Question about George Foreman G5 Indoor Grill
Dropped it and cracked case grp2841r - George Foreman G5 Indoor Grill
How do I repair the plastic base on the bottom side of the projector? Plastic base cracked?
In many cases you can contact the projector manufacturer for replacement parts, The plastic (also known as the chassis) can sometimes be purchased separate. Although a crack should no effect the projectors operation unless it was dropped hard enough to cause a crack.
Nov 29, 2014 | Office Equipment & Supplies
My son said he spilled soda on his dsi... it didnt get that wet but i think he dropped it. The bottom screen is a little faded and has lines in it. it still plays. is there a way to fix the lines?
No there is really no way to fix it unless if you ask the creator of of the dsi because the drop sorta cracked the screen of it. Depending on the side, top, bottom, back, where ever, it still cracks not necessarily crack but it has been to the point when it can't be fixed. The same problem happen to me except the case was that I dropped it a little more harder and the screen totally went black.
Mar 04, 2013 | Nintendo DSi Matte Blue Console
The modem has a crack on it could this effect it working properly or interfer with the signal?
A cracked plastic case will not interfer with the wireless signal unless the wireless router has been dropped on the floor.
Feb 11, 2012 | NetGear WGR614 Wireless Router
Crack on screen
So I don't understand I have had an HTC Touch Pro and I dropped it once my lady a few times and the only thing I ended up with is a couple of scratches on the corner of the body. Then I get my EVO which is a major upgrade for me and love it, then I drop it on my way out the work trying to prevent it from falling I try and catch it but ends up hitting the floor from about 2 - 3 feet and the screen is freaking cracked all the way through. I just had it ghost armored and was about to get a case for it but of course it looks like I waited to long for the case but I am also thinking it wouldent have helped.
Aug 11, 2010 | HTC Touch Cellular Phone
Dropped projector
It may HAVE fractured the solder connections to the RGB connector OR worst case may have cracked the circuit board to the connector.
Resolder the connections AND if necessary, bridge jumpers around the board cracked circuit traces.
Nov 23, 2009 | Hitachi Performa CP-RS55 Multimedia...
I was wondering if there are any known problems with the casing cracking from too much pressing? Mine cracked from the power button up to the menu button and back down to the home button. thanks
It usually happens if you dropped your phone, the casing cannot be broken by only pressing it. Even if you try to press the casing too hard, it won't break off, so it might have been dropped by you or someone else.
Sep 23, 2009 | HTC G1
MacBook Case cracking
Does it get stuffed in a bag or locker with other items? Is stressed placed on it? Nothing just cracks on it's own. There is no known Apple service programs for cracked cases, only discolored ones. You may want to re evaluate the life of the laptop, especially if it's constantly transported. Has it ever been dropped?
Aug 25, 2008 | Apple MacBook Mac Notebook
Casing crack
change the mobile panel and put cover to the mobile! if display have cracks mean buy display stickers and paste it to the display! just try it
May 07, 2008 | Palm Treo 650 Handheld
Archos 604
point pressure when you are carrying it can easily crack the screen. No dropping necessary. I bet something got pressed up against it when you were carrying it in something and you didn't have it in a hard shell case! If the screen is cracked, your best bet is the $150 repair from Archos.
Nov 18, 2007 | Archos 604 Digital Media Player
George Foreman G5 Indoor Grill Logo
Top George Foreman Kitchen Appliances - Others Experts
Mike
Gerry Harvey
Gerry Harvey
Angel Joseph Jr.
Angel Joseph Jr.
Are you a George Foreman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
