My sharp photocopier machine had a problem it show L 1 on display i want to know what exactly problem with machine
2 Suggested Answers
  • 37 Answers
SOURCE: RICOH Photocopier machine - problem
The code you are getting is actually E-101 there is not enough space on display to display the whole code so in future if you get a code again press the # key and you can see the whole code .This code is an exposure lamp code , so either your exposure lamp is blown , or got lose connections , or you moved the machine and the scanner klimed off its rails and cant go back to the hime position .Try to enter the service mode by pressing yellew c 107 and hold down blue c all in sequence ,the number 1 will star to flash , press 5 then # 810 # then 0 # switch on and of and see if it works other wise send me a reply and ill see how i can help you .thanks
Posted on Jan 07, 2008
I have a problem with sharp AR 6020 photocopier machine that is displaying triangle and minus symbols how can i solve it
The Triangle may be the toner low light. On the older models it would look like a Triangle of stacked up cannon balls. I am not specifically familiar with your exact model.
I’m happy to help further over the phone at https://www.6ya.com/expert/ethan_e84416e0b13809d2
Feb 19, 2017 | Sharp Office Equipment & Supplies
Sharp AR5620V PHOTOCOPY machine triangular red light and display shows that 2 and for comand
toner supply abnormality toner bottle improperly set or ATC sensor abnoromality
Oct 13, 2015 | Sharp Office Equipment & Supplies
Error Code F2 - 64 of photocopier Sharp AR 5816s
If you have the install disc , Go into remove programs and uninstall it . then reinstall it . up date as there may be a new driver for it.
Feb 25, 2015 | Sharp Ar-208d Duplex Copier, Printer,...
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5320 Black and White Copier
Dec 29, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL1644 machine does not operate as a photocopier
Do you have any status lights on? If not then you may just have a print button that needs repaired. I have seen this a few times on this series. Try pressing down firmly on the print button while wigging the button around in a circular fashion. If you work a it and all of a sudden the machine makes a copy then the solder connectioons for the print switch have worked loose and will need to be re-soldered. Pretty simple repair. You may have someone locally that can do it. The operation panel comes off pretty easy and the circuit board with the switch is right under this panel. It is a small "button" type switch with small solder contacts that break loose. 10 minute job if you know what you are doing. 20 minutes if you dont. Just need someone with a solder iron and a little skill.
Good Luck and Thank You for using Fixya.
May 06, 2010 | Sharp AL 1631 Copier
Please .. my Photocopier sudunly stop and find
My Sharp is a different model but my reset is:
Hit:
Clear (then)
Auto (then)
Clear (then)
Auto (then)
14 THEN
Start
It resets itself.
Oct 06, 2009 | Sharp AR-207 Copier
Sharp AR 5316 E photocopier error clearing
Try reset by pressing [#] [interupt] [C] [interupt] [1] [6] [start]
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
14 people viewed this question
k24674
jasbo
jasbo
