Question about Fitness Giant Sole Fitness F80 Folding Treadmill
Sole f80 treadmill red power switch stuck to on position
2 Suggested Answers
jtrunsco
SOURCE: SOLE F80 TREADMILL STARTS TO RUN THEN STOPS.
SimplerFASTERSolution So, I had the same problem. After removing the motor cover I checked everything out per earlier instructions. Everything looked great. Having been a software geek for as long as I've been running (35 years), I as inclined to believe this wasn't a hardware problem at all. It appeared to me that the system just needed to be recalibrated. So...here's what I did. I turned the treadmill on and selected the "Manual" program and hit "Start". The monitor, as usual, counted down 3-2-1. As soon as the rollers started to move I hit the "Slow" button on the right upright several times so I knew that the treadmill was running at it's slowest speed. I then started walking on the belt. I started tapping the "Fast" button and let the belt gradually increase in speed and took it up to 6.0. No problem! But...nobody wants to start each workout that slowly. I had a hunch it was 'fixed'. So, I stopped the treadmill and turned everything off. I started it again, selected "Manual", immediately hit the "2" then he "4" then the "6" on the right hand "Speed" panel, and it ran like new. No service call, no new speed sensor, no fiddling with the little 'diode', etc. Give this a try first...no need to even remove the motor cover. Best of luck!
Posted on Oct 19, 2013
Sole f80 stuck elevation
LUBE the gear and shaft motor
2) test the input voltage motor, see the diagram attached, if there are the motor need repair.
3)see if there are some relais, and clean for dirty, oxide, or coil. open and replace.
see the block diagram
Run the software calibration for easy diagnose, and troubleshooting.
God bless you
Nov 23, 2012 | Fitness Giant Sole Fitness F80 Folding...
My fans dont come on, on my brand new sole f80 treadmill
1( test the voltage to the terminal , if there are voltage the FAN is faulty, change it.
2( if there are NOT voltage to the terminal FAN, test the line why are NOT coming voltage, test some fuse, or c. breaker, tight any plug, connector, or loose wires.
3( Try again.
see the block di attached. and fix it.
God bless you
Oct 01, 2012 | Sole Fitness Sole F80 Treadmill 2011 Model...
My control panel on the Sole F80 Treadmill lights up but nothing I press works
adjust the REED SWITCH, see the diagram attached, clean it and tight the wires connector very well.
tight the ribbon cables insides from keypads +tight the wires connector from display board vs lower board and clean it.
God bless you
Jul 22, 2012 | RTO Sole F80 Treadmill
My Sole F80 deck bounces excessivly when not at an incline.
1) Lube the deck belt, this problem is lack of maintenance, maybe the deck belt is worn.
2) You must align the deck belt see the diagram
3) Lube the rollers bearing very well very important too
see the video: God bless you
May 15, 2012 | RTO Sole F80 Treadmill
Motor is not responsive and it read LOW SPEED message and time L51
Double check that all connections are secure, especially the console cable. Unplug and reconnect the console cable to verify.
Make sure the console cable is not pinched or damaged in any way.
Turn the power off, unplug the power cable and wait 60 seconds. Remove the motor cover. Wait until all red LED lights have gone off on the motor control board before proceeding. Next, verify that none of the wires connected to the lower board are loose or disconnected.
Oct 20, 2011 | RTO Sole F80 Treadmill
Error code of ls1 on sole f80 treadmill
John what are you talking about. All that's gonna do is give a LS error is you disconnect the motor.
Aug 22, 2010 | RTO Sole F80 Treadmill
Fitness Giant Sole Fitness F80 Folding Treadmill Logo
42 people viewed this question
Top Fitness Giant Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Fitness Giant Exercise and Fitnes Expert? Answer questions, earn points and help others
