USBSTOR \ DiskFly_____DS103_FLASH_DISK6225 - Computers & Internet
Cant install u-disk to pc
Do you have internet access with this computer?
If so, you should be able to google the brand and model number and find a driver to download.
I would give that a try.
There is no need to reinstall windows to fix this. The driver or inf file is damaged. Visit another computer with win xp, search for files named usbstor. Copy files usbstor.inf and usbstor.pnf into windows/inf folder and usbstor.sys into windows/system32/drivers. Now just search for new driver and that's it, usb storage will be recognized.
Car Transmissions
Jun 12, 2012 | Audio Players & Recorders
Have a ASUS Eee PC 1005 (?). My 500GB USB hard drive won't work. Either not recognized at all or disconnects while in use. Error code 43. Does this on more than one computer windows vista and windows 7...
Hi
The issue here is with your USB 500 GB hard drive.So you need to try to connect the same hard drive on any of your friends computer and check if it works.
So try to connect any other USB device like flash drive and check if USB port is functioning properly.
If the flash drive is not getting detected then the permissions have been revoked.
You need to login as administrator, if your are the only user then login with your ID on start up.
Press and hold the Windows sign key( Do not release) and press R key, this opens the run command box.
On the command box, type "inf" and hit enter key
Go to file name " usbstor " and " usbstor.pnf" and right click and go to properties and select security.
Under Group and Names, sellect your login ID and check for permissions at the below of the same screen.
If it is not under full control then USB device will not get detected.
You need to edit the permissions and get full control.
Hope this helps you.
Thank you
Gowtam R
Jan 06, 2011 | Computers & Internet
Old maxtor 3200, new computer windows 7. how can i make it work/
Maxtor manufacturer says that this drive is not ready for windows 7 and no driver had been issued. you will have to connect it to another computer to recover the data, or to use another computer in your network to access it and share the resource with your pc with windows 7
Apr 28, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
When I would connect it, it would start up and load on my computer with no problem and now it doesn't. The green light around the circle turns on but it doesnt load on the desktop. What do you think the...
First see if it works on another machine. if it does plug it back into your PC look at Device Manager: See if you have any yellow ! 's under usb devices. If you do right click and install the apropriate driver.
Then I would look at your USB Drivers
c:\windows\system32\inf\usbstor,pnf
c:\windows\system32\inf\usbstor.inf
c:\windows\system32\drivers\usbstor.sys
if they are there make sure you and SYSTEM have permission to them.
Sep 09, 2009 | Western Digital My Book (WDG1U1600)...
Transcend connection
For all of you who are unable to make USB drives work or still are getting the “USB Device not recognized”, try this method.
Download usbstor.inf and usbstor.pnf files (links are below) and copy them to
C:\ windows\inf  folder.
(click yes to overwrite the files if windows asks)
Remove the Unknown device from the Device Manager - Other Devices.
Inserted the USB drive and lo and behold! It should be recognized in a jify!
usbstor.inf and usbstor.pnf can be downloaded from here:
http://www.infdump.com/download-inf-files_new.php/inffiles/U/USBSTOR.INF/5.1.2600.0/download.html
http://www.pnfdump.com/download-pnf-files.php/pnffiles/U/usbstor.PNF/download.html
Hope this helps for everyone whose USB drives are still not recognized.
Regards,
Deboo
Jan 22, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Transcend 4 gb pendrive,after inserting into pc,again it si asking insert disk.it is not opening.i have done formatting also.no jetflash driver with me presently.ose help me
Hello Kannan,
Download usbstor.inf and usbstor.pnf files and copy them to
C: windowsinf folder.
Remove the USB Mass Storage Device from the Device Manager (Start -> Run then type devmgmt.msc  and press Enter)
Insert the USB drive and lo and behold! It should be recognized in a jify!
HTH,
Regards,
Deboo
Jan 11, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb transcend not detected by the computer
If getting the “USB Device not recognized” error, try this method.
Remove the Unknown device from the Device Manager - Other Devices. (Start -> Run then type devmgmt.msc  and press Enter)
HTH,
Regards,
Deboo
Jan 09, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Need help downloading and installing driver for hp photosmart C3100 printer said required section usbstor.inf not found xpsp3
Search your computer for the USB inf file usbstor.inf. Is this the first USB device you have ever used? What is the operating system on your computer? It appears as though it is searching for the Microsoft Service Pack 3 for XP, and can't find the file within the service pack, or the service pack. Have you recently installed MS updates?
Nov 19, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
