Question about Sewing Machines
Elna Stella air electronic when put on buttonhole with foot will not do zigzag stitch
Will not make an automatic button hole. Went back and reviewed manual pages 32-33. Will not do a zigzag stitch. Unless manually. Have never had a problem in the past. Had it cleaned and tuned a year ago could something have changed then.
5 Suggested Answers
nikeananth
  • 267 Answers
SOURCE: I want to downlaod elna stella air electronic
hi,
this will help you ouy....'
http://safemanuals.com/brand-user-guide-instructions-owner-manual/ELNA
thank you for fixya,rate my answer
vijay
Posted on Sep 30, 2009
Tally Girl
  • 1133 Answers
SOURCE: i need a manual for the elna stella air electronic type 57 sewing machine
You could try www.diplodocs.com or www.scribed.com, I think I've seen it on one of those sites. Is the 57 the TX model? If so, its got the most stitches of the Stella models, there was the ZZ, TSP, SP and TX, nice machine. If you can't find a free one you should be able to buy one from one of the sites like www.sewingpartsonline.com or www.whitesewingcenter.com
Posted on May 27, 2012
Tally Girl
  • 1133 Answers
SOURCE: elna stella air electronic
you could try www.Scribed.com or www.diplodocs.com for this one free, otherwise pretty sure it can be purchased at www.sewingpartsonline.com or relics which is www.sewing-machine-manuals.com.
Should be a blue or brown cover I think from memory.
Posted on Jun 15, 2012
SOURCE: my automatic buttonhole stitch is not working on my elna sewing machine ,even when the lever is pulled down
you should a buttonhole button that must be pushed on the machine
either before you pull the buttonhole lever down or after to let the
sewing machine know what function to use, my sewing machine
won't let me make a buttonhole unless I push the buttonhole button
or yes, like you said the buttonhole foot could be damaged.
Posted on Nov 09, 2012
I need an Air foot control # 436310-20 for my Elna Stella TSP air electronic. How and where I can get this part?
I'd suggest www.sewingpartsonline.com if you are in USA.
https://www.sewingpartsonline.com/air-foot-control-elna-436410-20.aspx
Or you could try the Elna Guru, White Sewing Center www.whitesewingcenter.com, he's the specialist supplier for all things Swiss Elna.
The air control foot is the same for all the Elna Air Electronics, whether Stella, SU, TSP, TX etc.
Mar 20, 2017 | Elna Sewing Machines
Directions for making a buttonhole with an Elna SU
A transcript from the Elna SU manual reads as follows, and the manual can be viewed on line at http://sewingonline.co.uk/instructions/elnasp/
First make a few trial runs with a scrap of material exactly as the buttonhole will be stitched, with the machine adjusted as you intend to use it.
1. Use the embroidery and buttonhole foot. It can be chnged without a screwdriver by using the fixation screw.- With the stitch width knob at "0", turn the selector to zigzag "1".
2. De-center the needle to the left.
3. Set the stitch width knob at 2, with the solid mark on top.
4. Set the stitch length dial between 1/2 and 1/4.
5. a) Mark the desired length on the material.
b) Sew the first side of the buttonhole. Stop with the needle in the material and the mark (right).
c) Raise the foot and pivot the material round the needle. Lower the foot and raise the needle.
6. a) Set the stitch width knob at 4.
b) Sew a few stitches. Raise the needle.
7. a) Set the stitch width knob at 2.
b) Sew the second side and stop just short of the length of the first. Raise the needle.
8. a) Set the stitch width knob at 4.
b) Finish off the buttonhole by sewing a few stitches. Raise the needle.
9. a) Set the stitch width knob at "0".
b) Sew a few stitches to fasten the threads, holding the material back by hand.
10. Open with the buttonhole knife, which you will find in the accessory box.
Oct 12, 2014 | Elna Sewing Machines
How can I make a buttonhole that's bigger than my buttonhole foot will allow
Measure the button, mark the size of hole you want with a pin at each end. sew 6 full width very close zigzag stitches at one end ending on left side , then sew down to the other end with needle in left position with #2 width stitches, at other end again sew 6 full width zigzag stitches finishing on right side, turn work right around and sew back to other end again with #2 width stitches.
you should now have a rectangle of very close stitches with a very narrow gap between them down the middle. carefully cut between the stitches and you have a button hole.
Feb 25, 2014 | Sewing Machines
How to make a button hole
I don't know that machine, but generally on older machines, you put a buttonhole foot on the machine, set one of the buttons in the back-end of the slot so that it adjusts the size needed automatically. Then you set the machine stitch setting on 1 and set the width to make a satin stitch (a close zig-zag) down one side of buttonhole. You sew until the buttonhole foot makes the button hit near the foot; it will stop you, basically. Then you change stitch dial to 2 to make the bottom of the buttonhole, then 3 to make the other side, then 4 to make the top side. Then you remove the fabric and cut open the buttonhole (I use FrayCheck fist) Try some buttonholes on scrap fabric first, you will figure it out by trial and error.
If your machine is newer, they automatically can sew a buttonhole, but each one does it differently, Sorry.
Dec 09, 2013 | Euro-Pro Sewing Machines
Elna SU buttonhole- I can't remember the order to set the dials for the automatic button hole function. Anyone know? Thanks
sure, put on the buttonhole foot after putting a button into it and using the screw knob to set the length you want.
Turn stitch length knob and stitch width knobs to zero, (always set them to zero first to avoid wear on the stitch selection mechanisim) then turn the left stitch selector knob to the blue button hole symbol. Now turn middle knob stitch width, to the blue buttonhole symbol. Now turn right knob stitch length to blue 1, sew down the first side of your buttonhole until foot slide in the buttonhole foot reaches end stop. raise needle and turn stitch length to blue 2, and sew three bar tacks across buttonhole. Again, raise needle and then turn stitch length to blue 3 and sew back down otherside of buttonhole until you reach the end stop. Needle up, turn length know to blue 4 and sew three bartacks to end. there is a last blue symbol dot on stitch length knob, this will sew a stitch in place to tie off the ends. Raise pressure foot, remove your work and draw top threads to underside with a needle, and tie off or use a dot of fray stop. Done! if you don't have a manual you could email me and I'll send you a copy of mine, tallygirl98 at yahoo dot com.
Oct 11, 2013 | Elna 2007 Mechanical Sewing Machine
My automatic buttonhole stitch is not working on my elna sewing machine ,even when the lever is pulled down
Nov 09, 2012 | Elna Sewing Machines
HI, I have an old Elna Stella, bought in Australia in 1983. The shank that holds the presser foot onto the column keeps slipping forward. This causes the needle to strike the presser foot at the back edge...
Are all your sewing feet in one piece that screw on? I'm struggling understanding what your foot is actually doing Lindy; is it because the nut loosens up quickly? or is it possible that the foot you are using is not an Elna foot?
Elna later changed to "Low Shank" clip on feet with the Air Electronic range and these should be interchangeable with your Stella. I found a good website for this, www.sewingpartsonline.com and he has the "Pressure Foot Shank" which is the later swissmade shank for the swiss made Elnas. I couldn't see a replacement screw to hold on the feet though but a sewing machine dealer might be able to track one down. Or try Ebay, still some swiss Elna stuff out there.
good luck
Carolyn
Feb 05, 2011 | Elna 2007 Mechanical Sewing Machine
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
BUTTONHOLES
Yes, If you have a zigzag function use that. First you must keep the zigzag function stationary then set it to about a one or two on the stitch dial. Try that!
Sep 21, 2008 | Singer 7422
Changing stitches on a White 1418 sewing machine...
I have a White 1418. Here's how you do it:
1. Attach the buttonhole presser foot (should have come with your machine) and place the fabric underneath.
2. Set the stitch length knob to 0, the zigzag width knob to 5, and set the needle position to center. Sew 3-5 stitches.
3.Change the stitch length to 0.5, the zigzag width to 2, and the needle position to left. Sew to the entire length of your buttonhole.
4.Set stitch length knob to 0, zigzag width knob to 5, and needle position to center and sew about 3-5 stitches
5. Set the stitch length knob to 0.5, zigzag width to 2, and set needle position to the right. Pressing the R button (reverse button), sew up to the top stitches.
6. Remove the fabric and open the button hole with a button hole cutter.
Sounds complicated, but it's really easy. I love this machine, you just have to know how to use it!
Sep 18, 2007 | White Sewing 1418 Mechanical Sewing...
Sewing Machines Logo
65 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
