Question about Refrigerators
FRIDGE NOT COOLING
I opened the fridge to clean up spilt jelly. I took out the compartments to wash and had the top door compartment out for a few hours. I didn't realise until later that the top door compartment is needed to turn the light off and the fridge was really hot and had even melted things inside. I placed all the compartments back but the fridge is not cooling. the freezer seems to be but maybe not as cold as should be as the ice-cream is soft (but not runny). ALSO - whilst cleaning the freezer seal where the jelly ran into - the seal cracked open and filled with jelly that i cleaned out with a soft cloth. Are my cooling problems to do with the cracked seal (top part on the freezer) or has it overheated from the interior light??? or something else????
2 Suggested Answers
mikedurland
  • 481 Answers
SOURCE: American fridge/freezer, over the last
  • yes, refrigerators have heaters in them to defrost the buildup of frost around the coils
  • they defrost approx. every 12-16 hours
  • if the defrost cycle gets stuck then it will continue to heat
  • i have seen it melt the plastic inside the refrigerator
  • possible causes:
  1. bad defrost timer
  2. bad thermo switch in freezer
  • i would replace both as they are not expensive
Posted on Jun 29, 2008
Why does my refrigerator circulate on bottom but not on top
Is this is a bottom mount fridge? Hey if your fridge is a fairly a new one. Say less than 8 years old and a fancy one then this is how it works.
a) Fan in freezer circulates air. Mainly to the freezer compartment.
b) Then for the fridge compartment there is a Vent door operated by a vent motor.
Either this vent motor not working and opening, or it is frozen or the thermister that controls the temperature on Fridge compartment is not asking for cooling and thus not sending power to the vent motor to open.
Sep 09, 2014 | Sub-Zero Refrigerators
Hi, I have a Maytag (MFD2560HES) fridge. The Freezer is working but the fridge is not cooling. What could be the causes? Alton.
you need to check and make sure the evaporator fan is running in the freezer compartment while the unit is in the cooling mode if it is then check the damper in the top of the fridge and make sure it is opening all the way to allow the cold air in the fridge.if ti does not open it needs to replaced.
If the fan is not running it needs to be replaced also check for excessive ice build up in the freezer compartment that would also block the air flow
Feb 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
Water leaks on to the floor from our whirlpool fridge
normally the pipe that drains the water on top of the compressor is a bucket that catch the water the pipe blocks sometime then needs to be opened again with a piece of wire
normally sits in the refridgerator compartement under neath the cooling plate
Oct 23, 2009 | Whirlpool Refrigerators
The freezer is working but the refrigerator is not
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Oct 01, 2009 | Dometic RM2652 Refrigerator
Both Freezer & Fridge compartments not cooling
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath. If that don't work you may be low on freon change fan motor
Aug 12, 2009 | Refrigerators
No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad.  When doors are opened, the fan stops.  No cooling.  When it closes, fan starts.  Bulb is just an indicator of no power to unit...probably burned out contact in switch.
Nov 12, 2008 | Refrigerators
Refrigerator stopped working, freezer works fine
I turned off the refrigerator and left the freezer door open so the coils and the vents could thaw out. The cold air was not getting to the refrigerator section because of ice blocking the vents.
May 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
22 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
