How do I tune my DSD 3 u decoder to my TV
I have just bought a DSD 3u decoder> I am trying to connect it to my old 54 Samsung TV. I am having no success.
5 Suggested Answers
  • 15 Answers
SOURCE: SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Posted on Dec 30, 2007
SOURCE: how do i tune in a 3 year old philips hd flat
my philips 32 inch flat screen doesnt give me freeview anymore when i scroll down to digital tuner i just get a blue screen
Posted on Jun 10, 2010
SOURCE: My decoder - dsd 1131
Don't worry about it. You have mistakenly pressed Shift + exit. What you need to do is to press Shift + i. What you have done is used by the people using two decoder. They use it to switch between the two decoders.
Posted on Dec 30, 2010
  • 910 Answers
SOURCE: I have a Panasonic TH-P42S10Z
You can't connect your TV direct to the dish. It needs to be connected to a sky decoder to be used.
If you've got Freeview built in to your TV you'll need to have an external aerial fitted if one isn't already their.
Is their an external aerial and I'l look into the setup procedure for tuning the TV.
Posted on Jul 23, 2011
DSD 1131 does not respond to a new remote control which is exactly the same as the old one. the remote is not faulty because itworks with other decoders
Some remotes , while looking the same on the outside are much different on the inside. Example: Two remotes in a household with 2 decoders in different rooms. To eliminate one from interfering with the other, each remote is matched to its decoder.
Jul 24, 2016 | Televison & Video
Model PS51E550D1MXXY. I seem to have lost channels Now im missing channels even after i press the auto tune channels option & the ones i do have are not clear at all
Hello there,
First I will put the problem straight to you, which is that your television is not connected to the Satellite source you have, be it local satellite or decoder.
1. You need to check first the connection to any antenna source or decoder.
2. Go check the direction of the antenna or decoder, trace the wires for any breakage (if any see to it that its properly corrected and taped),
3. and see to it that all plug ins are properly connected i.e. RF connector,
4. check to see that the decoder is properly connected to a power supply and turned on.
5. Turn on your tv, go to your auto tune and search again or you can do a manual search.
After that, it should work perfectly once again.
All the best with that.
Take care
Dec 06, 2015 | Samsung Televison & Video
How to take off analog
Either
buy a new television with a digital decoder / receiver
or buy a digital tv decoder that outputs AV on RCA cables whatever the tv has. may be able to tune tv into a particular channel analogue on some decoders. Check decoder and TV input sources. May not have AV input if really old TV.
see
http://www.wisegeek.com/what-is-a-digital-tv-decoder.htm
Apr 21, 2015 | Televison & Video
How do i hard rest the dsd 3u decoder its failing to boot, its just showing the orange light
download the software on net
put the software on 256mb pendrive
insert and flash or update
Nov 18, 2014 | Computers & Internet
My decoder Dstv dsd 3u doesn't response to the remote what should I do cause i need to add volume
If you have extra batteries, try to replace the old one and install the new batteries. And if still doesn't work, try to clean the battery terminals of the remote control, because sometimes, those are the one that making the problem due to corrosion caused by leaked batteries.
Aug 04, 2014 | Televison & Video
How do I setup 2 tv,s on a single view dsd 1131 decoder, 1 tv and decoder upstairs an 1 tv downstairs. The dish is already installed and can rust very easily for the area.
very simple ,, the tv next to the decoder must be conected using a rca cable and then run normal tv cable (RF out ) to the other room
Apr 04, 2013 | Televison & Video
Our remote will not change channel and we can not change channel from the TV either. We have changed the battery and cleaned the front of the TV.
The tuner in the TV is bad. Try connecting a regular decoder box and tune that instead. Make sure your source is selected for the box.
Nov 03, 2010 | Samsung Televison & Video
Free to Air on a Dstv
how can i have codes to tune east african channels plis for free. am using dsd 1131 decoder of dstv. am in johannesburg.
Jun 18, 2010 | Televison & Video
HOOK UP
Hi there!
If using an RF Converter you will have to tune whatever you connect to it onto UHF Bandwidth until it locks. You would tune it like you would tune any other station. So as an example tune a tv station onto CH1 and the DVD onto CH2 etc. Regards and good luck. JUS004
Apr 01, 2008 | Televison & Video
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
