Question about Lanzar SD54MU In Dash DVD/CD/MP3 w/ 5.4" Touchscreen 80 x 4 Watt
Touch screen white
Screen only shows white, however functions will work if I touch the screen.
Ipod froze
A white screen on an iPod Touch is the sign of a generic error, meaning you won't get a specific error message. Usually when this happens the white screen won't change and the iPod is frozen on that screen. Apple Support outlines a specific series of steps to take to deal with this problem, from turning the iPod Touch off to completely reinstalling the operating system if necessary.
What the White Screen Means The white screen is a sign that a software error has occurred in the iPod Touch. Unless you received an error message first, it's usually something near the root level of the iPod's operating system that caused the iPod to cease functioning normally. Rather than shut off completely, it goes to this white screen to let you know there's been an error. Unfortunately you usually lose unsaved information when this occurs. b> Resetting b> Try turning the iPod Touch off, then on again. This is the simplest way to reset your iPod Touch. If it remains stuck on the white screen, force a reset by holding down the Sleep button (top right corner) for about 10 seconds. The screen will go dark, then the Apple logo will appear. If it turns off and doesn't turn on again, the battery may be too low. b> Restore b> If a manual reset doesn't work and the screen remains stuck on a white screen, you'll need to restore the iPod to reinstall its operating system. Plug your iPod, via its charger cable, into your computer. Open iTunes and click on your iPod, then the "Restore" button on the main screen. b> Problematic Apps b> If you consistently receive a white screen while using a particular app, the app may be faulty or installed incorrectly. Try re-syncing the app to your iPod Touch and see if that solves the problem. Otherwise, you may need to delete the app to avoid the white screen problem.
b>
Jan 27, 2013 | Apple iPod touch
Touch screen working but it's not recognizing finger to chang
You need to calibrate the touch screen.
Try this:
Press Yellow key
On the key pad Press 1-9-9-3.
Press 5 times the red key (the 5th old a little longer)
(If everything is good in the touch screen shows an option "calibrate touch screen")
Try to touch there and will show a little arrow on each corner. With a pen click there to calibrate the touch screen.
Click exit and its done
Mar 08, 2011 | Ricoh Aficio 3025P Black and White Copier
SGH L700 is showing its screen complete white.there is no display on the screen bt other function is ok.
Oct 19, 2010 | Samsung SGH-L700 Cell Phone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
Touch screen not functioning properly. Press one key, get another
The touch screen on Garmin Nuvi 660 is not working at all. It turns on, but when I touch the screeen, nothing happens. Could it be the battery. It was low, so I charged it for 45minutes, then the gps screen dimmed and turned off after just 10-15 minutes of "messing with it"
May 25, 2009 | Garmin Nuvi 660 GPS Receiver
Droped iphone, screen is only white, touch screen works.
put it in DFU mode while connected to the computer. to do this, hold the home and power buttons for 10 seconds and then let go of the power but keep on holding the home for 10 secs. the screen will be black and nothing will show up. go to itunes and click on your ipod on the left. then click restore. this should work.
Apr 22, 2009 | Apple iPod touch
MY N1 LCD GONE WHITE
you have a damaged LCD screen ..
goo & get it fiiiiixed. yourwelcome .
Jan 24, 2008 | Sony Cyber-shot DSC-N1 Digital Camera
Lanzar SD54MU In Dash DVD/CD/MP3 w/ 5.4" Touchscreen 80 x 4 Watt Logo
14 people viewed this question
Top Lanzar Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lanzar Audio Player and Recorder Expert? Answer questions, earn points and help others
