
Picture disappears
My Konka LCD model KDL32AT23U Displayed a picture, then vanished, showing different colored vertical lines in horizontal blue bands.Then I could not turn it off with the remote or standby button on the side.Only with the main switch.What's wrong??
This is the same problem posted by kukish on july 26,2008
Jul 26, 2008 | Konka KDL32AT23U 32 in. LCD Television
Adjusting screen size
Make sure you dont have picture cropping on in your settings. If you do, it will crop about an inch or more off all sides of your picture.
Feb 13, 2008 | Konka KDL32AT23U 32 in. LCD Television
Konka klc 3211
i have the konka 32 inc lcd tv and it has power problem.thats why i want to buy a powerboarb and my tv model is Klc-3211QS and the powerboard sl no. is 10838.i want know the price of the powerboard.pleas reply me soon.
thanks
Md.Aminul Islam
Nov 14, 2007 | Konka KDL32AT23U 32 in. LCD Television
Konka 32" LCD/HD TV
contact Konka directly in Calif. e-mail them
Oct 16, 2007 | Konka K2001UM TV
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
