Question about Whirlpool Heating & Cooling
1187842 need power cord for whirlpool 1187842
I have a whirlpool dryer model #LER5636EQ3 which the power cord was missing upon aquiring it, the wall socket in my laundry room is a 50amp, so I need to know if a 50amp power cord would be a proper...
The recommended power cord is a 30 amp 3- or 4- wire cable. A 50 A cord could cause a problem by allowing a surge to the dryer motor and damage the dryer or start a fire. There are 30A to 50A adapters (see RV and boat supply vendors). The installation instructions for the LER5636EQ3 are available here: https://www.whirlpool.com/digitalassets/MLPDF/Installation%20Instructions%20-%203397618.pdf . See page 5 of the PDF.
Note: the 50A outlet has a 50A circuit breaker protecting it. If you swap the outlet to a 30A outlet, you will also need to replace the breaker with a 30A one.
I hope this helps.
Feb 01, 2013 | Whirlpool Dryers
My dishwasher did not come with power cord. what kind of cord do it need and how do i connect the cord? On the new cord how will i know which one to connect to the white and black wire? The dishwasher is...
120 Volt 16 gauge, 3 wire power cord.
Brass Screw is Black, White Screw is is Common, Green is Ground....Try Home Deport for a cord. If no screws are on the dishwasher, use wire nuts and elec. tape
Jun 13, 2010 | Whirlpool 24 in. DU930PWP Built-in...
Need to replace power cord on Whirlpool RF367BXP what color wire is the neutral wire and what colors are the hot wires for a 3 prong cord
Here is a picture on how to wire the range.
The black and red are the hot wires and the white is the neutral wire. the green is the ground you will not have the green with a 3 wire power cord.
May 31, 2010 | Whirlpool RF367 Electric Kitchen Range
I NEED TO REPLACE A POWER CORD TO MY SMALL AC UNIT
A hardware store will have what you need to repair. Tom
Jun 18, 2009 | Whirlpool Electronic Window Air...
Too many prongs on dryer power cord???
Do not just swap out the cord on the dryer. It has 4 prongs for a reason.
You will need to call a licensed electrician to change your outlet for the different service.
Jun 17, 2009 | Whirlpool Dryers
Duet 4.4 Washer (not steam) power cord too short
Hi, you might be able to find an 8 foot dryer power cord at your local building supply or hardware, or electrical supply store. It will be labelled for a dryer. First look at the dryer receptacle. The cords come in two types, 3 or 4 wire, so get the one that will match youyt receptacle. The wirte should be # 10 minimum.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool electric dryer will not heat up.
there are a few things to check out,< the outlet to unit needs to be tested for voltage on both sides, the power cord needs to be checked with a multi meter on ohm selection from end to end, the connection from power cord to power point,"junction", needs to be checked," looking at it you can tell if there is damage". If you find that everything is ok on power end then element is most likely problem. the power test is important because with 220 power source it is split into 110 for timer and motor and 110 for element operation, " if one side doesn't have voltage then it will not operate.
Apr 26, 2009 | Whirlpool Dryers
Cut cord
with the washer disconnected, remove the top panel. then remove the front panel until you see the motor where the cord used to go out. You will probably have to do some soldring if the cord can't be reattached. check where the power supply comes from and start from there. you will need to remove the old piece of cord and resolder the other part by splicing the cord and removing a piece of the rubber insulation.And resolder back on power supply.
Nov 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Power Suply Cord
If the cord is the ONLY item you need and NOT the terminal block in the dryer, then Home Depot sells replacement cords with a molded plug attached as well as ring lugs on the opposite end for terminating them on the dryer block. You'll need to know if you are using a 3-prong or 4- prong set up in order to get the correct cord. Hope this helps..
Sep 06, 2008 | Whirlpool LER3624JQ Electric Dryer
Heating & Cooling Logo
20 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
