Question about Pioneer BDP-62FD Elite Blu-Ray Player
Sometimes has to be unplugged then plugged back in to be turned on
My tv won't switch on?
Sometimes this procedure will get an electronic device to turn back on. First check that your power cable is seated in the back - remove it and plug it back in if you can just to be sure. Then unplug the power cord from the wall. Press and hold the power button on the TV (don't use the remote) for 15 seconds. Plug it back in and try turning on the TV using the power button (not the remote).
If that doesn't work - try leaving the TV unplugged for an hour or so then plug it back in and try it again.
Good luck.
Sep 02, 2015 | Sansui Televison & Video
Dryer timer works perfectly but the dryer itself wont turn on. Ive tried unplugging and plugging back in, tried circuit breakers, none of that makes it turn on. Lint screen is clean. What do i do?
try unplugging, while unplugged hold in on button for 15 seconds, then plug back in and see if that works. sometimes on some models, it does a reset
Aug 27, 2015 | Dryers
THE SCREEN IS BRIGHT PINK
Could be in the set but if using a cable or sat box unplug them and wait a while and plug back---I have seen a reboot of a box cure this issue.
Jun 03, 2012 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
I have a Model TC32LX70 Serial MX72540116. I also have Verizon Cable. The TV set keeps going off and I have to manually turn it back on. Sometimes it will go off and cannot be turned back on but will...
Hello
If the power indicator is blinking on the front of the VIERA, turn off the TV and unplug all HDMI cables that are connected to the TV. Then unplug the power cable from the current power source. Try a different electrical outlet. Remove the power cable from the rear of the TV and plug it back it in (the power cable tab is inserted correctly when you hear a click).
Just unplug the tV from AC powwer wall socket, let it be at theis state for about 30 minutes, replugh the TV only, and check whether the fault rectifes. OK.
Apr 23, 2011 | Panasonic Televison & Video
Television doesn't turn on sometimes. So I would have to unplug it for 10 minutes then plug it back in so it can turn on.
This might be because of the leakage also. ome of the parts would require sometime to charge up. The effeciency would have got reduced.
Regards,
HP
Aug 29, 2009 | Televison & Video
When i unplug my tv and plug it back it wont turn on, and after many tries of plugging and unplugging sometimes it turns on
Do you have a wall switch on that receptacle , maybe , just maybe, somebody is playing games with ya ...lol...
Oct 12, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Ge 46 inch projection tv
Turn your set on. While it is on unplug the power cord. Let it sit for about 5 minutes and then plug it back in. If the set comes on without turning it on you did not leave it unplugged long enough. If you you have to hit the power buttom to get the set to come on you will likely have sound. Sometimes you will have to go into the menu and turn your speakers back on. Also a satelitte reciever or cable bax can do the same thing. Usually you can unplug them for about 30 seconds and then plug them back in and turn them on to correct the problem if they are the cause.
Feb 01, 2008 | GE 46GW 948 46" Rear Projection Television
Turns on and off at all times of the day and night
Microprocessor or EEPROM circuit = difficult repair,could be
expensive......T.
Oct 24, 2007 | RCA 14F512T 14" TV
Pioneer BDP-62FD Elite Blu-Ray Player Logo
22 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
