Question about Frigidaire FWTBB30DS Front Load Washer
Fwt645rhso What is the load capacity of this model?
How to reset washer
Thank you for your post, Friend. This is Z.
Your Frigidaire washer (FTW645RHS0) can be reset by two ways. You may either unplug it or flip the circuit breaker off. It is best to wait roughly ten minutes and then turn on your washer. I hope this proves to be helpful to you. If I can be of further assistance, please feel free to reconnect.
Sep 02, 2014 | Frigidaire Washing Machines
What is the capacity of fwt645rhso
Hi Friend, that's a great question!
I show that your Frigidaire washer, FWT645RHS0, has a total capacity of 3.0. Hope this helps! If there is anything else that I can help you with, please feel free to reconnect! - Z
May 25, 2014 | Frigidaire Washing Machines
FWT645RHSO drum is making a sound
Sounds like on of the chocks may have failed. Open the cabinet and look at the shocks to see if 1 or more have failed. Here is a link to the shocks in case you need them.
Oct 13, 2012 | Frigidaire ATF6000ES Front Load Washer
Fan on pump dont turn model fwt645rhso
Several things could cause this, but if the fan motor isn't burnt up then it's not getting power from it's source. Check the terminals at the motor and see if it's getting power or trace the wires back from the motor to see where it's origin is and check for power there.Gillight
Aug 15, 2012 | Frigidaire Washing Machines
What is the capacity of Kenmore model
This may or may not help.
http://www.managemyhome.com//mmh/lis_pdf/OWNM/L0305295.pdf
Nov 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
White-Westinghouse model la450mxw1 top load capacity in Kg.
I called Frigidaire technical support, they informed me that the capacity is 2.7 c/feet.
Nov 26, 2008 | Westinghouse WWS833ES Super Capacity Top...
Frigidare Front Loading Washer model# FWT645RHSO
check out the drain pump if drain pump is blocked up water will not get away quick enough and stop machine from spinning
if that is clear
turn bowl by hand and if you get a runble noise then the main bearings are gone
that will need dismantle and replacement or new machine
Mar 15, 2008 | Frigidaire ATF6000ES Front Load Washer
My FWT645RHSO front load washer does not fill with enough water.
Hello Twisted1,
If you have adjusted the level to reset and then to where you want it and it still won't fill to the level you want, I would suspect the level sensor in the washer itself. Most washers have to be switched to reset before setting a lower or higher water level. I hope it's as simple as the reset level switch for you.
Good Luck.
Feb 28, 2008 | Washing Machines
WHAT IS THE LOAD CAPCITY SIZE OF WASHER MODEL 110.20702990
On newer, and sometimes a little newer, Whirlpool and Kenmore (Kenmore is made by Whirlpool) considers a few things in determing capacity. Most of the inner baskets are the same size, but they also add in agitator action into the mix. A Kenmore with an auger top agitator would have higher capacity than a Kenmore with just a normal agitator, even though it has the same sized drum. So a super capacity washer would have theoretically less CLEANING CAPACITY than a super capacity plus. The agitator action is actually what determines capacity on these models. So, with that in mind, cubic load should be about the same on both units. Sorry that I had to go into "Bill Nye The Washer Guy" mode, but thats about the only way to describe. Let me know if I can confuse you any more haha. Seriously though, if you need further help or info, write back, and will try to get you some other information. Remember, this theory only works on top load "normal people" washers, not the front loaders.
Nov 22, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Open Questions:
See all Frigidaire FWTBB30DS Front Load Washer Questions
Frigidaire FWTBB30DS Front Load Washer Logo
98 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
