DSE DVB T GH5912 Set Top Box User Manual? Where to get one?
Have just been given a DSE DVB T GH5912 Standard Definition Set Top Box - and it has no user manual with it - I have no clue what on earth I am meant to do with it other than having hooked it to the tv - cant seem to get it to talk to the tv so not sure if I have the cables in right... its an old Panasonic TV - big boxy type so pretty basic as far as it has an antenna cable hole and the Audio/Video cable holes - so not hard to figure out which goes where there... lol Cant seem to find a manual online for this Set Top Box... can anyone help?
HDTV GURU
  • 261 Answers
SOURCE: Sony Grand Wega KDF-E50A10 showing msg about unauthorized content HDMI
Did you select the output of Cable box to HDMI out? I think it is in the menu setup on most cable boxes. It maybe active but if it isnt, try this.... Hold Menu button down and see if setup menu comes up and then toggle with arrow buttons on front of settop box and try and select HDMI if it is in there. Also make sure settings are on in the T.V. menu as well. Let me know and we will continue. Thank you ...GURU JAY
Posted on Feb 06, 2008
phongnv
  • 56 Answers
SOURCE: start up settings.
Go to main menu and do a rescan for channel.
Posted on Feb 17, 2009
  • 128 Answers
SOURCE: Sound only works with HD, not SD
Check the setup menus of the Insignia TV, as most sets have an advanced setting hidden deep in the setup menu to use the HDMI cable for sound - OR- use component RCA inputs for sound. My Philips TV has this.
It's odd that this only shows up for SD content...I would see if there is a firmware update available for that from the manufacturer. The one thing that you see lots of firmware fixes for are HDMI issues.
Posted on Oct 16, 2009
  • 1779 Answers
SOURCE: Ok I have no skills
OK! First, you have NO TUNER in that model. It's called a monitor. You have to use a cable box, satellite receiver or use an older style vcr with a tuner in it. With the vcr you won't see HD stations that broadcast in HD. You will see the old style analog.
Posted on Dec 10, 2010
Testimonial: "Thanks, now i just have to find a vcr.. Is willing to try anything at this point. Thanks."
SOURCE: hooking cable to tv
I have a protron tv and unable to hook the cable box staight to the tv. what am I missing.
Posted on Jan 23, 2011
How to tune channels on a 14 inch RCA tv?
You need a good set top box, either Hi definition or standard Pal, to make any CRT Television work. These days, non digital TV do work well but they no longer accept analog signals, but when connected to a set top box that receives digital signals, the box converts the digitals signals to analo and sends then to the RCA inputs of your TV and not via an antenna connected to the set top box and the TV.
Sep 01, 2014 | Televison & Video
DSE IR CODE G7503
You're asking about the universal set-up codes to this TV; I assumes, and posts this solution. 1157 1052 1130 1142 1027. These are the codes to check. If you wish to get more, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option.
Jul 23, 2013 | Televison & Video
I have purchased a JNC DB961 Set Top Box but It does not have instructions so I do not know how to install it.
It's a standard definition set top box for high definition channels, I'm an idiot for buying it too
Sep 03, 2011 | Televison & Video
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
No problem, I just want to know if this tv has a digital tuner? It says it has a "digital comb filter". Is that the same thing?
A digital comb filter is not a tuner. It helps improve the appearance of digital content by splitting the luminance (brightness) and chrominance (color) of a digital video signal (DVD, or other set-top box). This filter is only needed when digital content is going to the TV over RF (coax) or composite (analog) inputs. http://electronics.howstuffworks.com/tv-buying-guide18.htm has some details on the filter,
Please provide the model number of the TV for additional information about the tuner. Normally the tuners will be listed as NTSC (analog), ATSC (digital), Clear QAM (unencrypted digital cable) in the US. In other countries you have PAL (analog) or DVB-T (standard definition digital terrestrial) or DVB-C (standard definition digital cable) signals.
I hope this helps.
Apr 15, 2011 | Televison & Video
I've BD 512 universal remote control,and i need code for Durabrand DVB-T CG5660-M digital set top box.Please help!!!
i need code for a durabrand dvb- digital set top box me remote is a bd-512 universal remote control
Jan 14, 2011 | Audio Players & Recorders
I have a Alba DVB-T set top box wont change channel
I think you most likely have a failed box problem.
Feb 17, 2018 | Televison & Video
Televison & Video Logo
124 people viewed this question
Top Televison & Video Experts
