Question about Delphi SKYFi3 XM Radio Receiver
Turn off skyfi3 - Delphi SKYFi3 XM Radio Receiver
Problem with the Delphi SKYFi3 XM Radio Receiver UNIT LOCKED UP WILL NOT COME ON OR GO OFF
Common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
You will need to update your firmware on the radio using the baby USB cable and the unit plugged into your computer WITH the battery recharged FIRST. Also, go to the www. xmradio dot com website and download the SkyFi3 FIRMWARE update. Then you need to download the "firmware update" into your SkyFi3. If this doesn't fix your lockup problem, you need to call DELPHI customer support, and they can tell you one more 'master reset' method. After the firmware update, it might take 2 or 3 'restarts'. Again, press and hold the Volume UP and PWR at the same time to reset a 'locked-up' SkyFi3. Regards, John
Oct 01, 2010 | Delphi SKYFi3 XM Radio Receiver
How do I use a new MicroSD? Unit locks up when Checking Media
First of all, suggest using an SD card of 2GB or under. Second, firmware update. Here's the details: This is a common problem with SkyFi3 units. You have to press the Volume UP button and hold it while you press the POWER button; this will 'reboot' your radio, then you can try it again to get it to go off.
My skyfi3 wont turn off. currently frozen on clasic vinyl with no sound
Try unplugging the power cable to force it to turn off. Wait for a minute or so, and then plug it back up. Try powering it back on- that should do it.
Feb 10, 2010 | Delphi SKYFi3 XM Radio Receiver
Delphi skyfi3 display blank. manual power only briefly...
try plugging the DC adapter directly into the buttom of the SKYFI3 - do you still get some sort of a power warning?
Jan 20, 2010 | Delphi SKYFi3 XM Radio Receiver with Car...
SKYFI3 WON'T TURN ON, PLUGGED INTO CAR AND WON'T TURN ON. PLUGGED INTO CELL CHARGER AND IT'S NOT FLASHING ON AND OFF
You need a special 5 volt 2 amp power supply for the unit, you cannot use your cellphone charger - not enough power.
Dec 01, 2009 | Delphi SKYFi3 XM Radio Receiver with Car...
My xm skyfi3 is on and the buttons will not work It is frozen up and I cannot get it to turn off or do anything. I have checked the button lock switch and it is off
Try this: "Reset your SKYFi3 by pressing and holding the volume button and pressing the mode button" (from user guide page 62)
Dec 13, 2008 | Delphi SKYFi3 XM Radio Receiver
Delphi SKYFi3 Problem
just hold down on all buttons.
Oct 18, 2008 | Delphi Audio Players & Recorders
Delphi SKYFi3 XM Radio Receiver Logo
46 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
