Monitors
Problem for Monitors
Generic problem for all Monitors
3yr old got ahold of monitor
By Suella on Oct 27, 2007
We have an older computer that I had decided to give to my 5 yr old daughter so that she could play with educational programs. Well no sooner than I had it set up and running perfectly fine, I caught my 3 yr old daughter pushing on the buttons on the front of the monitor. I found the monitor black with the green light next to the power button flashing. I tried to push buttons on both the keyboard and the monitor to get it back up. The only time I receive a response is if I press and release the "MODE" or the "SELECT" buttons. I get a window that pops up that says "SELF DIAGNOSIS" across top of the box back-lit in white and underneath back-lit in blue is "PC DISPLAY SETTINGS CORRECT?" and after about 3 seconds this disappears all the while the green light next to power button is still flashing. Now if I hold the power button on tower to turn computer off since I cannot see "Start menu" on monitor then turn it back on the monitor does come on normally but it only goes as far as showing the "Microsoft Windows 98" screen then I get the cursor in the upper left as if the screen that allows you to put it into doss is about to come up. The monitor goes to the "SELF DIAGNOSIS" window that I described before and the green power light starts flashing and then screen goes blank after about 3 seconds. If you can please tell me how to correct this I would be greatly appreciative.
Comments:
Oct 27, 2007
- I went to safe mode like you suggested wasn't sure what to do when I got there so I reloaded the driver for the monitor then restart the computer put it back into normal mode then it went back to the original problem. Does this mean I can only use my monitor in the safe mode?
Best Solution
posted on Oct 27, 2007
Helpful)
24 seven
Rank: Wiz
Rating: 82%, 1405 votes
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Comments:
Oct 28, 2007
- no. if you have winxp, then go to safe mode again and look for the system restore utility (start>all programs>accessories>system tools>system restore. run it and choose a restore point before this happened. maybe a registry problem...? this should cure it.
Was this helpful?
Yes
No
Popular Solutions for Monitors
Questions and Unsolved Problems for Monitors
Answer
i have an acer 17 in flat screen monitor, the left side is dimmer then the right side and the whole... (More)
Answer
My LG monitor show a message saying that the monitor is entrance sign out of scale
Answer
i want to degauss my monitor, but the monitor menu is blank. how do i get around it?
Answer
hello there, my problem in the monitor was, its always change in color every time i touch the... (More)
Answer
I have a HP Pavillion VF15 monitor and sometimes the power button does not turn the monitor on. Is... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Monitors:
Top Monitor Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
