Question about Philips HTS3100/05 Theater System
No Sound From philips hts3100 while playing dvd
2 Suggested Answers
  • 1456 Answers
SOURCE: My Philips Dvd home theater
Hello
1. First things first, READ the Instruction Manual, I know most of you guys out there hate reading the instruction manuals but every system is different, so I'll generalize this article for an average system you can find at a retail store today.
2. Make sure you have the right cables to connect your TV to your Home Theater System, now days the best connection is called "HDMI" (High-Definition Multimedia Interface) this cable uses a digital signal to transfer both video and audio while giving you the best quality possible. But please make sure your Home Theater System has the "HDMI" as an input option. If it does not, you might have to resort to a analog connection such as "Component Cables" which will provide you with a High-Definition connection but with analog quality.
3. Now if you are using a current TV and a current Home Theater System and your system is able to use the "HDMI" cable, connection to said devices will be pretty easy, just hook one end of the "HDMI" cable to the "HDMI" input on the back of the TV, and the other end of the "HDMI" to the "HDMI" output on the back of the Home Theater System. Turn your devices on and make sure your input/outputs are configured for "HDMI" usage and vola! You should now be able to see and hear everything your heart desires!
4. Organization is key, after you have checked your connections and everything is working the way you want it to, utilize the cable/wire loom to organize your cables and use the zip ties to secure them in place, not too tight though, if you want to change things around in the future it's easier to cut the zip ties if you have enough room between the cable and the zip tie.
THANK YOU
Posted on Jan 27, 2011
Philips HTS3100 tray will not open. Is there a manual 'paperclip hole' way to open it?
No there is not. You have to take it apart to remove the disc that may or may not be in there.
Sep 25, 2016 | Philips HTS3100/05 Theater System
My Philips DVP2800 Region 2 DVD Player With DivX will play pictures but there is no sound
go to settings ,change sound settings to bg or another frequency settings
Jan 21, 2015 | Philips Televison & Video
I have an hts 3100 philips home theater dvd player it plays some dvd's and some others not(coming the message no disc) Can you help me about it?Why does this happen?
Hi, is your DVD player anew one?if yes the lens that makes the CD play is not OK.But if it's an old one, you can get DVD lens cleaner toclean up the lens of the DVD player...
It's the problem of dirt inside the DVD player especially the lens area.
After cleaning up the lens and still does not play, you will need to replace the DVD player lens with anew one..
You can go to the nearest repair outlet for replacement of the lens ...
Hope you understand..
Take care...
May 04, 2011 | Philips HTS3100/05 Theater System
NO SOUND AT ALL. JUST PICTURE . HAD BEEN WORKING. TV WORKS FINE. DID NOTHING WITH CABLES
these is a various situations, from tv set to speakers internal circuit problem.
has high quality cable connecting from dvd to tv? normaly low quality cable has some pins contact problem and falling on perfomançe.
need you test these steps and post your results.
Jan 03, 2010 | Philips HTS3100/05 Theater System
When i connect to the tv the output was blurry
there isn't enough information. How can i help you? What did you connect to the TV? a VCR, a DVD or what? I am waiting for your response.
Sep 18, 2009 | Philips HTS3100/05 Theater System
Error display no disc
the problem is with your dvd players optical pic up .remoove the cover and clean the optical eye cairfully with cotton bud.(remember this is eye treet it very smoothly).then try again or use head cleaning cd.after that it will work .otherwise you have to change the optical lense to check wether it is problem with circuit or lence.
Jan 08, 2009 | Audio Players & Recorders
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
Philips home theater system
Recheck that you hooked it up exactly as stated in the quick start guide. If there is no sound when playing DVD, return it immediately or call Philips to get replacement. If you get sound when playing DVD, but from no other sources, then make sure that the end of the cord NOT plugged into the Philips says OUT or OUTPUT - many TV's do not have outputs.
May 24, 2008 | Philips Audio Players & Recorders
37pf7531 tv
If you have a later Philips home cinema model: HTS3100, 3300, 3500, 3154, 3357, 6510 & others, the sound from the TV will go through the existing scart connection.
Just select TV on the home cinema remote control.
For any other models, use a scart - twin phono lead (red & white), from the TV to one of the inputs into the home cinema.
Scarts 1 & 2 on the TV will have different results. Try both.
Nov 29, 2007 | Philips 37PF7531D/10 37 in. LCD Television
No CD sound on Philips DVD/VCR player
I havent seen this model But in the past I have heard this problem arise. It turned out that there was a mute button for the cd only on the remote and there was no indicator to show it. check for a cd mute or go into the cd play menu and check around in there.
Mar 23, 2006 | Philips DVD740VR DVD Player/VCR
Philips HTS3100/05 Theater System Logo
53 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
