Cant getmy vintage Nad 1000s to conect with my nad 2200. I ONLY GET SOUND innone speaker. barley
5 Suggested Answers
  • 4 Answers
SOURCE: nad 214 amp
problem is- intermittent speaker relay. You can cleaned contacts or better upgrade relay to better one (sealed)  Dariusz
Posted on Feb 13, 2008
SOURCE: NAD 402 Tuner problem
It's sounds like a chip gave up the ghost. You may want to try
turning in on and off a few times to see if you can get the culprit
to function properly again. Electronics are strange creatures in that you can at times just shake them and they will begin to function properly again. A loose wire here or there, instead of any real problem.
However, if the problem's more serious, given the cost of servicing these products, you may be better off just going to Ebay and buying a used one.
I recently purchased a nice used NAD 402 with original box
for $58. Upon arrival I found that the backlight to the digital display was not functioning, however the display itself was, and the sound of the tuner is amazing. It is nearly the equal of many tuners which I have owned in the past at as much as 50 times the price.
Best of luck to you...
Posted on May 31, 2008
ziraffa
  • 827 Answers
SOURCE: NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Posted on Dec 20, 2008
Gurudristi
  • 98 Answers
SOURCE: Connecting NAD 314 Receiver\ preamp to Carver M-500t to speakers
Dear Tim,
Yes, you can connect your NAD as a preamp to the Carver power Amp.
Connect the NAD's pre-out to the input of the Carver Power Amp. You can then connect the Klipsch speaker to the Carver. Set the gain control on the NAD.
Now you should be able to control all the input and the main volume control from the NAD.
Posted on Mar 12, 2009
Nad av 716 protect
If your NAD amplifier is in protect mode with no speakers connected, it will be necessary to open it up and check for internal component failure.
Jan 05, 2015 | NAD Audio Players & Recorders
Hi, nad going but no sound from speakers. can get FM but only up towards full volume.
Checker speaker wiring on back for shorts, if okay! the audio drivers and outputs are highly suspect, at this point I suggest a serviceman because of the complexity of the surround sound system.
Apr 20, 2012 | NAD T751 Receiver
Unsure of connections from nad c340 to power amp, cant get both speakers working
It sounds like you're guessing.
Have you looked at the manual?
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-C340-Amps-manual/id/8043dj588/t/2/
Page 7.
Tell us about the source(s) that won
Mar 25, 2011 | NAD C340 Integrated Amplifier
How to bridge 2 NAD 2200 amplifiers
See the picture:
http://wired4sound.net.au/systems/nad/nad.htm
Flip the switch to "bridged" and conenct a single speaker to the two red connectors.
Mar 20, 2011 | NAD 2200 2Channel Amplifier
Hello. I get no sound out of my AVR 7000 Receiver. No cables behind has been touched in the past. I'm trying TEST TONE, and everything seems normal in the display, but still no sound. I use Preout a NAD...
You don't say if all speakers are silent or just the ones to the unspecified NAD power amp. Do ANY speakers work regardless of which device powers them? Could the NAD be the problem?
Dec 25, 2010 | Harman Kardon AVR 7000
My NAD T763 turns on but no sound comes out of any speakers
HI,
I had the same problem and AH reset did not work. IS there anything else i can do?
Thanks
Adrian
Dec 02, 2008 | NAD T763 Receiver
Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
Sep 24, 2008 | NAD Audio Players & Recorders
NAD 502 CD player LCD problem
hey, well, typical problem i nad cd players, and also receivers by the way. The proble are tha nad use standard glow lamps. And as we know, the blow!! And often when you move around with the cd. Well i do have repair note for this one also. http://www.miguelovitch.dk/ go to the menu: 'amplifier repair notes' (yes includes cd players ;) ) Here you can find free amplifier repair notes, an go fore nad 705 repair fix (same fault with defect bulb's as in you nad cd) And also a technical repair movie showing you the hole process of the 'workaround' this fault i NAD 522 (NAD 501, 502, 512 and more) http://freemovies.s-educator.org/repair_movies/nad/nad_cdplayers_defect_lamp_in_display_stremingvideo.html best regards michael miguelovitch
Sep 06, 2007 | Audio Players & Recorders
14 people viewed this question
 Grubhead
Grubhead
