Question about Konica Minolta magicolor 7450II Laser Printer
Konica minolta c353 error 1 llegar operador 0x1
  • Konica Minolta Master
  • 6,161 Answers
Have a tech come out from what you stated you have a abort code need to have the firmware re flashed
Posted on Jan 18, 2016
osiriscompu
  • 16 Answers
SOURCE: konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Posted on Jul 19, 2008
herminio_hal
  • 210 Answers
SOURCE: I need to scan to email using the c353 konica
This are the the information you need to setup scan to email and maybe you know how to access the web browser to setup the network. first you need to know the smtp host name or ip address, second you must create a valid email address for the copier. To access the web browser input the ip addrress and press enter click administrator and the password is 12345678 or 8 zeros. there are tab system info print, scan and network. click the the scan tab. choose scan to email first thing you will see enable scan to email smtp ip address or host name. enter the right smtp. witch this you can get to your mail server. do not change the port # and that is 25. Input administrator email address and the machine email address and turn on the authentication enter your user id and a password iof there is any.
Posted on Aug 11, 2009
  • 5 Answers
SOURCE: Konica Minolta C353 has a C4551 error, how do I fix it?
try replacing the imaging unit with a new one not a reset imaging unit
Posted on Sep 02, 2009
  • 12 Answers
SOURCE: Konica Minolta C353 - Error Message C-4554
The C-4554 error identify a Laser Malfunction (K).
You could check flat cable that connect laset to logic unit.
Chech all laser K cables/connections.
If persist you have to change Lasers group.
Bye.
Posted on Oct 14, 2009
Testimonial: "Thanks for this helpful reply!!"
  • 7 Answers
SOURCE: i am having this error message with my konica
This is a tcr fault with the black i/u check the toner or i/u if tone has just been replaced check the seal on the unit sometimes the break and no toner comes through =if not look at replacing the i/u
Posted on Mar 04, 2010
How do you fix code error 5102 on konca minolta bizhu c353
check the paper draws and registration assembly. or might have a burned out transport motor worse case main board
Jan 23, 2017 | Konica Minolta Minolta Bizhub C353 Copier
C0202 bizhub c353
open the draw check for any paper behind it, THEN REMOVE ALL OF THE PAPER SITTING ON THE LEFT SiDE OF THE DRAW
NOT A STORAGE AREA. for 11 x 17 paper
Feb 05, 2014 | Konica Minolta Bizhub C353 Copier
C-4152 error c353 bizhub
magenta LASER located under the Magenta (red) image unit
Dec 23, 2013 | Konica Minolta Minolta Bizhub C353 Copier
KONICA MINOLTA C353 ERROR CODE C-5102
hi tracey, 5102 is a main motor failure, it is possible for there to be paper jammed tight in the fuser unit, if not this will pretty much be guaranteed to be the main motor
Nov 11, 2013 | Konica Minolta Bizhub C353 Copier
"konica minolta bizhub c353 error code c-4154"
"konica minolta bizhub c353 error code c-4154" help
change the chip and the imaging unit and still the same
what else I can do ??
help me please?
Thank you ...
Mar 09, 2013 | Konica Minolta Office Equipment & Supplies
How to clear error code c 3421 on konica bizhub c353
While holding down the utility/counter button and turning on the machine go to screen that say trouble reset press it says OK that power off and turn on again if comes back need a fusing unit.
Mar 13, 2012 | Konica Minolta Konica Bizhub C353 Drum...
I have problerm with konica minolta c353 .. the error code c4554 showing on display. i cant printing....
this is an easy fix, have you had your fuser replaced recently?? if so then it needs reseated or just do a trouble reset. ask me if you need help with that
Dec 19, 2010 | Konica Minolta Konica Bizhub C353 Drum...
I have konica minolta bizhub c353 i have problem
Most likely it is your magenta cartridge or magenta developer unit.
did you recently change cartridge?
Are you using original cartridge?
Nov 13, 2010 | Konica Minolta bizhub Office Equipment &...
Konica Minolta magicolor 7450II Laser Printer Logo
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
